Blackmagic Camera 7.8 Public Beta - Newsshooter
Blackmagic Design has released Blackmagic Camera 7.8 Public Beta. This offers support for live streaming on Blackmagic URSA Broadcast G2 direct to YouTube
www.newsshooter.com
Today we announced Blackmagic Camera 7.9.1 update for Blackmagic Pocket Cinema Cameras which includes improved reliability when recording in all formats to external USB-C media disks. In addition, this update improves the record button response which means you’ll be able to start and stop recording faster. Plus, there’s improved reliability when updating the camera software and it fixes an issue where Blackmagic RAW clips with a LUT applied may not preview correctly in camera.
This update also fixes an issue on the Blackmagic Pocket Cinema Camera 4K that prevented users from setting frame rates above 60 fps when shooting in the 4K 2.4:1 resolution. Frame rates up to 75 fps can now be selected allowing you to record smoother slow motion footage. Also, this update improves the accuracy of the motion sensor metadata recorded from the gyro sensor in the Blackmagic Pocket Cinema Camera 4K, improving the effectiveness of the stabilization feature in DaVinci Resolve 18.
Blackmagic Camera 7.9.1 update is available now as a free download from http://bmd.link/k3K7pL
Today we announced Cloud Store 1.0.3 update which adds support for synchronization with Google Drive. This means in addition to existing Dropbox sync, you can now set up a local cache of your Google Drive files. This makes them instantly available to anyone on your network without the need to download them from the internet each time. It also allows you to sync multiple Blackmagic Cloud Stores so people in different geographic locations can collaborate without latency because everyone has a local copy of the files.
This update also lets you open Finder windows and Windows Explorer directly from the Blackmagic Cloud Store utility, making it faster and easier to connect to your network as well as access files.
With improved stability, you also get better performance when moving files with extremely long names. Plus, it’s now easier synchronizing large directories with these same files, making for a smoother workflow.
Cloud Store 1.0.3 update is available now as a free download from http://bmd.link/NWA3x3
What's new in Blackmagic Camera 7.9.2
The following models have new features.
Blackmagic Camera Fiber Converter
- Improved streaming compatibility.
- Improved compatibility with some iPhone 12 models.
- Improved gain, shutter and white balance switch behavior.
- Improved codec response with LED walls.
- Adds support for writing motion sensor data to Blackmagic RAW recordings.
- Adds support for retaining presets and LUTs for future updates.
- General performance improvements.
- Compatibility improvements.
What’s new in Blackmagic RAW 2.6
- Adds support for Fujifilm XH2s Blackmagic RAW clips captured by Blackmagic Video Assist.
- Adds adjustable white balance and accuracy for Panasonic GH5S, BGH1.
- Improved white balance accuracy for Panasonic S1H, S1, S5, BS1H.
