-Samsung TV Line-up 2017-
4K OLED
26 April 2014
12
Q9
Q8
Q7
xavito
29 October 2008
8,991
Samsung QLED vs. LG OLED TV: What's the difference?​
...QLED stands for Quantum Dot LED TV...
A QLED TV is an LCD TV with quantum dots
Marketing aside, the two technologies are very different. Here's a quick summary.
OLED stands for "Organic light emitting diode."
QLED (according to Samsung) stands for "Quantum dot LED TV."
OLED is a fundamentally different technology from LCD, the major type of TV today.
QLED is a variation of LED LCD, adding a quantum dot film to the LCD "sandwich."
OLED is "emissive," meaning the pixels emit their own light.
QLED, like LCD, is, in its current form, "transmissive" and relies on an LED backlight.
source:[cnet.com]
[cnet.com]...Samsung QLED TVs on sale starting at $2500. That's really expensive....https://www.cnet.com/news/samsung-qled-tvs-on-sale-starting-at-2500-that-seems-way-too-expensive/
hristoslav2
8 January 2016
359
Varna, Bulgaria
https://forum.setcombg.com/samsung-телевизори/58649-samsung-телевизори-2017-a-15.html#post808557
Premium (QDCF)
Samsung QLED TV 2017 - european models / Samsung QLED TV 2017 - european models / Samsung QLED TV 2017 - european models / Samsung QLED TV 2017 - european models
SeriesCertificatesHardware & SoftwareCalibrationPicture QualityOtherSeries
Series
Model
________________
UHD Premium
_____
Dolby Vision
VS10
____
Hybrid
Log Gamma
(HLG)
_____
HDR 10
ST2084
(EOTF PQ),
ST2086
(static metadata)
ST2094-40
(dynamic metadata)
________
Advanced HDR Technicolor
ST2094-30
_______​
THX
____
SoC / GPU / RAM
_________________________
Plattform
Central Processing Unit
System on Chip
Instruction set
Graphic Processor Unit
RAM
Total memory
Software
____________
Operating System
Firmware version
Internal Processing
Videopanel
Type LCD/Oled matrix,
Resolution,
Bits of color,
(Operating frequency of T-Con board)
FRC,
Curvature,
Screen Uniformity,
Anti-reflective filter
Backlight Unit
_______________
Type backlight
Local Dimming zone,
Type LED,
MEMC,
Backlight Scanning,
Black Frame Insertion,
PulsΠϴ Wide Modulation
Opportunities for calibration
Color
_______________________________
DCI P3,
Rec.2020,
Delta E ,
Gamma,
Color Temperature
Brightness
in HDR
in SDR,
Average Pocture Level,
Automatic Brightness Limiter,
Contrast
ANSI Contrast,
With local dimming,
Without local dimming,
White level,
Black level
Viewing angle
_________
Horizontal & Vertical
(°cone)
Motion resolution​
______________
Input Lag
_______________
Audio
Built in Media Player
Supported file systems
Image file formats
Audio file formats/codecs
Video file formats
Subtitles
Networks
__________________
Supported Resolutions
Frame per seconds
24, 25, 30, 50, 60, 100, 120
Chroma subsampling
4:4:4
4:2:2
4:2:0
Conectors
_____________________________________
Tuners
___________________
Note
_________________________________________
Pros & Cons
Product
Q9F
(Flat)
QE-88Q9F
QE-65Q9F
successor model KS9
no HFR (High Frame Rate)
no HDMI 2.1
no DP 1.3
??Yes Yes in internet services, HDMI, USB port.
