Σταθεροποίηση Κάμερας - Camera gimbals and stabilizers
Kosh
7 September 2006
91,162
Εκεί ψηλά.....
evanfotis
26 March 2008
5,475
Τώρα αυτό είναι Software Stabilizing, δε ξέρω αν χρήζει νήμα σε άλλη κατηγορία.
Βγήκε η έκδοση 1.2 με υποστήριξη Braw! Dji Avata etc...
Features​
  • Real time preview, params adjustments and all calculations
  • GPU processing and rendering, all algorithms fully multi-threaded
  • Rolling shutter correction
  • Supports already stabilized GoPro videos (captured with Hypersmooth enabled) (Hero 8 and up)
  • Supports and renders 10-bit videos (up to 16-bit 4:4:4:4 for regular codecs and 32-bit float for OpenEXR - works directly on YUV data to keep maximum quality)
  • Customizable lens correction strength
  • Render queue
  • Keyframes
  • Ability to create custom settings presets
  • OpenFX plugin (eg. for DaVinci Resolve), which allows you to apply stabilization in video editor without any transcoding
  • Visual chart with gyro data (can display gyro, accel, magnetometer and quaternions)
  • Visual display of smoothed quaternions
  • Modern responsive user interface with Dark and Light theme
  • Adaptive zoom (dynamic cropping)
  • Support for image sequences (PNG, OpenEXR, CinemaDNG)
  • Based on telemetry-parser - supports all gyro sources out of the box
  • Gyro low pass filter, arbitrary rotation (pitch, roll, yaw angles) and orientation
  • Multiple gyro integration methods for orientation determination
  • Multiple video orientation smoothing algorithms, including horizon levelling and per-axis smoothness adjustment.
  • Cross-platform - currently works on Windows/Linux/Mac, with Android and iOS apps coming
  • Multiple UI languages
  • Supports variable and high frame rate videos, all calculations are done on timestamps
  • H.264/AVC, H.265/HEVC, ProRes, DNxHD, PNG and OpenEXR outputs, with H.264 and H.265 fully GPU accelerated (ProRes also accelerated on Apple M1 Pro/Max/Ultra)
  • Automatic lens calibration process
  • Fully zero-copy GPU preview rendering (working but experimental)
  • Core engine is a separate library without external dependencies (no Qt, no ffmpeg, no OpenCV), and can be used to create OpenFX and Adobe plugins (on the TODO list)
  • Automatic updates of lens profile database
  • Built-in official lens profiles for GoPro: HERO 6, 7, 8, 9, 10; RunCam: Thumb, ThumbPro, 5 Orange; Insta360: GO 2 in all shooting modes
Supported gyro sources​
  • GoPro (HERO 5 and later)
  • Sony (a1, a7c, a7r IV, a7 IV, a7s III, a9 II, FX3, FX6, FX9, RX0 II, RX100 VII, ZV1, ZV-E10)
  • Insta360 (OneR, OneRS, SMO 4k, Go, GO2, Caddx Peanut)
  • DJI Avata
  • Blackmagic RAW (*.braw)
  • RED RAW (*.r3d)
  • Betaflight blackbox (*.bfl, *.bbl, *.csv)
  • ArduPilot logs (*.bin, *.log)
  • Gyroflow .gcsv log
  • iOS apps: Sensor Logger, G-Field Recorder, Gyro
  • Android apps: Sensor Logger, Sensor Record
  • Runcam CSV (Runcam 5 Orange, iFlight GOCam GR, Runcam Thumb, Mobius Maxi 4K)
  • Hawkeye Firefly X Lite CSV
  • WitMotion (WT901SDCL binary and *.txt)
Info for cameras not on the list​
  • For cameras which do have built-in gyro, please contact us and we will implement support for that camera. Refer to the documentation for information about the gyro logging process.
  • For cameras which don't have built-in gyro, please consider using Betaflight FC or check out our flowshutter project.
v1.2.0
✨ Improvements​
  • New gyro sources: DJI Avata, Blackmagic RAW (.braw), RED RAW (.R3D), Ardupilot binary log (.bin)
  • Horizon lock actually locks the horizon now 🚀
  • Blackmagic RAW (.braw) direct video playback
Highpriest
28 January 2023
417
Αν έχεις φυσικά και gimbal του βάζεις να κάνει πανοραμικό πόσες λήψεις θέλεις και χώρο που θα καλύψει και έχεις μεγαλύτερο αρχείο με περισσότερες επιλογές κροπ από μια λήψη με ευρυγώνιο…
Δεν έχω Gimbal, αλλά είναι στις προσεχείς αγορές. Ολο και περισσότερο βρίσκω πως χρειάζομαι ένα.
Κάποιο youtube link με κάποιο αξιόλογο gimbal που να δείχνει και μια τέτοια λειτουργία υπάρχει;
evanfotis
26 March 2008
5,475
Σίγουρα τα Ronin Rs2 και για πιο μικρό rsc2 και οι 3η βερσιον τους,
Και έβγαλε τώρα ένα για ακαθρέπτες η hohem που κάνει παπάδες
Reactions: Highpriest
Highpriest
28 January 2023
417
H αλήθεια είναι πως δεν έχω ασχοληθεί καθόλου με gimbal, επειδή για την ώρα δεν κάνω καθόλου βίντεο.
