Τεχνολογικά νέα, καινοτομίες .... από τη Pentax - Ricoh
evanfotis
26 March 2008
5,475
Pentax K-3 Mark III με 1.6 million ISO
http://news.ricoh-imaging.co.jp/rim...1042881625.16 03812263-1970226206.1603812263
[/URL][h=3]Model Description[/h]
TypeTTL autofocus, auto-exposure SLR digital-still camera
Lens MountPENTAX KAF2 bayonet mount (AF coupler, lens information contacts, K-mount with power contacts)
Compatible LensKAF4, KAF3, KAF2 (power zoom compatible), KAF, KA mount lens
Image SensorPrimary color filter, CMOS. Size: 23.3 x 15.5 (mm)
Effective PixelsApprox. 25.73 megapixels
Total PixelsApprox. 26.78 megapixels
Dust RemovalImage sensor cleaning using ultrasonic vibrations "DR II"
Sensitivity
(Standard output)
ISO AUTO/100 to 1600000 (EV steps can be set to 1EV, 1/2EV or 1/3EV)
Image Stabilizer Sensor-shift shake reduction "SR II"(5-axis) Auto/Panning/Off
Compensation effect of 5.5 steps
*Measured in conformity to CIPA standards
AA Filter SimulatorMoiré reduction using SR unit. OFF/Low/High/Bracketing (2 images)/Bracketing (3 images)
[h=3]File formats[/h]
File formatRAW (PEF/DNG), JPEG (Exif 2.3), DCF2.0 compliant
Recorded Pixels JPEG:L(26M:6192x4128)、M(15M:4752x3168)、S(9M:3648x2 432)、XS(2M:1920x1280)
RAW:(26M:6192x4128)
Quality Level RAW (14bit): PEF, DNG
JPEG: ★★★ (Best), ★★ (Better), ★ (Good), RAW + JPEG simultaneous capturing available
Color SpacesRGB, AdobeRGB
Storage MediumSD, SDHC and SDXC Memory Card (Conforms to USH-I, UHS-II standards) * UHS-II supports slot 1 only
Dual SD slotSequential Use, Save to Both, Separate RAW/JPG, Image copy between slots possible
Storage FolderFolder Name: Date (100_1018,101_1019...) or User assigned folder name (Default "PENTX")
Recording File File Name: "IMGP****" or User assigned file name
File name numbering: Sequential, Reset
[h=3]Viewfinder[/h]
TypePentaprism Finder
Coverage (FOV)Approx. 100%
MagnificationApprox. 1.05x (FA 50mmF1.4 at infinity)
Eye-Relief LengthApprox. 20.5mm (from the view window), Approx. 22.0mm (from the center of lens)
Diopter adjustmentApprox. -4.0m to + 1.0m[SUP]-1[/SUP]
Focusing ScreenNatural-Bright-Matte III focusing screen
Viewfinder OverlayAF Points, Grid Display, Electronic Level, AF Frame, Spot Metering Frame, Crop, Smart Function, Operation Control Lock
[h=3]Live view[/h]
TypeTTL method using image sensor
Focusing
Mechanism
Contrast detection (Auto Area, Zone Select, Tracking, Select(L/M/S), Spot)
FunctionsFocus Peaking, Face detection, Touch AF
Display Field of View approx. 100%, Magnified view (up to 16x),
Grid Display (4x4 Grid, Golden Section, Scale, Square(L), Square(S), Grid Color: Black/Gray/White ), Histogram, Bright area warning, Composition Adjustment
[h=3]LCD monitor[/h]
TypeWide viewing angle TFT color LCD, Air-gapless glass
Size3.2 inch (aspect ratio 3:2)
DotsApprox. 1620K dots
Touch ScreenCapacitive sensing method
AdjustmentBrightness, Saturation and Colors adjustable
Outdoor View SettingAdjustable ±2 step
Night Vision LCD DisplayON/OFF
[h=3]White Balance[/h]
TypeMethod using a combination of the image sensor and the RGBIr sensor
White Balance AUTO WB, Multi Auto WB, Daylight, Shade, Cloudy, Fluorescent Light (D:Daylight Color, N:Daylight White, W:Cool White, L:Warm White), Tungsten Light, CTE, Manual WB (up to 3 settings), Color Temperature Configuration (up to 3 settings), Copying the white balance setting of a captured image
Fine AdjustmentAdjustable ±14 steps on A-B axis or G-M axis
[h=3]Autofocus System[/h]
TypeTTL: Phase-matching autofocus
Focus SensorSAFOX 13, 101 point (25 cross type focus points)
Brightness Range EV-4 to 18 (ISO 100 / at normal temperature)
*EV-4 with luminance flux based on F2.8 levels
AF modeSingle AF (AF.S), Continuous AF (AF.C)
AF Point SelectionAuto Area, Zone Select, Select, Expanded Area(S, M, L), Select(S), Spot
AF Assist LightDedicated LED AF assist light
[h=3]Metering[/h]
TypeTTL open aperture metering using 307K pixel RGBIr sensor, Multi-segment, Center-weighted, Spot and Highlight-weighted
Metering RangeEV-3 to 20 (ISO100 at 50mm F1.4)
Exposure ModeScene Analyze Auto, Program, Sensitivity Priority, Shutter Priority, Aperture Priority, Shutter & Aperture Priority, Manual, Bulb, Flash X-sync Speed, USER1, USER2, USER3, USER4, USER5
EV Compensation±5EV (1/2EV steps or 1/3EV steps can be selected)
AE Lock Button type (timer type: two times the meter operating time set in Custom Setting);
Continuous as long as the shutter button is halfway pressed
[h=3]Shutter[/h]
Type Electronically controlled vertical-run focal plane shutter
* Electronic shutter when using Pixel Shift Resolution
Shutter SpeedAuto:1/8000 to 30 sec., Manual:1/8000 to 30 sec. (1/3EV steps or 1/2EV steps), Bulb (Timed exposure setting possible from 1 sec. to 20min.)