Conversion SDR/HDR
ST2084,
ST2086,
ST2094,
No
NoPlattform:
SoC:
Core Architecture:
Instruction set:
Operating at up to:
GPU:
Open GL
RAM:
Total memory:
Available memory:
Internal storage total space:
Internal storage free space:
Electronics and remote connection in the One Connect box
OS: Tizen 3.088" - QDCF-MVA (Samsung Display), 3840x2160, RGB, 10-bit, 120/100Hz, FRC, Flat
65" - QDCF-MVA (Samsung Display), 3840x2160, RGB, 10-bit, 120/100Hz, FRC, Flat
FALD
White balance - 2/20points88" - DCI/P3 - 108%
88" - BT.2020 - 98%
88" -
88" -
88" -
65" - DCI/P3 - 108%
65" - BT.2020 - 98%
65" -
65" -
65" -
88" - max 200cd/m2 in HDR
88" - max cd/m2 in SDR
65" - max 200cd/m2 in HDR
65" - max cd/m2 in SDR
APL -
ABL - full-field peak white came in at:
5% - cd/m2 (? mode) - in HDR
10% - cd/m2 (? mode) - in HDR
88" -
65" -
88" -°
65" -°
88" -
65" -
88"- HDR - ms
88"- Game mode - ms
88"- by default - ms
65"- HDR - ms
65"- Game mode -
65"- by dafault
? W (4ohms)
Dolby Plus, Dolby Puls,
DTS,
FAT16, FAT32, NTFS and exFAT
Image formats:
JPEG, JIF, PNG, MPO, BMP
Video formats:
3GPP, AVI, ASF, DivX, Flash Video, H.263, H.264, H.265, MKV, M2TS, MP4, MPEG-4,TS, VC-1, VP7, VP8, VP9, VRO, WebM, WMV,
Audio formats:
AAC, FLAC, M4A, MIDI, MP3, OGG, WMA, WAV, APE, AIFF, ALAC,
Subtitles formats:
Lan (100BASE-TX/10BASE-T)
Wi-Fi
802.11 a
802.11 b
802.11 g802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
DLNA
Bluetooth
2 x USB 2.0 (DC 5V MAX 500mA)
1 x USB 3.0 (DC 5V MAX 900mA)
1 x Ethernet RJ45
4 x HDMI 2.0a - HDCP2.2 (ARC, CEC, MHL 3.0)
1 x AV Cimposite in
1 x AV Component In
1 x Optical Audio Out (AAC/PCM/AC3/Dolby/DTS/DTS Neo2.5)
1 x Antena (RF) (female)
1 x CI+ 1.3
1 x RS.232C
Compatible Rec.2020 input
Double tuners
DVB-T/T2/C/S/S2
DiSEqC version 1.0
PIP, PAP, PAT
Timeshift & PVR
MPEG2, MPEG4,HEVC H.265, VP9
Q9F
(Flat)
QE-88Q9F
QE-65Q9F
Q8C
(Curved)
QE-75Q8C
QE-65Q8C
QE-55Q8C
successor model KS8
no HDMI 2.1
no DP 1.3
??YesYes in internet video services, HDMI, USB port.
Conversion SDR/HDR
ST2084,
ST2086,
ST2094,
NoNoPlattform:
SoC:
Core architecture:
Instruction set:
Operating at up to
GPU:
OpenGL
RAM:
Total memory:
Available memory:
OS: Tizen 3.075" - QDCF-MVA (Samsung Display), 3840x2160, RGB, 10-bit(?), 120/100Hz, FRC,
Curvature 4200R
65" - QDCF-MVA (Samsung Display), 3840x2160, RGB, 10-bit(?), 120/100Hz, FRC,
Curvature 4200R
54,5" - QDCF-MVA (Samsung Display), 3840x2160, RGB, 10-bit(?), 120/100Hz, FRC,
Curvature 4200R
Edge Led
White balance - 2/20 points75" - DCI/P3 - 108%
75" - Rec.2020 - 98%
75" -
75" -
75" -
65" - DCI/P3 - 108%
65" - Rec.2020 - 98%
65" -
65" -
65" -
55" - DCI/P2 -108%
55" - Rec.2020 - 98%
55" -
55" -
75" - max 1500cd/m2
65" - max 1500cd/m2
APL
5% - cd/m2 (Vivid mode) - in HDR
10% - cd/m2 (Vivid mode) - in HDR
75" -
65" -
75" - °
65" - °
75" -
65" -
75"- HDR
75"- Game mode
75"- by dafault
65"- HDR
65"- Game mode ms
65"- by default ms
