kgf123
- 19 December 2007
- 236
Re: TOSHIBA 47z3030DG ..... Thread ... αντε και 42 και 52 !!!
SERVICE MENU ΣΕΙΡΑ Χ ΚΑΙ Ζ ΤΟΣΙΜΠΑ !!!ΠΡΟΣΟΧΗ!!!
πολυ προσοχη αν κανετε αλλαγες στις τιμες!!!το ανεβαζω μονο και μονο για future reference.
Disclaimer: I accept no liability for any damage you may do to your set so if you're intent on making service menu changes proceed with caution!
Warning: I recommend you make a note of all settings and their corresponding values before you change them. Finally, remember that the performance of each set varies to some degree and that these controls can have a big impact on your picture even if tweaked slightly, consequently using someone else's settings is more likely to be detrimental than beneficial. I strongly recommend obtaining a colorimeter to monitor the results of such changes.
Accessing the Service Menu
If you haven't please read the above disclaimer and warning!
* Turn the TV on.
* Press the {MUTE} button three times on the remote.
* Press the {MUTE} button again on the remote and hold.
* Then press the {MENU} button on the TV's front panel.
* Release both buttons
* There should be a letter "S" on the upper right of the screen.
* Press the {MENU} button on the TV's front panel again.
* Use the {CH+} or {CH-} buttons to select a setting.
* Use the {VOL+} and {VOL-} buttons to adjust the value.
* Turn the set off to exit the Service Menu.
το οριτζιναλ thread ειναι εδω:
http://www.avforums.com/forums/showthread.php?t=528641&page=4
τη διαδικασια την τσεκαρα και δουλευει.
* Turn the TV on.
