Sony XR X90K/X93K/50X90S : Reviews - Εντυπώσεις - Σχόλια
kmeles
16 January 2010
22
XR-55X90K,Την αγορασα με απαλλαγή φπα πριν αρχισουν οι εκπτωσεις απο public .
Τωρα δεν ξερω εαν εκανα καλα και προτίμησα την Κ απο τη J,απλα την J δεν την ειχανε στις 55 ίντσες.
VA panel,RGB,vertical stripe,8 domain
Direct LED LCD,Full Array Local Dimming
65": 54 dimming zones in a 6x9 array
100/120Hz με MCFI+black zonal insertion
Cognitive Processor XR 2nd gen
Συμβατότητα HDR formats: HDR10,HLG,TV-led Dolby Vision :yes
(HDR10+ : no)
Dolby Atmos,DTS,DTS:X via DTS-HD MA via eARC
SoC
Model: BRAVIA 4K VH21
MediaTek MT5895
Core Architecture:4x ARM Cortex-A73 @ 1800MHz
64-bit ARMv8-A (32-bit mode)
CPU Cores: 4
CPU Clock Range: 1200 - 1800MHz
Installed RAM : 3 GB
Available Memory: 935 MB
GPU Renderer : ARM Mali-G52 (Vulkan)
OpenGL ES version: 3.2
Total storage-On-board Storage : 16GB - expandable via USB
Internal Storage Total Space: 4185 MB
Internal Storage Free Space: 2112 MB
Sony X90K CPU_GPU benchmark flapanelshdcom
Πλάτος βάσης (Περίπου) (cm)
Τυπική θέση:
XR-85X90K: 156,7
75X93K / 75X90K: 136,1
65X93K / 65X90K: 117,4
55X93K / 55X90K: 102,7
Περιορισμένη θέση:
XR-85X90K: 60,1
75X93K / 75X90K: 50,9
65X93K / 65X90K: 43,4
55X93K / 55X90K: 42,4
Θέση sound bar:
XR-85X90K: 156,7
Difference between X90K and X93K/X94K/X92K:
1)In the X94K/X93K series, a microphone is built into the screen. You can give a voice command without speaking directly to the remote control with built-in microphone
2)The X94K/X93K series uses a "Blade" aluminum base and the X90K series uses a standard slim "Blade" base .
3)The X94K/X93K Series features Rich Color Enhancer technology, which enhances neutral colors to more vivid tones to give the image extra clarity.
This happens automatically and this function is not visible in the settings to enable or disable it .
4)The X92K series uses a very narrow stand that allows you to safely place the TV on a very narrow piece of furniture
Sony 65X90K teardown (chinese market)...https://avclub.gr/index.php?threads/sony-tv-line-up-2022.176330/post-1058821787
Υποδοχές:
HDMI IN x4 (eARC/ARC port3)
USB x2 : 3.1gen+ usb 2.0
USB drive format support :FAT16/FAT32/exFAT/NTFS
Digital audio out x1 (optical)
Είσοδος composite-AV/ S-Centre speaker input x1 (mini-jack υποδοχή),adapter not included
Έξοδος ακουστικών : όχι
Ethernet (LAN) x1: 10BASE-T/100BASE-TX
Wi-Fi :802.11 a/b/g/n/ac
S Center speaker IN x1 mini-jack 3.5mm : 50X90S : όχι
Bluetooth : version 4.2,HID,HOGP,SPP,A2DP,AVRCP
DVB-T2 HD (H.265/HEVC),DVB-S2 x2
Εγγραφή τηλεοπτικών προγραμμάτων : ναι ,από 64 GB και πάνω.