65" -
55" - 60W (20W x 2 + Woofer 10W x 2 )(4ohms)
Front Firing (4.2CH)
Dolby Digital Plus, Dolby Puls,
DTS Premium Sound 5.1,
Image formats:
Video formats:
Audio formats:
Subtitles formats:
Wi-Fi
802.11 a,
802.11 b,
802.11 g,
802.11 n,
802.11 n 5GHz,
802.11 ac,
WiFi Direct
DLNA
Blietooth
2 x USB 2.0 (DC 5V MAX 500mA) - [HID support]
2 x USB 3.0 (DC 5V MAX 900mA)
1 x Ethernet RJ45
4 x HDMI 2.0 - (ARC, CEC, MHL 3.0)
1 x Satelite In (Main: F-type female)
1 x Satelite In (Sub: F-type female)
1 x SCART
1 x AV Composite In
1 x AV Component In
1 x Optical Audio Out (AAC/PCM/AC3/Dolby/DTS/DTS Neo 2.5)
1 x 3.5mm Audio Out
1 x CI+ 1.3
1 x RS.232C
CompatibleRec.2020 input
Double tuners
DVB-T/T2/C/S/S2
DiSEqC version 1.0
PIP, PAP, PAT
Timeshift & PVR
MPEG2, MPEG4, HEVC H.265,
VP9
Q8C
(Curved)
QE-75Q8C
QE-65Q8C
QE-55Q8C
Q7C
(Curved)
QE-65Q7C
QE-55Q7C
QE-49Q7C
successor model KS7
no HDMI 2.1
no DP 1.3
Conversion SDR/HDR
ST2084,
ST2086,
ST2094,
No
NoPlattform:
SoC:
Core Architecture:
Instruction set:
Operating at up to:
GPU:
Open GL
RAM:
Total memory:
Available memory:
OS: Tizen 3.064.5" - QDCF-MVA (Samsung Display),
120/100Hz, FRC,
Curvature 4200R
Curvature 4200R
Model: ()
48.5" - QDCF-MVA (Samsung Display), 3840x2160, RGB, 10-bit(?), 120/100Hz, FRC,
Curvature 4200R
Edge Led
White balance - 2/20points55" - DCI/P3 - 108%
55" - BT.2020 - 98%
55" -
49" - DCI/P3 - 108%
49" - BT.2020 - 98%
49" -
49" -
49" -
55" - max 1500cd/m2 in HDR
55" - max cd/m2 in SDR
49" - max 1500cd/m2 in HDR
49" - max cd/m2 in SDR
APL -
55" -
49" -
55" -°
49" -°
55" -
49" -
55"- HDR - ms
55"- Game mode - ms
55"- by default - ms
49"- HDR - ms
49"- Game mode -
49"- by dafault
? W (4ohms)
DTS,
Image formats:
Video formats:
Audio formats:
Subtitles formats:
Wi-Fi
802.11 a,
802.11 b,
802.11 g,
802.11 n,
802.11 n 5GHz,
802.11 ac,
Wi-Fi Direct
DLNA
Bluetooth
1 x Ethernet RJ45
1 x AV Cimposite in
1 x AV Component In
1 x CI+ 1.3
1 x RS.232
Double tuners
DVB-T/T2/C/S/S2
DiSEqC version 1.0
PIP, PAP, PAT
Timeshift & PVR
Q7C
(Curved)
QE-65Q7C
QE-55Q7C
QE-49Q7C
Q7F
(Flat)
QE-75Q7F
QE-65Q7F
QE-55Q7F
QE-49Q7F
successor model KS7
no HDMI 2.1
no DP 1.3
Conversion SDR/HDR
ST2084,
ST2086,
ST2094,
No
NoPlattform:
SoC:
Core Architecture:
Instruction set:
Operating at up to:
GPU:
Open GL
RAM:
Total memory:
Available memory:
OS: Tizen 3.074.5" - QDCF-MVA (Samsung Display), 3840x2160, RGB, 10-bit, 120/100Hz
64.5" - QDCF-MVA (Samsung Display), 3840x2160, RGB, 10-bit, 120/100Hz
54.5" - QDCF-MVA (Samsung Display), 3840x2160, RGB, 120/100Hz
10-bit, 120/100Hz, Flat
48.5" - QDCF-MVA, 3840x2160, RGB,
Edge Led
55" - BT.2020 - 98%
55" -
49" - DCI/P3 - 108%
49" - BT.2020 - 98%
49" -
49" -
49" -
APL -
55" -
49" -
55" -°
49" -°
55" -
49" -
55"- HDR - ms
55"- Game mode - ms
49"- HDR - ms
49"- Game mode -
49"- by dafault
? W (4ohms)
DTS,
FAT16, FAT 32, NTFS and exFAT
Wi-Fi
802.11 a,
802.11 b,
802.11 g,