Σκεφτόμουν (φωτογραφικά) σε τρίποδο, στήσιμο σε μια γωνία, portrait mode (για να πάρω όσο το δυνατόν παραπάνω ταβάνι και πάτωμα) και τράβηγμα διαδοχικές λήψεις τύπου πανοράματος ανα μισό κάδρο και μετά δέσιμο.
Στα 24mm υπολόγισα πως θα χρειαστώ περίπου 4-6 φώτο.
Με gimbal λογικά (απο τα λίγα βιντεάκια που είδα) θα γίνεται ευκολότερα, και έχει και όλες τις έξτρα λειτουργίες για βίντεο.
Βέβαια (και πάλι απο τα λίγα που είδα) είναι ψιλοχάσιμο η φάση. Δεν ξέρεις ποιο να πρωτοδιαλέξεις.
Ποιο θεωρείται καλό VFM και να μπορεί να σηκώνει βάρος Mirrorles Full Frame με αρκετά ογκώδη φακό;
Για να ξέρω απο ποιο και πάνω ξεκινάω να ψάχνω.
Highpriest
28 January 2023
417
Πολύ καλό, αλλά με 1.2 κιλά maximum load, με περιορίζει αρκετά.
Υ.Γ Ψάχνω ζυγαριά να αρχίσω τα ζυγίσματα...:LOL:
ΥΓ2. Οκ, τα ζύγισα. Με την Μ4/3 μου μπορώ, και με όλους τους φακούς. Αρα εκει υπάρχει μαι επιλογή.
Με την FF, πρέπει να γίνει σωστή επιλογή φακών. Με τον 24-70 f/4 πχ είναι στα 1.190 κιλά. Ακριβώς στο όριο. Δεν ξέρω στο ζύγισμα της τι επίπτωση μπορεί να έχει αυτό ή αν δίνουν και κάποιες ανοχές μέρα απο το 1.2 που αναφέρουν.
Highpriest
28 January 2023
417
Όσο μαθαίνω για αυτό το isteady MT2 διαπιστώνω πως πρόκειται για φανταστικό εργαλείο! Έχει ακριβώς όλα όσα θέλω να έχει ένα gimball. Ειδικά αυτό με το ενσωματωμένο tracking είναι εξαιρετικά χρήσιμο!
Μόνος μου ενδοιασμός είναι τα 1.2 κιλά που αντέχει. Κάνω σενάρια με συνδυασμούς σωμάτων και φακών που διαθέτω ή θέλω να πάρω και βλέπω πως με περιορίζει αρκετά.
Υπάρχει αντίστοιχη πρόταση με όλα αυτά τα features του isteady MT2 που να αντέχει έστω 1,5 κιλό; Ή ακόμη καλύτερα 2 κιλά;
evanfotis
26 March 2008
5,475
Οι κλασικές λύσεις DJI RSC2, RSC3 και για πιο μεγάλο payload RS2 & RS3 Pro.
Υπάρχουν κ τα Zhiyun Crane 3S κλπ που σηκώνουν περισσότερα κιλά και είναι σκυλιά.
Αλλά πρέπει να σταθμίσεις ανάγκες σου, ευκολίες προταιρεότητες...
Άλλα έχουν καλό λογισμικό, άλλα σηκώνουν κιλά και αντέχουν σε επαγγελματική χρήση, αλλά είναι μεγάλα και βαριά, άλλα θέλουν περισσότερο σετάρισμα... Θέλει ψάξιμο.
Reactions: Kosh and Highpriest
Highpriest
28 January 2023
417
Ευχαριστώ.
To isteady MT2 καλύπτει ακριβώς όλες τις ανάγκες μου. Εκτός απο το βάρος που μπορεί να σηκώσει.
Την σειρά της dji την έχω δει. Απο τα πιο φτηνά στα ακριβότερα. Στην κατηγορία τιμής του isteady MT2 δεν δίνουν το tracking. Το θεωρώ αρκετά σημαντικό feature για να το προσπεράσω.
stratigos24
30 January 2011
475
Για δώστε μια βοήθεια ρε παιδία γιατί χάθηκα.
Ψάχνω να πάρω ένα gimbal για την gopro 8. Τα διαθέσιμα στην ελλάδα που βρίσκω κοντά μου καθαρά για gopro είναι το Hohem isteady pro 3 και isteady pro 4 στα 137 ευρώ και 179 αντίστοιχα.
Βλέπετε κάποιο άλλο που να αξίζει?
Ακόμα, βλέπω κάτι βίντεο που πχ αυτός βάζει gopro/dji action κλπ σε mobile gimbal Hohem iSteady M6 και δουλεύει και τον κάνει tracking. Δουλεύει γενικά ή απλά δουλέυει όπως όπως με action camera απλά χαιρόμαστε με το tracking?
Έχετε άλλη εναλλακτική?
Μπορείς να βάλεις τη Gopro (έχω την 8) σε κάποιο mobile gimbal? Αν ναι τί κερδίζεις και τί χάνεις?
evanfotis
26 March 2008
5,475
Aφου λειτουργει με το Μ6 εγώ αυτο θα διάλεγα γιατί το χρησιμοποιείς και με κινητό, διπλή χρησιμότητα...