Υποστηρίζει υβριδική τηλεόραση HbbTV
IMAX enhanced television,Netflix Calibrated Mode
50X90S,X90K : BRAVIA Core streaming support: 5 ταινίες για εξαργύρωση και 12 μήνες απεριόριστης ροής
X93K : Bravia Core streaming support: 10 ταινίες για εξαργύρωση και 24 μήνες απεριόριστης ροής
CalMAN auto calibration mode
Google Home,Google Assistant, Amazon Alexa,Apple AirPlay2 and HomeKit,Chromecast built-in
Εφαρμογή Video & TV SideView για iOS και Android, με δυνατότητα αντικατάστασης του τηλεχειριστηρίου
X90K: 2 remotes : new Voice Remote Bluetooth: RMF-TX800U + standard remote υπερύθρων RMT-TX440E
Προαιρετικά : Bravia Cam ή άλλη web cam,
Επίσημα υποστηριζόμενες κάμερες (USB streaming):
Sony CMU-BC1,ZV-1,DSC-RX0M2
Logitech (κάμερες):BRIO,C920,C920s
Υποστήριξη X90K...https://www.sony.gr/electronics/support/televisions-projectors-lcd-tvs-android-/xr-65x90k
Οδηγός βοήθειας X90K...https://helpguide.sony.net/tv/jaep1/v1/el/index.html
Οδηγός αναφοράς X90K...https://www.sony.com/electronics/su...9e540e72723e9a4b08126b1a7331fb2/50377111M.pdf
Λήψεις X90K...https://www.sony.gr/electronics/support/televisions-projectors-lcd-tvs-android-/xr-65x90k/downloads
Τρόπος επαναφοράς, επανεκκίνησης ή επαναφοράς του Android TV ή του Google TV στις αρχικές εργοστασιακές ρυθμίσεις...https://www.sony.com/electronics/support/articles/00159487
Sony Pocket Guide app πρόσβαση στις πληροφορίες προϊόντων Sony:
Apple store : https://apps.apple.com/gr/app/sony-pocket-guide/id1566182094
Google Play store : https://play.google.com/store/apps/details?id=com.sony.pocketguide
Ενδεικτικές αρχικές τιμές για την X90K
XR-85X90K - 4.100 €
XR-75X90K - 2.800 €
XR-65X90K - 2.050 €
XR-55X90K - 1.650 €
XR-50X90S : 1.430 €
Reviews-test:
65"...[hdtvpolska]...Sony XR-65X90K review (sample)...https://hdtvpolska.com/test-recenzja-telewizor-sony-x90k-opinie-cena/?showfull=1
65"...[rtings.com]...Sony XR-65X90K review...https://www.rtings.com/tv/reviews/sony/x90k
Οι ρυθμίσεις είναι μόνο για αναφορά.
Δεν υπάρχει καμία εγγύηση ότι θα σας δώσουν την καλύτερη εικόνα που είναι σύμφωνη με τα πρότυπα της βιομηχανίας και κατάλληλη για το περιβάλλον προβολής σας (ειδικά ισορροπία λευκού, ρυθμίσεις συστήματος γάμμα και χρώματος που διαφέρουν από μονάδα σε μονάδα).
Εάν θέλετε μια εγγυημένη βαθμονομημένη εικόνα, καλέστε έναν επαγγελματία βαθμονομητή τηλεόρασης.
Calibration settings... https://www.rtings.com/tv/reviews/sony/x90k/settings
65"...[homecinema-fr.com]...Sony XR-65X94K test...https://www.homecinema-fr.com/test-hcfr-televiseur-lcd-sony-xr-65x90k/
65"...[athinorama.gr]...Sony XR-65X90K review...https://www.athinorama.gr/digital/homecinema/article/sony_bravia_65x90k-2552992.html
65"...[geex.x-kom.pl]...Sony XR-65X90K review...https://geex.x-kom.pl/recenzje/test-i-recenzja-sony-65x90k/
two leg spacing: 446 or 1173 mm (although the manufacturer does not inform about it, asymmetrical leg settings are also possible, if someone likes them).
I identified 6 zones horizontally and 9 vertically, for a total of 54 independent zones.