802.11 n,
802.11 n 5GHz,
802.11 ac,
Wi-Fi Direct
DLNA
Bluetooth
1 x Ethernet RJ45
1 x AV Cimposite in
1 x AV Component In
1 x CI+ 1.3
1 x RS.232
Double tuners
DVB-T/T2/C/S/S2
DiSEqC version 1.0
PIP, PAP, PAT
Timeshift & PVR
Q7F
(Flat)
QE-75Q7F
QE-65Q7F
QE-55Q7F
QE-49Q7F
High End (QDEF)
Samsung Premium UHD TV 2017 - european models / Samsung Premium UHD TV 2017 - european models / Samsung Premium UHD TV 2017 - european models / Samsung Premium UHD TV 2017 - european models
Series
Model
________________
UHD Premium
_____
Dolby Vision
VS10
____
Hybrid
Log Gamma
(HLG)
_____
HDR 10
ST2084
(EOTF PQ),
ST2086
(static metadata)
ST2094-40
(dynamic metadata)
________
ST2094-30
_______​
THX
____
SoC / GPU / RAM
Plattform
System on Chip
Instruction set
RAM
Total memory
Software
____________
Operating System
Firmware version
Internal Processing
Videopanel
Resolution,
Bits of color,
Curvature,
Screen Uniformity,
Backlight Unit
_______________
Type backlight
Local Dimming zone,
Type LED,
MEMC,
Backlight Scanning,
Color
DCI P3,
Rec.2020,
Delta E ,
Gamma,
Color Temperature
Brightness
in HDR
in SDR,
Contrast
ANSI Contrast,
With local dimming,
White level,
Black level
Viewing angle
_________
(°cone)
Motion resolution​
______________
Input Lag
_______________
Audio
Image file formats
Video file formats
Subtitles
Networks
__________________
Frame per seconds
Chroma subsampling
4:4:4
4:2:2
4:2:0
Conectors
Tuners
___________________
Note
Pros & Cons
Product
MU9000
(Curved)
UE-65MU9000
UE-55MU9000
UE-49MU9000
no HDMI 2.1
no DP 1.3
Yes?Yes Yes in internet services, HDMI, USB port.
Conversion SDR/HDR
ST2084,
ST2086,
ST2094,
No
NoPlattform:
SoC:
Core Architecture: 4x
Instruction set:
Operating at up to:
GPU:
Open GL
RAM:
Total memory:
Available memory:
OS: Tizen 3.064.5" - QDEF-MVA, 3840x2160, RGB, 10-bit, 120/100Hz, Curvature 4200R
55" - QDEF-MVA, 3840x2160, RGB, 10-bit, 120/100Hz, Curvature 4200R
48.5" - QDEF-MVA, 3840x2160, RGB, 10-bit, 120/100Hz, Curvature 3000R
Ultra Black filter
Edge Led, Local Dimming
55" - BT.2020 - 98%
55" -
49" - DCI/P3 - 108%
49" - BT.2020 - 98%
49" -
49" -
49" -
APL -
55" -
49" -
55" -°
49" -°
55" -
49" -
55"- HDR - ms
55"- Game mode - ms
49"- HDR - ms
49"- Game mode -
49"- by dafault
? W (4ohms)
DTS,
Image formats:
Video formats:
Audio formats:
Subtitles formats:
Wi-Fi
802.11 a
802.11 b
802.11 g802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
DLNA
Bluetooth
MU9000
(Curved)
UE-65MU9000
UE-55MU9000
UE-49MU9000
no HDMI 2.1
no DP 1.3
MU8000
(Flat)
UE-75MU8000
UE-65MU8000
UE-55MU8000
UE-49MU8000
Conversion SDR/HDR
ST2084,
ST2086,
ST2094,
No
NoPlattform:
SoC:
Instruction set:
Operating at up to:
GPU:
Open GL
RAM:
Total memory:
Available memory:
OS: Tizen 3.074.5" - QDEF-MVA, 3840x2160, RGB, 10-bit, 120/100Hz
54.5" - QDEF-MVA, 3840x2160, RGB, 10-bit, 120/100Hz,
Ultra Black filter
55" - BT.2020 - 98%
55" -
49" - DCI/P3 - 108%
