-Samsung TV Line-up 2017-
xavito
29 October 2008
8,991
[audiovideohd.fr]...New tv series Samsung 2017: QLED TV and UHD tv series prices...http://www.audiovideohd.fr/actualites/11645-Prix-nouvelle-gamme-TV-QLED-UHD-Samsung-2017.html
μετάφραση google fr to en
Αρχικές ενδεικτικές τιμές στη Γαλλία:
QLED series Q9, Q8C, Q7 :
QE88Q9F : 19 999,00
QE75Q8C : 5 999,00
QE65Q9F : 4 999
QE65Q8C : 3 999,00
QE65Q7F : 3 499,00
QE55Q8C : 2 999,00
QE55Q7F : 2 499,00
QE49Q7F : 1 999,00
UHD Premium series MU9000, MU8000, MU7000 :
UE65MU9005 : 2 799,00
UE55MU9005 : 1 999,00
UE49MU9005 : 1 699,00
UE85MU7005 : 4 999,00
UE75MU7005 : 3 999,00
UE65MU7045 : 2 499,00
UE55MU7045 : 1 699,00
UE49MU7045 : 1 399,00
UE49MU6645 : 1 099,00
UE49MU6405 : 899,00
UE49MU6105 : 799,00
UE43M5575 : 699,00
UHD series 6000:
UE75MU6105 : 2 999,00
UE65MU6645 : 2 199,00
UE65MU6405 : 1 699,00
UE65MU6105 : 1 499,00
UE55MU6405 : 1 099,00
xavito
29 October 2008
8,991
[pocket-lint.com]...What is QLED? Samsung's new TV tech explained...http://www.pocket-lint.com/news/139867-what-is-qled-samsung-s-new-tv-tech-explained
What is QLED?
Samsung has called its new TVs QLED because they use quantum dot technology on an LED panel. Quantum dot + LED = QLED. Simple. This isn't actually a new technology, it's the third-generation of quantum dot in Samsung's TVs, so you'll also find it in the 2015 and 2016 SUHD models, although in the new QLED 2017 models, there are a lot of changes.
It's being pitched as a rival to OLED (organic light emitting diode) at the high-end, with Samsung pushing the message that QLED is a superior technology with a number of advantages over OLED. It's part of the on-going battle for superiority between LED TV and OLED TV.
The change in name to QLED over SUHD is also a branding and marketing move: not only does QLED as an expression look like OLED, but it resonates better than SUHD, which didn't really mean anything. It also allows Samsung to separate its flagship Q models, from the second-tier models it offers.
JL_?
19 September 2008
15,415
Terra
Τυπική Edge-lit LCD...
Στις 35 μοίρες το φως πέφτει στο μισό και η αντίθεση στο 1/5...
JL_?
19 September 2008
15,415
Terra
Το είχαμε ξαναδεί το εργό με τις "LED"...
H πρώτη ουσιαστική επανάσταση στην αντίθεση των LCD ήταν τα πάνελ VA.
H δεύτερη, η μείωση των διαρροών, που επιτεύχθηκε με το μεγαλύτερο fill ratio και τον προσανατολισμό των κρυστάλλων με υπεριώδη ακτινοβολία.
Η τρίτη, θα επέλθει όταν αφαιρεθούν τα χρωματικά φίλτρα.
Όλα τ' άλλα είναι για να 'χουμε να λέμε...
xavito
29 October 2008
8,991
55"...[rtings.com]...Samsung QN55Q7F review...post #45
...We have contacted Samsung, and they say that our unit is out of spec due to the relatively low peak brightness measurements. We will continue to investigate and update the review as we obtain more information.
Update 3/10/2017. We've ordered another unit. We will test it, verify the results and update the review...
