SONY VPL-VW300
spcav
18 August 2006
16,616
Χωρις δυναμική ιριδα βλεπω...
Sony χωρις δυναμική ιριδα; Χλωμο για καλό μαύρο....
xavito
29 October 2008
8,989
[presscentre.sony.eu]...Sony VPL-VW300ES press release...http://presscentre.sony.eu/pressreleases/sony-announces-its-vpl-vw300es-projector-to-bring-true-4k-home-cinema-to-a-wider-audience-1049365
source:[hdlandblog.com]
[cine4home.de]...Sony VPL-VW300ES first test...http://www.cine4home.de/tests/projektoren/Sony_VPL-VW300/sony_vpl-vw300_test.htm
μετάφραση google de to en
[hdlandblog.com]...Sony VPL-VW300ES: first tests...http://www.hdlandblog.com/2014/09/sony-vpl-vw300es-premiers-tests.html
μετάφραση google fr to en
Αρχική ενδεικτική τιμή: 7000
Διαθεσιμότητα:Οκτώβριος 2014
Babis K.
28,718
Φτιάχνει προβολείς θηρία όμως η SONY... Κατασκευαστικά δείχνουν μια ποιότητα. :a0210:
spcav
18 August 2006
16,616
Re: Απάντηση: SONY VPL-VW300
Νταξ, Epson δεν είναι παντως....:p
xavito
29 October 2008
8,989
[hdtvtest.co.uk]...Sony VPL-VW300ES review...http://www.hdtvtest.co.uk/news/vplvw300es-201412033953.htm
Conclusion
We wanted to call the Sony VPL-VW300ES class-leading, but that wouldn’t be entirely accurate, because at this time of writing, there’s not even a non-Sony home theatre projector on the market capable of delivering true 4K resolution. And when you consider that its closest 4K competition – ironically Sony’s own step-up VPL-VW500ES model – costs £3,000 more in price, it really drives home the point that the VW300 stands peerless in a class of its own.
4K Ultra HD aside, the VW300ES excels with 1920x1080 Blu-ray films, live sports broadcast and video games. Its black level doesn’t go as deep as the JVCs (which, we must stress, is still not native 4K), but the VPLVW300ES more than makes up for it with its brightness and punchiness, the sheen of silkiness afforded by genuine 4K res, as well as all-round versatility.
We firmly expect the same scenario between the Sony VPL-HW40ES and VPL-HW55ES to play out: the frankly marvellous VPL-VW300ES will likely cannibalise sales of the higher-end VPL-VW500ES, with most buyers happy to swap the inclusion of dynamic iris for a chunk of spare change in their pockets.
emperor
2 February 2008
680
Main Listening Position NYC
Κύριε Καστρουνη, γνωρίζοντας την εμπειρία σας θα ήθελα να σας ρωτήσω τα παρακάτω ως πρόβλεψη:
Οι προβολείς που αναφέρεται ειναι πανάκριβοι όταν το entry level αυτών ξεκινάει από τα 7000 $, ποσό μάλλον για τα καλύτερα μοντέλα. Υλικό δεν υπάρχει βέβαια ακόμη εκτός από ελάχιστες ταινίες στο Netflix & sony network.
Ποτε κατα την εκτίμηση σας, θα έχουμε τιμές στα 4k σε νορμαλ τιμές; Δηλαδή σε επίπεδα κάτω των 2000 στις πιο φτηνές κατηγορίες; Επίσης ποτέ νομίζετε ότι θα υπάρχει αξιόλογο υλικό για να μεταπηδησουμε σε κάτι τέτοιο;
Θυμάμαι από τα 1080 ότι είχα πάρει τηλεόραση το 2003 πληρώνοντας ένα απίθανο ποσό για να βλέπω demo από το pc και μόλις 4-5 χρόνια αργότερα άρχισα να εκμεταλλεύομαι δειλά δειλά το bluray. Προβλέπεται αντίστοιχα και εδώ το ίδιο; Θα πάμε δηλαδή σε μια πενταετία όπου όλοι θα αρχίσουν να πουλάνε αλλά δεν θα υπάρχει υλικό;
Ευχαριστώ.
3,031
Απάντηση: Re: SONY VPL-VW300
Ευχαριστώ.
Καλημέρα σας.
Το 4Κ είναι ακόμη στα σπάργανα του και, μέχρι στιγμής, για τους προβολείς μόνο μιλάμε, η Sony είναι η μοναδική που το υποστηρίζει. Στην CES παρουσιάστηκαν τα specification για το 4K BLU RAY. Άποψή μου είναι ότι θα αργήσουμε να δούμε και άλλους κατασκευαστές να ακολουθούν σχετικά γρήγορα. Εάν θα μπορούσα να κάνω μια πρόβλεψη δεν το βλέπω πριν το τέλος του χρόνου. Υπάρχει μεγάλος κίνδυνος προβολείς 4Κ να μην μπορέσουν να παίξουν αμιγώς υλικό 4Κ λόγω HTCP και συμβατότητας.
Η κατηγορία των προβολέων με ανάλυση 4Κ τουλάχιστον για αρχή θα θεωρείται η HI- END κατηγορία, σαν τιμολογιακή πολιτική. Μην ξεχνάμε ότι μόνο μια εταιρία αυτήν την στιγμή έχει 4Κ με την JVC να έχει ένα ερμαφρόδιτο 4Κ. Άρα θα πρέπει να άλλη παίκτες να μπουν στο παιχνίδι για να ανακατευτεί η τράπουλα. Αυτό που περιμένω με ανυπομονησία είναι η απάντηση της Ti. Δεν έχει δώσει ακόμη κάποια σημάδια σχεδίων της.