49" - BT.2020 - 98%
49" -
49" -
49" -
APL -
55" -
49" -
55" -°
49" -°
55" -
49" -
55"- HDR - ms
55"- Game mode - ms
49"- HDR - ms
49"- Game mode -
49"- by dafault
? W (4ohms)
DTS,
Image formats:
Video formats:
Audio formats:
Subtitles formats:
Wi-Fi
802.11 a
802.11 b
802.11 g802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
DLNA
Bluetooth
1 x Ethernet RJ45
1 x AV Cimposite in
1 x AV Component In
1 x CI+ 1.3
1 x RS.232
Double tuners
DVB-T/T2/C/S/S2
DiSEqC version 1.0
PIP, PAP, PAT
Timeshift & PVR
MPEG2,
MPEG4,
HEVC H.265,
VP9
Mini One Connect
MU8000
(Flat)
UE-75MU8000
UE-65MU8000
UE-55MU8000
UE-49MU8000
MU7000
(Flat)
UE-82MU7000
UE-75MU7000
UE-55MU7000
UE-49MU7000
Conversion SDR/HDR
ST2084,
ST2086,
ST2094,
No
NoPlattform:
SoC:
Instruction set:
Operating at up to:
GPU:
Open GL
RAM:
Total memory:
Available memory:
OS: Tizen 3.082" - QDEF-MVA, 3840x2160, RGB, 10-bit, 120/100Hz,
74.5" - QDEF-MVA, 3840x2160, RGB, 10-bit, 120/100Hz,
55" - BT.2020 - 98%
55" -
49" - DCI/P3 - 108%
49" - BT.2020 - 98%
49" -
49" -
49" -
APL -
55" -
49" -
55" -°
49" -°
55" -
49" -
55"- HDR - ms
55"- Game mode - ms
49"- HDR - ms
49"- Game mode -
49"- by dafault
? W (4ohms)
DTS,
Image formats:
Video formats:
Audio formats:
Subtitles formats:
Wi-Fi
802.11 a
802.11 b
802.11 g802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
DLNA
Bluetooth
MU7000
(Flat)
UE-82MU7000
UE-75MU7000
UE-55MU7000
UE-49MU7000
Middle range
Samsung UHD TV 2017 - european models / Samsung UHD TV 2017 - european models / Samsung UHD TV 2017 - european models / Samsung UHD TV 2017 - european models / Samsung UHD TV 2017 - european models
Series
Model
________________
UHD Premium
_____
Dolby Vision
VS10
____
Hybrid
Log Gamma
(HLG)
_____
HDR 10
ST2084
(EOTF PQ),
ST2086
(static metadata)
ST2094-40
(dynamic metadata)
________
ST2094-30
_______​
THX
____
SoC / GPU / RAM
Plattform
System on Chip
Instruction set
RAM
Total memory
Software
____________
Operating System
Firmware version
Internal Processing
Videopanel
Resolution,
Bits of color,
Curvature,
Screen Uniformity,
Backlight Unit
_______________
Type backlight
Local Dimming zone,
Type LED,
MEMC,
Backlight Scanning,
Color
DCI P3,
Rec.2020,
Delta E ,
Gamma,
Color Temperature
Brightness
in HDR
in SDR,
Contrast
ANSI Contrast,
With local dimming,
White level,
Black level
Viewing angle
_________
(°cone)
Motion resolution​
______________
Input Lag
_______________
Audio
Image file formats
Video file formats
Subtitles
Networks
__________________
Frame per seconds
Chroma subsampling
4:4:4
4:2:2
4:2:0
Conectors
Tuners
___________________
Note
Pros & Cons
Product
MU6500
(Curved)
UE-65MU6500
UE-55MU6500
UE-49MU6500
Conversion SDR/HDR
ST2084,
ST2086,
ST2094,
No
NoPlattform:
SoC:
Core Architecture:
Instruction set:
Operating at up to:
GPU:
Open GL
RAM:
Total memory:
Available memory:
OS: Tizen 3.064.5" - ?, 3840x2160, RGB, 8-bit, 60/50Hz, Curvature 4200R