QN55Q7F:Edge LED(only bottom),local dimming,VA panel (RGB),100/120Hz + αναβόσβησμα του οπίσθιου φωτισμού
QN55Q7F:subpixel panel structure,VA panel (RGB),100/120Hz + αναβόσβησμα του οπίσθιου φωτισμού
source photos:[rtings.com]
65"...[avsforum.com]...Samsung Q9 65″ QLED HDR LCD TV: First Look...http://www.avsforum.com/samsung-q9-65-qled-hdr-lcd-tv-first-look/
65Q9:flat, LED-edgelit LCD.
xavito
29 October 2008
8,991
[lesnumeriques.com]...Samsung unveils its range of TVs-frames in Paris: the frame...http://www.lesnumeriques.com/tv-tel...s-qui-se-transforment-en-tableaux-n59219.html
[lesnumeriques.com]...Introducing the new Samsung QLED Q7F, Q8C and Q9F televisions...http://www.lesnumeriques.com/tv-televiseur/nouveaux-televiseurs-samsung-qled-q7f-q8c-q9f-n61289.html
An evolution of SUHD models.
Samsung has unveiled its new QLED televisions, an acronym that unfortunately does not constitute a new technology, but a simple evolution of the SUHD models of last year. QLED TVs consist of three series Q7, Q8 and Q9, available in flat (F for flat) or curved (C for curve).
JL_?
19 September 2008
15,415
Terra
Έτσι... Έβαλε ο απίθανος τύπος την τηλεόραση των 2000 nits δίπλα-δίπλα με την τηλεόραση των 1400 nits και θεωρεί ότι έκανε αντικειμενικό συγκριτικό... :bang:
Και η γνώση, η άμοιρη, έχει πάει πίσω στη δεκαετία του '50...
Ducksong
11 July 2013
4,985
The Dutch Mountains
Έτσι... Έβαλε ο απίθανος τύπος την τηλεόραση των 2000 nits δίπλα-δίπλα με την τηλεόραση των 1400 nits και...
Ανακάλυψε ότι η πιο φωτεινή, δειχνει το ηλιοβασίλεμα καλύτερα :2thumb22sup: μετά έγραψε και ένα κατεβατό για το φα-ντα-στι-κό καλώδιο και έτοιμη η γνωριμία με την καλύτερη LCD ever, γρήγορα και παστρικά :smash:
hristoslav2
8 January 2016
359
Varna, Bulgaria
Samsung QLED TV 2017 - european models / Samsung QLED TV 2017 - european models / Samsung QLED TV 2017 - european models / Samsung QLED TV 2017 - european models
SeriesCertificatesHardware & SoftwareCalibrationPicture QualityOtherNotesSeries
Series
Model
_____________
UHD Premium
_____
Dolby Vision
VS10
____
Hybrid
Log Gamma
(HLG)
_____
HDR 10
ST2084
(EOTF PQ),
ST2086
(static metadata)
ST2094-40
(dynamic metadata)
________
Advanced HDR Technicolor
ST2094-30
_______​
THX
____
SoC / GPU / RAM
________________________
Plattform
Central Processing Unit
System on Chip
Instruction set
Graphic Processor Unit
RAM
Total memory
Software
____________
Operating System
Firmware version
Internal Processing
Videopanel
Type LCD/Oled matrix,
Resolution,
Bits of color,
(Operating frequency of T-Con board)
FRC,
Curvature,
Screen Uniformity,
Anti-reflective filter
Backlight Unit
_______________
Type backlight
Local Dimming zone,
Type LED,
MEMC,
Backlight Scanning,
Black Frame Insertion,
PulsΠϴ Wide Modulation
Display Measurement
Temperature
Uniformity,
Image retention,
Motion blur,
Image flicker,
Motion Interpolation,
Reflection
Opportunities for calibration
________________
Post calibration
_________________
Color Gamut
______________
DCI P3,
Rec.2020,
Delta E ,
Gamma,
Color Temperature
Color Volume
__________________________
Normalized DCI P3 Coverage
(How much of the DCI-P3 colorspace a TV can display at different luminosity levels)
Normalized REC. 2020 Coverage
(How much of the Rec. 2020 colorspace a TV can display at different luminosity levels)
SDR Peak Brightness
Peak Brithness
Average Picture Level,
Automatic Brightness Limiter,
HDR Peak Brightness
Peak Brithness
Contrast
___________________
ANSI Contrast,
With local dimming,
Without local dimming,
White level,
Black level
Viewing angle
____________
Horizontal & Vertical
(°cone)
Color Shift
Brightness
Black Level
Motion resolution​
______________
Input Lag
___________________________
Audio
_______________
Built in Media Player
Supported file systems
Image file formats
Audio file formats/codecs
Video file formats
Subtitles
Networks
__________________
Supported Resolutions
__________________
Frame per seconds
24, 25, 30, 50, 60, 100, 120
Chroma subsampling
4:4:4
4:2:2
4:2:0
Conectors
_____________________________________
Tuners
___________________
Note
Pros & Cons
Product
____________
Q9F
(Flat)
QE-88Q9F
QE-65Q9F
successor model KS9
no HFR
no HDMI 2.1
no DP 1.3
Yes?Yes Yes in internet services, HDMI, USB port.