[h=3]Drive modes[/h]
Mode SelectionSingle Frame, Continuous (H, M, L), Bracketing (2, 3 or 5 frames), Depth of Field Bracketing, Motion Bracketing, Mirror-up, Multi-Exposure (Average/Additive/Bright), Interval Shooting, Interval Composite
Self-timer12s, 2s
Remote Control0s, 3s
Continuous Shooting Max. approx. 12 fps, JPEG ( L: ★★★ at Continuous H): up to approx. 37 frames, RAW: up to approx. 32 frames, RAW: up to approx. 30 frames
Max. approx. 7.0 fps, JPEG L: ★★★ at Continuous M): up to approx. 60 frames, RAW: up to approx. 37 frames, RAW: up to approx. 33 frames
Max. approx. 2.5 fps, JPEG ( L: ★★★ at Continuous L): up to approx. 90 frames, RAW: up to approx. 39 frames, RAW: up to approx. 37 frames
*Depending on shooting conditions
*Continuous shooting speed slows down with High sensitivity
[h=3]External Flash[/h]
Flash Modes Auto Flash Discharge, Auto Flash + Red-eye Reduction, Flash On, Flash On + Red-eye Reduction, Slow-speed Sync, Slow-speed Sync + Red-eye, P-TTL, Contrast-control-sync, High-speed sync, Wireless sync
* Contrast-control-sync and High-speed sync requires 2 or more dedicated external flash
Sync Speed1/200sec.
Flash Exposure Compensation-2.0~+1.0EV
[h=3]Capture Settings[/h]
Custom ImageAuto Select, Bright, Natural, Portrait, Landscape, Vibrant, Radiant, Muted, Flat, Bleach Bypass, Reversal Film, Monochrome, Cross Processing
Cross ProcessRandom, Preset 1-3, Favorite 1-3
Digital FilterExtract Color, Replace Color, Toy Camera, Retro, High Contrast, Shading, Invert Color, Unicolor Bold, Tone Expansion, Bold Monochrome, Grainy Monochrome
ClarityAdjustable ±4 step
Skin ToneType1/Type2
HDRAuto, HDR1, HDR2, HDR3, Advanced HDR, Exposure bracket value adjustable, Automatic composition correction function
Pixel Shift ResolutionAvailable, Motion Correction On/Off
Lens CorrectionDistortion Correction, Peripheral Illumin. Correction, Lateral Chromatic Aberration Correction, Diffraction Correction
D-Range CorrectionHighlight Correction, Shadow Correction
Noise ReductionSlow Shutter Speed NR, High-ISO Noise Reduction
Horizon CorrectionSR On: correction up to 1 degrees, SR Off: correction up to 2 degrees
Composition AdjustmentAdjustment range of ±1.5mm up, down, left or right (1mm when rotated); Rotating range of 1 degree
Electronic LevelDisplayed in viewfinder (Horizontal and vertical); Displayed on LCD monitor (Horizontal and vertical)
Program LineAUTO, Normal, Hi-speed Priority, DOF Priority (Deep), DOF Priority (Shallow), MTF Priority
[h=3]Movie[/h]
File FormatMPEG-4 AVC/H.264(MOV)
Recorded Pixels 4K(3840x2160, 30p/24p)
Full HD(1920x1080, 60p/30p/24p)
Sound Built-in stereo microphone, external microphone (Stereo recording compatible)
Recording Sound Level adjustable, Wind Noise Reduction
Recording TimeUp to 25 minutes or 4GB ; automatically stops recording if the internal temperature of the camera becomes high.