54.5" - ?, 3840x2160, RGB, 8-bit, 60/50Hz, Curvature 4200R
48.5" - ?, 3840x2160, RGB, 8-bit, 60/50Hz, Curvature 3000R
Edge Led
55" - BT.2020 -
55" -
49" - DCI/P3 -
49" - BT.2020 -
49" -
49" -
49" -
55" - max cd/m2 in HDR
49" - max cd/m2 in HDR
55" -
49" -
55" -°
49" -°
55" -
49" -
55"- HDR - ms
55"- Game mode - ms
49"- HDR - ms
49"- Game mode -
49"- by dafault
? W (4ohms)
DTS,
Wi-Fi
802.11 a
802.11 b
802.11 g802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
DLNA
Bluetooth
MU6500
(Curved)
UE-65MU6500
UE-55MU6500
UE-49MU6500
MU6400
(Flat)
UE-65MU6400
UE-55MU6400
UE-49MU6400
UE-43MU6400
UE-40MU6400
Conversion SDR/HDR
ST2084,
ST2086,
ST2094,
No
NoPlattform:
SoC:
Core Architecture:
Instruction set:
Operating at up to:
GPU:
Open GL
RAM:
Total memory:
Available memory:
OS: Tizen 3.0Edge Led
55" - BT.2020 -
55" -
49" - DCI/P3 -
49" - BT.2020 -
49" -
49" -
49" -
APL -
55" -
49" -
55" -°
49" -°
55" -
49" -
55"- HDR - ms
55"- Game mode - ms
49"- HDR - ms
49"- Game mode -
49"- by dafault
? W (4ohms)
DTS,
Wi-Fi
802.11 a
802.11 b
802.11 g802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
DLNA
Bluetooth
MU6400
(Flat)
UE-65MU6400
UE-55MU6400
UE-49MU6400
UE-43MU6400
UE-40MU6400
MU6200
(Curved)
UE-65MU6200
UE-55MU6200
UE-49MU6200
Conversion SDR/HDR
ST2084,
ST2086,
ST2094,
No
NoPlattform:
SoC:
Core Architecture:
Instruction set:
Operating at up to:
GPU:
Open GL
RAM:
Total memory:
Available memory:
OS: Tizen 3.064.5" - ?, 1920x1080, RGB, 60/50Hz, 8-bit
54.6" - ?, 1920x1080, RGB, 60/50Hz, 8-bit
48.5" - ?, 1920x1080, RGB, 60/50Hz, 8-bit
Edge Led
55" - BT.2020 - 98%
55" -
49" - DCI/P3 - 108%
49" - BT.2020 - 98%
49" -
49" -
49" -
APL -
55" -
49" -
55" -°
49" -°
55" -
49" -
55"- HDR - ms
55"- Game mode - ms
49"- HDR - ms
49"- Game mode -
49"- by dafault
? W (4ohms)
DTS,
Wi-Fi
802.11 a
802.11 b
802.11 g802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
DLNA
Bluetooth
MU6200
(Curved)
UE-65MU6200
UE-55MU6200
UE-49MU6200
MU6100
(Curved)
UE-75MU6100
UE-65MU6100
UE-55MU6100
UE-50MU6100
UE-49MU6100
UE-43MU6100
UE-40MU6100
Conversion SDR/HDR
ST2084,
ST2086,
ST2094,
No
NoPlattform:
SoC:
Core Architecture:
Instruction set:
Operating at up to:
GPU:
Open GL
RAM:
Total memory:
Available memory:
49.5" - ?, 1920x1080, RGB, 60/50Hz, 8-bit
42.5" - ?, 1920x1080, RGB, 60/50Hz, 8-bit,
40" - ?, 1920x1080, RGB, 60/50Hz, 8-bit,
Edge Led
55" - BT.2020 -
55" -
49" - DCI/P3 -
49" - BT.2020 -
49" -
49" -
49" -
APL -
55" -
49" -
55" -°
49" -°
55" -
49" -
55"- HDR - ms
55"- Game mode - ms
49"- HDR - ms
49"- Game mode -
49"- by dafault
? W (4ohms)
DTS,
Wi-Fi
802.11 a
802.11 b
802.11 g802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
DLNA
Bluetooth
MU6200
(Curved)
UE-75MU6100
UE-65MU6200
UE-55MU6200
UE-50MU6100
UE-49MU6200
UE-43MU6100
UE-40MU6100
Low level
Samsung Full TV 2017 - european models / Samsung Full TV 2017 - european models / Samsung Full TV 2017 - european models / Samsung Full TV 2017 - european models