Conversion SDR/HDR
ST2084,
ST2086,
ST2094,
No
NoPlattform:
SoC:
Core Architecture:
Instruction set:
Operating at up to:
GPU:
Open GL
RAM:
Total memory:
Available memory:
Internal storage total space:
Internal storage free space:
Electronics and remote connection in the One Connect box
OS: Tizen 3.088"
QDCF-MVA (Samsung Display), 3840x2160,
RGB,
10-bit,
120/100Hz,
FRC,
Flat
65"
RGB,
10-bit,
120/100Hz, FRC,
Flat
Edge Lit led system positioned at the left and right sides of the screen
32 Dimming blocks
WLED
MEMC
No
BFI - No
PWM - Yes
--White balance - 2/20points
CMS
White Balance dE:
Color dE: 1.3
Gamma:
88"
DCI/P3 xy - %
DCI/P3 uv - %
Rec.2020 xy - %
Rec.2020 uv - %
65"
DCI/P3 xy - %
DCI/P3 uv - %
Rec.2020 xy- %
Rec.2020 uv - %
88"
Normalized DCI P3 Coverage: %
10,000 cd/m² DCI P3 Coverage: %
Normalized Rec 2020 Coverage: %
10,000 cd/m² Rec 2020 Coverage: %
65"
88" -
65" -
APL -
ABL - full-field peak white came in at:
5% - cd/m2 (? mode) - in HDR
10% - cd/m2 (? mode) - in HDR
88" -
88" -
88" -
88" -
88" -
65" -
65" -
65" -
65" -
65" -
88"
H&V - °
Color Shift -
Brightness -
Black Level -
65"
H&V - °
Color Shift -
Brightness -
Black Level -
88" -
65" -
88"- HDR - ms
88"- Game mode - ms
88"- by default - ms
65"- HDR - ms
65"- Game mode -
65"- by dafault
? W (4ohms)
Dolby Plus,
Dolby Puls,
DTS,
FAT16, FAT32, NTFS and exFAT
Image formats:
JPEG, JIF, PNG, MPO, BMP
Video formats:
3GPP, AVI, ASF, DivX, Flash Video, H.263, H.264, H.265, MKV, M2TS, MP4, MPEG-4,TS, VC-1, VP7, VP8, VP9, VRO, WebM, WMV,
Audio formats:
AAC, FLAC, M4A, MIDI, MP3, OGG, WMA, WAV, APE, AIFF, ALAC,
Subtitles formats:
Lan (100BASE-TX/10BASE-T)
Wi-Fi
802.11 a
802.11 b
802.11 g802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
DLNA
Bluetooth
2 x USB 2.0 (DC 5V MAX 500mA)
1 x USB 3.0 (DC 5V MAX 900mA)
1 x Ethernet RJ45
4 x HDMI 2.0a - HDCP2.2 (ARC, CEC, MHL 3.0)
1 x AV Cimposite in
1 x AV Component In
1 x Optical Audio Out (AAC/PCM/AC3/Dolby/DTS/DTS Neo2.5)
1 x Antena (RF) (female)
1 x CI+ 1.3
1 x RS.232C
Compatible Rec.2020 input
Invisible Connection
Due to the OneConnect box, the only two cables into the back of the TV are the optical OneConnect cable and a power cable. These can both be hidden behind panels. The OneConnect box and the TV each require a separate power cable.