White BalanceAUTO WB, Daylight, Shade, Cloudy, Fluorescent Light (D:Daylight Color, N:Daylight White, W:Cool White, L:Warm White), Tungsten Light, CTE, Manual WB (up to 3 settings), Color Temperature Configuration (up to 3 settings), Copying the white balance setting of a captured image
Custom ImagesAuto Select, Bright, Natural, Portrait, Landscape, Vibrant, Radiant, Muted, Flat, Bleach Bypass, Reversal Film, Monochrome, Cross Processing
Cross ProcessingRandom, Preset 1-3, Favorite 1-3.
Digital FilterExtract Color, Replace Color, Retro, High Contrast, Invert Color, Unicolor Bold, Bold Monochrome
[h=3]Playback[/h]
Playback ViewSingle frame, Multi-image display (20, 48, 70 segmentation), Display magnification (up to 16, 100% display, quick zoom and Focus Magnification available), Grid display (4x4 Grid, Golden Section, Scale, Square(L), Square(S), Grid Color: Black/Gray/White), Rotating, Histogram (Y histogram, RGB histogram), Bright area warning, Auto Image Rotation, Detailed information, Copyright Information (Photographer, Copyright holder), GPS information (latitude, longitude, altitude, Coordinated Universal Time) , Orientation, Folder Display, Calendar Filmstrip Display
DeleteDelete single image, Delete all, Select & delete, Folder delete, Calendar delete, Delete instant review image
Digital FilterBase Parameter Adj, Extract Color, Replace Color, Toy Camera, Retro, High Contrast, Shading, Invert Color, Unicolor Bold, Tone Expansion, Bold Monochrome, Grainy Monochrome, Miniature, Soft, Fish-eye, Slim, Monochrome, Frame Composite
RAW Development RAW file select: Select Single Image, Select Multiple Images, Select a folder, Select a shooting date
RAW Development Parameter: White Balance, Custom Image, Sensitivity, Digital filter, Clarity, Skin Tone, HDR, Pixel Shift Resolution, Distortion Correction, Peripheral Illumin. Corr., Lateral Chromatic Aberration Correction, Diffraction Correction, Color Fringe Correction, High-ISO Noise Reduction, Shadow Correction, File Format (JPEG/TIFF), JPEG Recorded Pixels, JPEG Quality, Aspect Ratio, Color Space
EditProtect, Image Rotation, Image Copy, File Transfer, Save RAW Data in buffer memory, Resize, Cropping (Aspect ratio and Slant adjustment available), Levels Adjustment, WB Adjustment, Color Moiré Correction, Movie Edit (Divide or delete selected frames), Capturing a JPEG still picture from a movie
[h=3]Customization[/h]
SettingsUSER Mode, Fx Button, AF/AE Lock Settings, Preview Dial, E-Dial Programming, Smart Function, Monitor Touch Opperation, Eye Sensor, Viewfinder Display, LCD Panel, Monitor Display, Instant Review, Zoom Review, Warning Display, Control Panel, Memory, EV Steps, ISO Sensitivity Steps, Color Temperature Steps, Input MF Lens Focal Length, Save Rotation Information, Aperture Information Record, AF Fine Adjustment, Copyright Information
LanguageEnglish, French, Germany, Spanish, Portuguese, Italian, Dutch, Danish, Swedish, Finnish, Polish, Czech, Hungarian, Turkish, Greek, Russian, Thai, Korean, Traditional Chinese, Simplified Chinese, Japanese
[h=3]Power supply[/h]
Battery TypeRechargeable Lithium-ion Battery D-LI90
AC AdapterAC Adapter Kit K-AC166(Optional)
Battery LifeNumber of recordable images: Approx.: 800 images
Playback time: Approx. 250 minutes
* With a fully-recharged Rechargeable Lithium-ion Battery. Tested in compliance with CIPA standard.
Actual results may vary depending on the shooting condition.
[h=3]Interfaces[/h]
Connection PortUSB Terminal(USB Type-C), External cable switch terminal(2.5mm diameter), X-sync socket, HDMI output terminal (Type D) , Stereo microphone input terminal, Headphone terminal
USB ConnectionUSB 3.2 Gen1, Data Transfer: MTP/CD-ROM, Battery Recharge/Power Supply (Optional AC Adapter required)
[h=3]Wireless LAN[/h]
StandardsIEEE 802.11b/g/n
Frequency (Center Frequency)2412MHz~2462MHz (1ch~11ch)
SecurityAuthentication: WPA2, Encryption: AES
[h=3]Bluetooth[/h]
StandardsBluetooth[SUP]®[/SUP] v4.2 (Bluetooth Low Energy)
Frequency (Center Frequency)2402MHz~2480MHz (CH0~CH39)
[h=3]Dimensions and Weight[/h]
DimensionsApprox. 134.5mm (W) x103.5mm (H) x 73.5mm (D) (excluding protrusions)
WeightApprox. 820g (Including dedicated battery and SD Memory Card),
Approx. 735g (body only)
https://youtu.be/vDO0esYahRw
[url]https://www.youtube.com/watch?v=howLTiGRKoM
karamela
6 November 2013
10,591
Εντάξει ουαου!!! Ότι πιο περίεργο έχω δει μεν άλλα εντυπωσιακή δε!! Με εξαίρεση την τελευταία κάτω δεξιά όλες τις άλλες ευχαρίστως θα τις έπαιρνα!!