Series
Model
________________
UHD Premium
_____
Dolby Vision
VS10
____
Hybrid
Log Gamma
(HLG)
_____
HDR 10
ST2084
(EOTF PQ),
ST2086
(static metadata)
ST2094-40
(dynamic metadata)
________
ST2094-30
_______​
THX
____
SoC / GPU / RAM
Plattform
System on Chip
Instruction set
RAM
Total memory
Software
____________
Operating System
Firmware version
Internal Processing
Videopanel
Resolution,
Bits of color,
Curvature,
Screen Uniformity,
Backlight Unit
_______________
Type backlight
Local Dimming zone,
Type LED,
MEMC,
Backlight Scanning,
Color
DCI P3,
Rec.2020,
Delta E ,
Gamma,
Color Temperature
Brightness
in HDR
in SDR,
Contrast
ANSI Contrast,
With local dimming,
White level,
Black level
Viewing angle
_________
(°cone)
Motion resolution​
______________
Input Lag
_______________
Audio
Image file formats
Video file formats
Subtitles
Networks
__________________
Frame per seconds
Chroma subsampling
4:4:4
4:2:2
4:2:0
Conectors
Tuners
___________________
Note
Pros & Cons
Product
MU6300
(Curved)
UE-65MU6300
UE-55MU6300
UE-49MU6300
NoNoNoNoNo
NoPlattform:
SoC:
Core Architecture:
Instruction set:
Operating at up to:
GPU:
Open GL
RAM:
Total memory:
Available memory:
Edge Led,
No,
WLED,
Yes
65" -
55" -
49" -
55" -
49" -
55" -
49" -
55" -°
49" -°
55" -
49" -
55"-
49"-
Wi-Fi
802.11 a
802.11 b
802.11 g802.11 n
802.11 n 5GHz
Wi-Fi Direct
DLNA
Bluetooth
MU6300
(Curved)
UE-65MU6300
UE-55MU6300
UE-49MU6300
MU5500
(Flat)
UE-55MU5500
UE-50MU5500
UE-43MU5500
UE-32MU5500
NoNoNoNoNo
NoPlattform:
SoC:
Core Architecture:
Instruction set:
Operating at up to:
GPU:
Open GL
RAM:
Total memory:
Available memory:
OS: Tizen 3.054,6" - ?, 1920x1080, RGB, 60/50Hz, 8-bit
8-bit
31.5" - ?, 1920x1080, RGB, 60/50Hz, 8-bit
Edge Led,
No,
WLED,
Yes
55" -
49" -
55" -
49"
55" -
49" -
55" -°
49" -°
55" -
49" -
55"-
49"-
Wi-Fi
802.11 a
802.11 b
802.11 g802.11 n
802.11 n 5GHz
Wi-Fi Direct
DLNA
Bluetooth
1 x Ethernet RJ45
1 x AV Cimposite in
1 x AV Component In
1 x CI+ 1.3
1 x RS.232
DVB-T2/C
Timeshift & PVR
MU5500
(Flat)
UE-55MU5500
UE-50MU5500
UE-43MU5500
UE-32MU5500
xavito
29 October 2008
8,991
What is the difference between a QLED and OLED TV?...https://www.avforums.com/article/what-is-the-difference-between-a-qled-tv-and-oled-tv.13307
...By comparison QLED is a marketing term and a QLED TV still uses a traditional LCD panel with an LED backlight, whether that backlight is at the edge or to the rear. The image is created by passing the light from the LEDs through the panel and, as result, the black levels are far less impressive when compared to an OLED TV. To improve their black level performance LCD TVs use a number of technological developments, including vertical alignment (VA) panels and local dimming. The use of a VA panel does improve the black levels but at the expense of the off-axis performance.