Double tuners
DVB-T/T2/C/S/S2
DiSEqC version 1.0
PIP, PAP, PAT
Timeshift & PVR
MPEG2, MPEG4,HEVC H.265, VP9
Q9F
(Flat)
QE-88Q9F
QE-65Q9F
Q8C
(Curved)
QE-75Q8C
QE-65Q8C
QE-55Q8C
successor model KS8
no HFR
no HDMI 2.1
no DP 1.3
Yes?YesYes in internet video services, HDMI, USB port.
Conversion SDR/HDR
ST2084,
ST2086,
ST2094,
NoNoPlattform:
SoC:
Core architecture:
Instruction set:
Operating at up to
GPU:
OpenGL
RAM:
Total memory:
Available memory:
OS: Tizen 3.075"
RGB,
10-bit(?),
120/100Hz,
FRC,
Curvature 4200R
65"
RGB,
10-bit(?),
120/100Hz,
FRC,
Curvature 4200R
54,5"
RGB,
10-bit(?),
120/100Hz,
FRC,
Curvature 4200R
Edge Led lighting from the bottom of the screen
12 Dimming blocks
WLED
MEMC
BFI - ?
PWM - Yes
--White balance - 2/20 points
CMS
White Balance dE:
Color dE:
Gamma:
75"
DCI/P3 xy - %
DCI/P3 uv - %
Rec.2020 xy - %
Rec.2020 uv - %
65"
DCI/P3 xy - %
DCI/P3 uv - %
Rec.2020 xy - %
Rec.2020 uv - %
55"
DCI/P2 xy - %
DCI/P3 uv - %
Rec.2020 xy - %
Rec.2020 uv - %
75"
65"
75" -
65" -
APL
5% - cd/m2 (Vivid mode) - in HDR
10% - cd/m2 (Vivid mode) - in HDR
75" -
75" -
75" -
75" -
75" -
65" -
65" -
65" -
65" -
65" -
75"
H&V - °
Color Shift -
Brightness -
Black Level -
65" - °
75" -
65" -
75"- HDR
75"- Game mode
75"- by dafault
65"- HDR
65"- Game mode ms
65"- by default ms
65" -
55" - 60W (20W x 2 + Woofer 10W x 2 )(4ohms)
Front Firing (4.2CH)
Dolby Digital Plus,
Dolby Puls,
DTS Premium Sound 5.1,
Image formats:
Video formats:
Audio formats:
Subtitles formats:
Wi-Fi
802.11 a,
802.11 b,
802.11 g,
802.11 n,
802.11 n 5GHz,
802.11 ac,
WiFi Direct
DLNA
Blietooth
2 x USB 2.0 (DC 5V MAX 500mA) - [HID support]
2 x USB 3.0 (DC 5V MAX 900mA)
1 x Ethernet RJ45
4 x HDMI 2.0 - (ARC, CEC, MHL 3.0)
1 x Satelite In (Main: F-type female)
1 x Satelite In (Sub: F-type female)
1 x SCART
1 x AV Composite In
1 x AV Component In
1 x Optical Audio Out (AAC/PCM/AC3/Dolby/DTS/DTS Neo 2.5)
1 x 3.5mm Audio Out
1 x CI+, (Version 1.3)
1 x RS.232C
CompatibleRec.2020 input
Invisible connection
Double tuners
DVB-T/T2/C/S/S2
DiSEqC version 1.0
PIP, PAP, PAT
Timeshift & PVR
MPEG2, MPEG4, HEVC H.265,
VP9
Q8C
(Curved)