Kosh
7 September 2006
91,253
Εκεί ψηλά.....
Καλα ναι ας αφησουν τα φρου φρου και αρωματα και ας σχεδιασουν καποια στιγμη καμια ακαθρεπτη γιατι τους βλεπω να καταληγουν σαν την Contax.
karamela
6 November 2013
10,591
Σωστός, από ότι είχαν πει βέβαια δεν θέλουν να βγάλουν Mirrorless...είχα παλιότερα μια Pantax KS-2 με 3-4 φακούς, όμορφη, στιβαρή, καλή κατασκευή, IBIS, καλή εργονομία κλπ. άλλα τρισάθλια εστίαση, φακοί που κάνανε σαν χαλασμένο γραμμόφωνο και δούλευαν με το γνωστό ''κατσαβιδάκι'', τραγική Jpeg engine, για βίντεο ότι χειρότερο υπάρχει και άλλες πολλές ελλείψεις, ούτε καν καλή μπαταρία δεν είχε που είναι από τα θετικά των Dslr.....πολύ ιδιαίτερες μηχανές με λίγους και φανατικούς θαυμαστές...προσωπικά μια K1 αν την έβρισκα σε πολύ χαμηλή τιμή θα την αγόραζα, άλλα μέχρι εκει.
karamela
6 November 2013
10,591
Φαίνεται πολύ καλός φακός, άλλα συγγνώμη 1.500 ευρώ???? Πάνε καλά???
karamela
6 November 2013
10,591
Ετσι και αλλιώς λίγοι τις αγοράζανε οπότε αναμενόμενο, αυτή η πρόταση ''Ricoh will stop mass-producing cameras and will concentrate on “workshop-like” manufacturing process΄΄ δείχνει ευγενικά ότι σταματάει την παραγωγή μηχανών για το ευρύ κοινό. Βασικά συρρικνώνεται (για να σώσει το τμήμα μάλλον) και επικεντρώνεται μόνο σε πολύ συγκεκριμένα προϊόντα και καταστάσεις.
Kosh
7 September 2006
91,253
Εκεί ψηλά.....
Και πολυ αργησε θα ελεγα εγω.
ποσο κοινο να ειχε πια για να την κραταζει ζωντανη ?
milaber22
2 December 2012
1,402
Βόλος
Νομίζω ότι χάθηκαν λίγο στην μετάφραση,
στο pentaxforum υπάρχει μια εκτίμηση της ανακοίνωσης
αν και η μεγάλη εικόνα δεν αλλάζει.
Δύσκολα θα μπει κάποιος σρο σύστημα της
Προσωπικά από όσα σώματα έχω πιάσει η Κ1 ήταν από τα κορυφαία εργονομικά.
Έχοντας φύγει από το μικρόβιο των λάιβ ευχαρίστως αν μπορούσα θα γυρνούσα σε πένταξ.
Αλλά υπάρχει το παράδοξο οι τιμές στα μεταχειρισμένα Ευρώπη να είναι ψηλά.
Υποθέτω όσοι έχουν μείνει πλέον δύσκολα πουλάνε.
πχ KP ακριβότερα από used xt2 σε πλατφόρμες.
cacau
7 June 2008
20,360
Συγκλονιστικά νέα από την Ricoh! Θα κυκλοφορήσει η GR IIIx Urban Edition σε γκριζάκι μεταλλικό με δαχτυλίδι σε απαλή μπλέ απόχρωση και ασορτί δερμάτινο λουράκι.
Γκουγλομετάφραση της ανακοίνωσης: "Το σώμα της κάμερας τονίζεται από έναν εντυπωσιακό μπλε-μπλε δακτύλιο που περιβάλλει το βαρέλι του φακού — μια αναπαράσταση βαθυγάλανου ουρανού που αντανακλάται σε μια πισίνα μετά τη βροχή ή τα σημάδια νέον μιας πόλης που δεν κοιμάται ποτέ και οι αντανακλάσεις τους."
Μόνο 2.000 κομμάτια παγκοσμίως, τρεχάτε να προλάβετε! :cry::ROFLMAO:
  • Haha
Reactions: toupia and karamela
toupia
Τιμούλα;