Local dimming involves breaking the picture up into zones and turning them on or off depending on the image, this does improve the blacks but also results in haloing where a bright object glows because it crosses over two zones. The solution is to increase the number of zones because the more zones, the less likely there will be haloing. There have been LCD TVs released with over 600 local dimming zones but to put that in perspective, an OLED TV with its self-illuminating pixels effectively has over 8 million dimming zones. So an OLED TV can not only deliver deeper blacks but it do so with far greater accuracy...
source:[avforums.com]
Damien
20 November 2016
57
Πάλι ''κάστανο'' μου φαίνεται θα πέσει αν θες πραγματικό HDR.Έλεγα οτι φέτος θα πέσει στην σειρά 6 το hdr και θα ξενερώσω που πήρα KU6000 αλλά μπα.Aποδεικνύεται καλή αγορα:2thumb22sup:
Damien
20 November 2016
57
Μούφα είναι,ουτε 10bit panel ούτε wide color gamut.Με τρώει μήπως μετανιώσω μελλοντικά που δεν έκανα οικονομία να πάρω ks7000 αλλά τότε ήταν στα 1200.Εγώ έδωσα τα μισά και είμαι καταευχαριστημένος.
Με αυτό το video video ψάρωσα οτι κάτι χάνω αλλά βλέπουμε.:grandpa:Happy είμαι και τώρα αλλά σου βάζουν το μικρόβιο οι άτιμοι.:furious3:
xavito
29 October 2008
8,991
[areadvd.de]...Samsung announces prices for QLED TV & UHD TV 2017...http://www.areadvd.de/news/samsung-gibt-preise-fuer-qled-tv-uhd-fernseher-2017-bekannt/
μετάφραση google de to en
Samsung TV portfolio 2017 at a glance
QLED TV:
Samsung Q9F (65 inch - 5499 Euro)
Samsung Q8C (75 inch - 6499 Euro, 65 inches - 4499 Euro, 55 inches - 3499 Euro)
Samsung Q7C (65 inch - 3799 Euro, 55 inch - 2799 Euro, 49 inch - 2499 Euro)
Samsung Q7F (75 inch - 5599 Euro, 65 inch - 3599 Euro, 55 inch - 2599 Euro, 49 inch - 2299 Euro)
Premium UHD TV:
Samsung MU9009 (65 inch - 2899 Euro, 55 inch - 2099 Euro, 49 inch - 1799 Euro)
Samsung MU8009 (75 inch - 4799 Euro, 65 inch - 2699 Euro, 55 inch - 1899 Euro, 49 inch - 1599 Euro)
Samsung MU7009 (75 inch - 4449 Euro, 65 inch - 2499 Euro, 55 inch - 1699 Euro, 49 inch - 1399 Euro)
UHD TV:
Samsung MU6509 (65 inch - 2199 Euro, 55 inch - 1399 Euro, 49 inch - 1149 Euro)
Samsung MU6409 (65 inch - 2049 Euro, 55 inch - 1249 Euro, 49 inch - 999 Euro, 40 inch - 829 Euro)
Samsung MU6179 (75 inch - 3299 Euro, 65 inch - 1799 Euro, 55 inch - 999 Euro, 49 inch - 849 Euro, 43 inch - 749 Euro, 40 inch - 729 Euro)
JL_?
19 September 2008
15,415
Terra
Μην ψαρώνεις άδικα. Δεν υπάρχει τέτοια διαφορά μεταξύ KU6000 και KS7000, ειδικά σε τέτοιου τύπου υλικό... -bye-
Damien
20 November 2016
57
Α,υπάρχει διαφορά αλλά δεν είναι τόσο τρανταχτή,καπως έτσι ε?Μια χαρά τότε,μπορώ και χωρίς αυτό για την ώρα.