QE-75Q8C
QE-65Q8C
QE-55Q8C
Q7C
(Curved)
QE-65Q7C
QE-55Q7C
QE-49Q7C
successor model KS7
no HFR
no HDMI 2.1
no DP 1.3
Conversion SDR/HDR
ST2084,
ST2086,
ST2094,
No
NoPlattform:
SoC:
Core Architecture:
Instruction set:
Operating at up to:
GPU:
Open GL
RAM:
Total memory:
Available memory:
OS: Tizen 3.064.5"
3840x2160,
RGB,
10-bit(?),
120/100Hz,
FRC,
Curvature 4200R
54,5" - QDCF-MVA (Samsung Display), 3840x2160, RGB,
10-bit(?), 120/100Hz,
Curvature 4200R
Model: ()
48.5"
RGB,
10-bit(?),
120/100Hz,
FRC,
Curvature 3000R
(6 zone)
12Dimmingblocks
CMS
White Balance dE:
Color dE:
Gamma:
55"
DCI/P3 xy - %
DCI/P3 uv - %
Rec.2020 xy - %
Rec.2020 uv - %
49"
DCI/P3 xy - %
DCI/P3 uv - %
BT.2020 xy - %
BT.2020 uv - %
55"
49"
55"
49" -
APL -
55" -
49" -
55" -
55" -
55" -
55" -
55" -
49" -
49" -
49" -
49" -
49" -
55"
H&V - °
Color Shift -
Brightness -
Black Level -
49"
H&V - °
Color Shift -
Brightness -
Black Level -
55" -
49" -
55"- HDR - ms
55"- Game mode - ms
55"- by default - ms
49"- HDR - ms
49"- Game mode -
49"- by dafault
? W (4ohms)
Dolby Plus,
Dolby Puls,
DTS,
Image formats:
Video formats:
Audio formats:
Subtitles formats:
Wi-Fi
802.11 a,
802.11 b,
802.11 g,
802.11 n,
802.11 n 5GHz,
802.11 ac,
Wi-Fi Direct
DLNA
Bluetooth
1 x Ethernet RJ45
1 x AV Cimposite in
1 x AV Component In
1 x RS.232
Double tuners
DVB-T/T2/C/S/S2
DiSEqC version 1.0
PIP, PAP, PAT
Timeshift & PVR
MPEG2, MPEG4,
HEVC H.265
VP9
Q7C
(Curved)
QE-65Q7C
QE-55Q7C
QE-49Q7C
Q7F
(Flat)
QE-75Q7F
QE-65Q7F
QE-55Q7F
QE-49Q7F
successor model KS7
no HFR
no HDMI 2.1
no DP 1.3
Conversion SDR/HDR
ST2084,
ST2086,
ST2094,
No
NoPlattform:
SoC:
Core Architecture: Quad
Instruction set:
Operating at up to:
GPU:
Open GL
RAM:
Total memory:
Available memory:
OS: Tizen 3.074.5"
3840x2160,
RGB,
10-bit,
120/100Hz
64.5"
RGB,
10-bit,
120/100Hz
54.5"
3840x2160,
RGB,
10-bit,
120/100Hz,
Flat
48.5"
QDCF-MVA, 3840x2160,
RGB,
10-bit,
120/100Hz,
Flat
12 Dimming blocks
WLED
MEMC
PWM - Yes
Vertical blooming is visible when there is a bright highlight. Note that on the Q7F, the local dimming cannot be totally turned off, the minimum setting is 'Low'.
