Xbox One X as 4K UHD Blu-ray player
xavito
29 October 2008
8,984
-Xbox One X as UHD Blu-ray player-
HDTV Magazine's Christian Trozinski presents a test update on the UHD Blu-ray Player Performance, matching the official launch of the new Xbox One X. Can the HDR playback be convincing in addition to the SDR movie display?
https://www.youtube.com/watch?v=5TuoSSdtklc
source video:[youtube.com -
digitalfernsehende]
source picture:[lunawolfgaming.com]
spcav
18 August 2006
16,601
Re: Απάντηση: Xbox One X as 4K UHD Blu-ray player
Εγώ πάλι πιστεύω ότι ψαγμένος χρήστης με 4Κ, HDR 23,976 κλπ δεν υπάρχει περίπτωση να ασχολείται με σουβέρ πλέον.....
Λύσσα κακιά με τα δισκάκια 😋
Μέχρι πρότινος και ίσως και ακόμα, χωρίς δισκάκια δεν έπαιζε 4Κ, Τάσο
Panoramix
31 January 2012
11,429
Να εκπεδευεσαι :p
Πότε δεν ξέρεις:)
Και Τάσο μην το λες. Όντως το 4κ έχει αέρα streaming τελικά, αλλά δεν είναι και μακρυά από τα δισκάκια. Να δω βέβαια ποτέ θα έρθουν στα mainstream video club για τον πολύ τον κόσμο που πλέον ψωνίζει 4κ πανελς στις 42 ίντσες...
xavito
29 October 2008
8,984
We demonstrate in a side-by-side comparison how the HDR video output (including 4K Blu-ray playback & internal Netflix app) from Microsoft's new Xbox One X console is broken, resulting in significantly raised black level & a severely washed out HDR picture.
However, Microsoft is fully aware of this issue, and promised to release a software fix within the next few days.
The side-by-side comparison was done on two 49-inch Samsung Q7F QLED TVs, as well as a Panasonic UB900 4K Blu-ray player.
https://www.youtube.com/watch?v=nlVdhZxpEqM
source video:[youtube - hdtvtest.co.uk]
xavito
29 October 2008
8,984
We compare the picture quality of Microsoft's new Xbox One X console vs a dedicated 4K Blu-ray player (the Panasonic UB900) in terms of Ultra HD Blu-ray playback, after a firmware update has fixed the console's elevated black level for HDR video output.
Ryan Masciola's HDR10 test disc can be found here:
http://diversifiedvideosolutions.com/
https://www.youtube.com/watch?v=F1Lt43-9lmY
source video:[youtube.com - hdtvtest.co.uk]
MakisM
12 May 2009
5,362
Χμμμμ...Μια χαρά .
Ειδικότερα όταν θα έρχονται οι αναβαθμίσεις και όλοι οι υπόλοιποι θα το βλέπουν με τα κυάλια .
Χθες αναβαθμίστηκε και πάλι .:award:
MakisM
12 May 2009
5,362
Όχι απαραίτητα αν είναι κάτι καλό ναι .
Αλλά περισσότερο για να είσαι μέσα στα πράγματα ...Μιας η επεξεργαστική του δύναμη άνετα θα σηκώσει για κάτι μελλοντικό πχ Hi 4 Κ ULTRA HD....Συνεχίζω όμως να βλέπω 1080p.
french bulldog
3 August 2017
29
καλησπέρα παιδιά!μετά την αγορά της sony xe9005 σκέφτομαι την απόκτηση είτε ενός xbox one x είτε ενός Sony UBP-X800.
ποια είναι η άποψή σας για θέαση 90% ταινιών και 10% για παιχνίδια?απλά σκέφτομαι ότι αν πάρω το xbox,σκαλώσω και αντιστραφούν τα ποσοστά...
σαν τρίτη επιλογή έχω το νέτφλιξ ,ενώ δεν έχω vdsl κ δε θα βάλω.η ταχύτητα είναι γύρω στα 8-9mbps.αξίζει?
Videophile2
1 June 2010
118
Λαμία
Αν δεν παιζεις παιχνιδια βαλε netflix και με τα ρεστα πηγαινε κανα ταξιδακι . Εχω ps4 , htpc , και xtreamer . Τα torrents εχουν γινει ελεεινα και τα αλλα app τυπου kodi κλπ μου γυμναζουν τα νευρα ... επαψα να ασχολουμαι .Αν και εβαλα vdsl 50 και με τα 10 -11 που ειχα πριν μια χαρα πηγαινε το netflix. Απλα δεν αφηνει περιθωριο σε αλλους για youtube και κατεβασματα . Με τα 8-9 σου φτανει ισως και για 4κ στο netflix οριακα.
french bulldog
3 August 2017
29
videophile2 ακριβώς αυτα που λες αποφάσισα να κάνω τελικά.να βάλω νετφλιξ μιας και ειναι αρκετα ικανοποιητικο κατι που δεν το περίμενα.παιχνιδια δεν θα επαιζα οποτε 500ε μονο για να βλεπω ταινιες δεν....και πλεον θα αγορασω ηχεία και ενισχυτη για να στησω ενα ηχοσυστημα 5.1!
MakisM
12 May 2009
5,362
Την ιστορία γενικά οι παλιότεροι που έχουν ασχοληθεί με τα player την ξέρουν .
Απλά θα σας θυμίσω το τι έκανε ένα ps3 πάντα για την εποχή του και κάποια παραδείγματα που αξίζει να αναφέρω...Γρήγορη εκκίνηση του δίσκου blu -ray ,συνεχόμενες αναβαθμίσεις και υποστήριξη από την Sony όπως το 3D κτλ όταν επώνυμα player hi end τα έβρισκες στις αγγελίες αφού έχαναν γρήγορα την αξία τους .
Και εκεί που θα περίμενες την Sony να απαντήσει μέσω της παιχνιδομηχανής του pro δεν το έκανε αφού ούτε media player είναι ούτε 4K native player είναι παρά μόνο στα παιχνίδια .
Όμως και εκεί ούτε τα γραφικά του XboxΧ πιάνει ,ούτε την επεξεργαστική ισχύ.Και βέβαια οι κάτοχοι του Xbox αγοράζουν παιχνίδια η κατεβάζουν free αφού το store πυκνά συχνά κάνει προσφορές .
Όσον αφορά την ποιότητα της εικόνας και την λεπτομέρεια που πήρα ήταν άψογη και με εξέπληξε ευχάριστα για το πως διαχειρίζεται το σήμα SD dvd για κάποιους που έχουν μια μεγάλη συλλογή από ταινίες .Είναι αθόρυβο ,γρήγορο έχει δικό του media player,vlc,plex και τώρα kodi.
Netflix,άψογη συμπεριφορά και συνεργασία με τα win10 και το πιο σημαντικό ,υποστήριξη από την Microsoft αφού η ίδια εταιρία βρίσκεται στην Ελλάδα .
