Τεχνολογικά νέα, ανακοινώσεις .....από την Blackmagic Design
evanfotis
26 March 2008
5,475
Τη πιο καλή για μένα
Την original cinema camera 2.5κ δεν την έβαλε. Αυτή εισήγαγε τη bmd στο χώρο αυτό της λήψης και το χρώμα που έβγαζε ακόμα και σήμερα είναι καταπληκτικό, και φυσικά το form factor box body με ποιοτικά υλικά.
Kosh
7 September 2006
91,254
Εκεί ψηλά.....
ναι αλλα ηθελε τρελλο φως για να γραψει εκεινη η καμερα. Αν απεφευγα καποια απο ολες εκεινη θα ηταν.
Μην πω για την ανοησια με την εσωτερικη μπαταρια που δεν αλλαζε...
evanfotis
26 March 2008
5,475
Today we announced Blackmagic Camera 1.3 update which adds support for audio monitoring on connected earphones. This means you can now use your existing wired or bluetooth headphones to monitor your audio when shooting.
This update also adds rack focus controls in the camera so you can change the focus of the lens during a continuous shot. This allows you to gradually pull focus between 3 preset focus points in the foreground or background, giving you the ability to draw your audience’s attention to different elements and change the emphasis of a scene.
Blackmagic Camera 1.3 also adds support for 48mm lenses on iPhone 14 Pro and 15 Pro, allowing steady, easier zooming in on object. In addition, the interface will now smoothly animate when switching between landscape and portrait modes. There is also faster listing of projects in the media tab, reduced latency for HDMI video feeds, and the ability to display clip name, reel, scene and take details over an external HDMI monitor during recording.
Blackmagic Camera 1.3 update is available now as a free download from the Apple App
Store, free of charge at https://apps.apple.com/us/app/blackmagic-camera/id6449580241
Kosh
7 September 2006
91,254
Εκεί ψηλά.....
Bγηκε και νεο update για τις καμερουλες
About Blackmagic Camera Utility​
Welcome to the Blackmagic Camera Setup!​
This installer will add Blackmagic Camera Setup software to your system so you can update the software and manage your Blackmagic Camera. It also installs Blackmagic RAW Player, Blackmagic RAW Speed Test, Blackmagic RAW SDK and Blackmagic RAW plugins.
For updating Blackmagic Cameras from Camera 4.0 or above it is advisable to export your presets and LUT’s onto a card as they will be removed during this update.
What's new in Blackmagic Camera 8.6​
The following models have new features:
Pocket Cinema Camera 4K​
Pocket Cinema Camera 6K​
Pocket Cinema Camera 6K G2​
Pocket Cinema Camera 6K Pro​
Cinema Camera 6K​
  • Adds support for using camera as a webcam or UVC device.
  • Adds media pool file browser.
  • Adds clip deletion support.
  • Adds Blackmagic Cloud clip uploads.
  • Adds direct uploads to DaVinci Resolve projects.
  • Adds ability to update and manage camera via ethernet.
  • Adds REST control API for remote control.
  • Adds login and secure certificate support.
  • Adds network time protocol support.
  • Adds web media manager support.
  • Adds file transfer protocol support.
  • Adds SMB file sharing support.
  • Adds mobile phone tethering support for some models.
  • Improves gyro metadata reliability.
  • Improves USB-C drive detection reliability.
Kosh
7 September 2006
91,254
Εκεί ψηλά.....
Αν στοιχηματιζαμε εδω και μηνες τι νεα καμερα θα βγαλει πλεον η ΒΜ ηταν μια νεα Ursa
η 12k ειναι μια κατηγορια απο μονη της αλλα η 4.6k G2 ηθελε φρεσκαρισμα .
Και νομιζω οτι αυτη ακριβως ειναι η στοχευση με την Ursa Cine που βλεπουμε σε αφισα στο Λας Βεγκας.
υγ
να και η ανακοινωση για την σημερινη ζωντανη παρουσιαση
Live stream starts at Los Angeles 9 AM PDT, New York 12 PM EDT, London 5 PM BST on the 12th of April, and Singapore 12 AM SGT, Tokyo 1 AM JST, Sydney 2 AM AEST on the 13th of April.
Reactions: cacau
Kosh
7 September 2006
91,254
Εκεί ψηλά.....
Βρεχει καμερες ο Petty !!!
Kαινουργια 12k FF, 16 stops DR, ενσωματωμενο ssd εγγραφης στα 15000€
Καινουργια 6k box camera !!!!! ( επιτελους) FF σαν την komodo περιπου με 3 μοντουρες , ΕF, L , PL.
komodo killer θα ειναι η Pyxis 6k box FF οπως την λενε . Μολις στα μισα λεφτα απο την Komodo δηλαδη στα 3000€
Ρευση αεροπλανο βυσσινο :love:
Kosh
7 September 2006
91,254
Εκεί ψηλά.....
Σωστο αλλα η μια ειναι super35 και η αλλη FF.
Και τα μισα λεφτα.....
Η komodo μονο RF μοντουρα και με την Nikon απο πανω ......
Η Pyxis με 3 μοντουρες