Maximum Temperature: 46 °C
Average Temperature: 38 °C
Gray Uniformity
50% Std. Dev.: 3.955 %
50% DSE: 0.147 %
5% Std. Dev.: 0.778 %
5% DSE: 0.106 %
Black Uniformity
Std. Dev.: 1.618 %
Image Retention: 0%
Response Time: 9.9 ms
Overshoot: 0 ms
PWM Dimming Frequency: 120 Hz
BFI: No
BFI Frequency: 120 Hz
BFI In Game Mode: No
Motion Interpolation (30 fps): Yes
Motion Interpolation (60 fps): Yes
Reflection: 0.4 %
Screen Finish: Glossy
CMS
White Balance dE: 0.31
Color dE: 1.64
Gamma: 2.21
The calibration process is relatively easy to do with the 2 points, 10 points and color management system provided. With those tools, the white balance dE was brought down to a negligible 0.31 dE, which is excellent. The gamma value did not change too much (from 2.28 to 2.21), but the gamma tracks the 2.2 target much closer. The color error was brought down considerably, but even then the cyan is still a bit less precise than the other colors.
55" -
DCI/P3 xy - 99.00%
DCI/P3 uv - 99.27%
Rec.2020 xy - 73.52%
Rec.2020 uv - 77.19%
49"
DCI/P3 xy - %
DCI/P3 uv - %
Rec.2020 xy - %
Rec.2020 uv - %
55"
Normalized DCI P3 Coverage: 86.341 %
10,000 cd/m² DCI P3 Coverage: 57.257 %
Normalized Rec 2020 Coverage: 69.545 %
10,000 cd/m² Rec 2020 Coverage: 46.116 %
49"
This color volume is good, with slightly better performance than the B6, C6 and E6 and noticeably better performance than the Samsung KS* TVs of 2016. The TV can produce saturated colors especially at higher brightness. The darker colors cannot get as saturated as OLED TVs though.
55" - SDR results are for Movie mode calibrated to 6500k;
Real Scene Peak Brightness: 195 cd/m2
Peak 2% Window : 409 cd/m2
Peak 10% Window : 918 cd/m2
Peak 25% Window : 508 cd/m2
Peak 50% Window : 317 cd/m2
Peak 100% Window : 105 cd/m2
Sustained 2% Window : 284 cd/m2
Sustained 10% Window : 490 cd/m2
Sustained 25% Window : 468 cd/m2
Sustained 50% Window : 317 cd/m2
Sustained 100% Window : 104 cd/m2
49" -
APL -
55" - HDR results are for Movie mode calibrated to 6500k;
Real Scene Peak Brightness: 359 cd/m2
Peak 2% Window: 598 cd/m2
Peak 10% Window : 782 cd/m2
Peak 25% Window: 599 cd/m2
Peak 50% Window: 405 cd/m2
Peak 100% Window: 362 cd/m2
Sustained 2% Window : 376 cd/m2
Sustained 10% Window: 504 cd/m2
Sustained 25% Window: 516 cd/m2
Sustained 50% Window : 361 cd/m2
Sustained 100% Window: 362 cd/m2
49" -
APL -
ABL -
55" - 5020:1
55" -
55" -
55" - 100.4 cd/m2
55" - 0.020 cd/m2
This is slightly worse than the KS* TVs of 2016.
49" -
49" -
49" -
49" -
49" -
55"
H&V - 59°/
Color Shift - 27°
Brightness - 35°
Black Level - 25°
49"
H&V - °
Color Shift -
Brightness -
Black Level -
55" -
49" -
55"
1080p @ 60Hz: 24.3 ms
1080p With Interpolation : 79.5 ms
1080p @ 60Hz Outside Game Mode: 79.4 ms
1080p @ 60Hz @ 4:4:4: 20.2 ms
4k @ 60Hz: 24.2 ms
4k @ 60Hz @ 4:4:4: 20.3 ms
4k @ 60Hz + HDR: 24.4 ms
49"
The Q7F has low input lag in game mode which is great, and should be good enough for all but the most competitive gamers. The lowest input lag was actually found in PC mode, as seen in our 4:4:4 color tests; however it's only 4 ms lower than game mode which is not significant.