HDR:In User mode on the board 10%, the maximum luminance after three minutes of measurement was stable and amounted to 971 cd/m² (nits).
I would like to point out that on the white full-screen board, the 65X90K shines with a luminance of 673 cd/m² (nits).
To set the optimal brightness level for a home cinema (i.e. to a completely darkened room), it is enough to set the "brightness" option to only "3" of the available "50", which will give a reference 120 cd/m² (nits). I repeat: already 3/50 gives cd/m² (nits). And that's what proof of how bright the 65-inch Bravia of the X90K series is.
65"...[rtvmaniak.pl]...Sony XR-65X90K review...https://www.rtvmaniak.pl/9617285/test-sony-x90k/
65"...[tomsguide.fr]...Sony XR-65X94K review...https://www.tomsguide.fr/test-bravi...tiquee-des-tv-lcd-sony-a-retro-eclairage-led/
kmeles
16 January 2010
22
Υπάρχουν πουθενά ρυθμίσεις για την Τν?
δεν την έχω ψάξει και πολύ λόγο έλλειψης χρόνου.
SWISSTEC
26 July 2007
1,366
ΠΕΙΡΑΙΑΣ
υπάρχουν κάποιες ρυθμίσεις στο σχετικό νήμα του forum για αυτό το μοντέλο. Βέβαια για ποιο επαγγελματικές ρυθμίσεις που αλλάζουν την εικόνα έχει όνομα ΜΑΝΩΛΗΣ ΚΑΣΤΡΟΥΝΗΣ.
Αντωνης Β
2,526
Υπάρχουν πουθενά ρυθμίσεις για την Τν?δεν την έχω ψάξει και πολύ λόγο έλλειψης χρόνου
kmeles
16 January 2010
22
Μπορουμε να συνδεσουμε δορυφορικο πιατο στην τν παιδια??
zerone
16 February 2016
37
Παιδιά καλησπέρα,
Σήμερα παρέλαβα την 55X90K.
zerone
16 February 2016
37
Τελικά άνοιξα την (XR-55X90K) συσκευασία , αφού με διαβεβαίωσαν από το κατάστημα πως δεν έχει ανοιχτεί.
Οι εντυπώσεις μου είναι θετικές.
Όσον αφορά το blooming, είναι διαχειρίσιμο & όπως είπε ο stempi δεν έχει καμία σχέση με αυτό που φαίνεται στη φωτογραφία.
Το μόνο αρνητικό είναι ένας ήχος υψηλής συχνότητας (μάλλον από τον μετασχηματιστή) που ακούγεται όταν η τηλεόραση είναι στο mute & υπάρχει ησυχία στο δωμάτιο, ειδικά όταν η φωτεινότητα είναι στο max.
Ευχαριστώ για τις συμβουλές.
Haris1977
9 May 2011
900
Καλησπέρα
Ξέρει κάποιος να μας πει στα σίγουρα αν η XR-65X90K έχει α) usb recording και β) hbbtv?
Διότι στα επίσημα specs δεν τα λέει
Ευχαριστώ!
https://www.sony.gr/electronics/tileoraseis/x90k-x93k-x94k-series/specifications
Εγγραφή τηλεόπτικών προγραμμάτων...https://helpguide.sony.net/tv/jaep1/v1/el/03.html
Στην usb 2 γράφει HDD REC
Όλες οι Sony από το 2015 που συνδέονται στο internet υποστηρίζουν υβριδική τηλεόραση Hbbtv.
Haris1977
9 May 2011
900
Mόλις μου απάντησαν και επίσημα από την sony hellas.
Το μόνο κακό είναι πως δεν έχω βρει ακόμα κάποια tv με 2-πλό tuner (για να μπορώ να γράφω οποιοδήποτε κανάλι ενώ να βλέπω ταυτόχρονα όποιο άλλο θέλω)
Σ ευχαριστω φίλε!