Note: The game mode setting has moved into 'General' > 'External Device Manager'.
40 W (4ohms)
2,2 chanels
Woofer
Dolby Digital Plus,
Dolby Digital Puls,
DTS,
Bluetooth Audio,
FAT16, FAT 32, NTFS and exFAT
Video Codec
H.264 BP/MP/HP, HEVC (H.265 - Main, Main10), Motion JPEG, MVC, Divx 3.11/4/5/6, MPEG4 SP/ASP, Window Media Video v9(VC1), MPEG2, MPEG1, Microsoft MPEG-4 v1/v2/v3, Window Media Video v7(WMV1)/v8(WMV2), H 263 Sorrenson, VP6, VP8, VP9, RV8/9/10 (RV30/40)
Audio Codec
MPEG1 Audio Layer 3, MPEG4/AAC, FLAC, OGG/Vorbis, WMA, wav, midi, ape, AIFF, ALAC
Container
AVI, MKV, ASF, MP4, 3GP, MOV, FLV, VRO, VOB
File transfer
avi, mkv, asf, wmv, mp4, mov, 3gp, vro, mpg, mpeg, ts, tp, trp, mov, flv, vob, svi, m2ts, mts, divx, webm, rmvb, mp3, m4a, mpa , Aac, flac, ogg, wma, wav, mid, midi, ape, aif, aiff, m4a
Wi-Fi
802.11 a,
802.11 b,
802.11 g,
802.11 n,
802.11 n 5GHz,
802.11 ac,
Wi-Fi Direct
DLNA
Bluetooth
1080p @ 60Hz @ 4:4:4: Yes
1080p @ 120Hz: No
4k @ 30Hz @ 4:4:4: Yes
4k @ 60Hz : Yes
4k @ 60Hz @ 4:4:4: Yes
All tested resolutions worked except for 120 Hz input. To show 4k @ 60 Hz @ 4:2:2 or 4:4:4 color 'HDMI UHD color' needs to be enabled. To show 4:4:4 color properly the TV needs to be in PC mode. HDR was not supported in PC mode; the TV displayed that it was showing HDR but the picture was clearly not HDR because it was still using the gamma curve and not the PQ curve.
1 x Ethernet RJ45
1 x AV Cimposite in
1 x AV Component In
1 x RS.232
15 meters optical cable - Invisible Connection
Double tuners
DVB-T/T2/C/S/S2
DiSEqC version 1.0
PIP, PAP, PAT
Timeshift & PVR
MPEG2,
MPEG4,
HEVC H.265, (Only for S2 & T2)
VP9
Q7F
(Flat)
QE-75Q7F
QE-65Q7F
QE-55Q7F
QE-49Q7F
JL_?
19 September 2008
15,415
Terra
Μα δύο χαλασμένες; Τί γκαντέμηδες είναι αυτοί; :laugh:
Μπράβο στα παιδιά, εκτός από την εξαιρετική δουλειά με τις μετρήσεις και την αντικειμενική καταγραφή, πολύ θετικό και το ότι δεν προμηθεύονται δείγματα από τις εταιρείες, αλλά αγοράζουν οι ίδιοι τις συσκευές... :a0210:
Ducksong
11 July 2013
4,985
The Dutch Mountains
Δεν είναι ακόμα βέβαιο ότι είναι ατυχία.. Τα site λαμβάνουν επιλεγμένα δείγματα, ίσως τα δικά τους αποτελέσματα είναι πιο κοντά στο τι αγοράζουμε εμείς :p
Εχει ξεφύγει το rtings! Οχι μόνο αγοράζουν τις συσκευές, αλλά δεν παρουσιάζουν συσκευές απο rma για την αποφυγή "επεμβάσεων" και προτιμούν να αγοράζουν 2ο ίδιο δείγμα :worshippy:
