Zidoo X20
leonkoum
20 December 2008
4,892
Απάντηση: Re: Zidoo X20/Χ20 PRO
Θα καθυστερήσει λιγο το λανσάρισμα του Zidoo X20.
Στην καλύτερη τέλη Δεκεμβρη αλλιώς με το νέο ετος.
Τελος, μάλλον θα ονομάζεται Zidoo X20 Pro.
Ενα περιμεναμε, δυο τελικα μας ερχονται τον Μαιο .. :antlers:
X20
Powerful Configuration:
430MM Standard cabinet Size, All aluminum alloy chassis
New upgrade version Realtek 1296 Quad-Core 64 bit A53 processor,High quality high-power SMPS.
2G DDR4 Memory,16GB eMMC Super Built-in Storage,gigabit wired, 802.11 AC 2T2R 867Mbps WIFI,Bluetooth 4.2
Abundant Interface :
SATA 3.0*2, USB 2.0*2, USB 3.0*1, TYPEC *1, Coaxial Cable*1, Optical Fiber*1 , Left/Right Channels*1, AV Output*1, Infrared Input*1, RS232*1, HDMI OUT*2, HDMI IN 2.0*1
Full function with backlight Bluetooth-Infrared-Learning three-in-one remote control, remote control without dead Angle.
Super Lager front LED Display.
Independent Dual SATA 3.0 Ports, NSS Patented metal hard disk extractor can Build-in two High-Capacity Hard Disk.
Smart temperature control with dual Balls and High Static Pressure Fan.
Dual HDMI Output ports (Audio and Video Separation) dispense with origin power amplifier and enjoy 4K with HD Audio.
New quality optimization engine technology, Optimized HDR to SDR Algorithm. Play 4K HDR which Restoring primitive color even without HDR TV.
Detailed Frame switching and resolution switching. (23.976,59.94,25,30,50,60)
4K 60P Point to Point Output, Color Region: HDR/HDR10, 10Bit Color Depth, 10.7 hundred million kind of colors.
True 4K 60P decode, H.265/HEVC 10Bit Hard solution.
Support 4K UHD Blue-Ray Navigation
Powerful subtitle function, Support random change any fonts with different color effects; Support download subtitle online; Support SUP&ASS special effects subtitles
Unparalleled Wall-Poster Function, Full automatic scan, Automatic classification and sorting movies and dramas. Customer Layout.
Soundtrack support SACD, DFF, DSF, APE, FLAC, WAV and etc Free lossless audio formats; Support CUE track; Support cell phone control without having to open the display device to listen to music.
Support NFS,SMB,V2,SMB V1 multiple shared protocols.
Support HTTP, RS232(Control on-off), Control4 Multiple ways to control.
X20 Pro
New upgrade version Realtek 1296 Quad-Core 64 bit A53 processor, High quality high-power SMPS.
4G DDR4 Memory,32GB eMMC Super Built-in Storage :eek:perator:, Œgigabit wired, 802.11 AC 2T2R 867Mbps WIFI, Bluetooth 4.2
X20: SATA 3.0*2, USB 2.0*2, USB 3.0*1, TYPEC *1, Coaxial Cable*1, Optical Fiber*1 , Left/Right Channels*1, AV Output*1, Infrared Input*1, RS232*1, HDMI OUT*2, HDMI IN 2.0*1
ESS 9038 Professional DAC Audio processing Chip :guitarist:
Προσεξτε την διπλασια μνημη (4/32) του PRO εναντι του 'απλου', τη παρουσια εξιδικευμενου chip ηχου (ESS 9038 Professional DAC Audio processing Chip) και οπως επισης οτι λιγοτερο απο εναν μηνα πριν την επισημη παρουσιαση, κουβεντα δεν γινεται για το λειτουργικο...:BDGBDGB53:
..και για τιμη -αγνωστο ακομα- στο 'θεο'.. Υπερβολικα 'φιλοδοξες' οι προσδοκιες τους ειδικα οταν ακομα το λογισμικο σου εχει 'τρυπουλες'..
Περισσοτερα εν'καιρω..
vadergr
17 August 2007
27,565
Μεταμορφωση
Εντάξει, δεν χρειάζεσαι 4gb ram για σωστή αναπαραγωγή βίντεο και λίγοι θα πάρουν το μεγάλο για το sac του, ειδικά αν έχει 500+
Είναι καλό πάντως που έβγαλαν και το απλό x20, ειδικά αν δούμε διαφορες σε ποιοτικά χαρακτηριστικά.
auteur
Banned
12 March 2009
9,072
αν το απλό x20, ειναι κοντά στα 200 που ζητάει το νέο Dune, θα περιμένουμε να δουμε και αυτό...
αλλα ετσι πως το πάνε, δεν θα παρουμε ποτέ mp με απροβλημάτιστη αναπαραγωγή 4Κ HDR.
vadergr
17 August 2007
27,565
Μεταμορφωση
Χωρις να ξερω κάτι, λογικά θα εχει πάνω απο 200 το Χ20 μιας και δεν αντικαθιστά το Χ10.
auteur
Banned
12 March 2009
9,072
μεχρι 300 το σκέφτομαι.. αφου θα εχει 2 HDMI και δεν θα χρειάζομαι το egreat H10.
σε firmware update υποστήριξη, εμπιστέυομαι περισσοτερο την dune,
αλλα αν υπάρχουν θεματα που δεν λύνονται λογο SoC, και αν το νεο SoC του zidoo x20 τα λύνει, τοτε θα προτιμήσουμε το zidoo.
leonkoum
20 December 2008
4,892
Τιμές ακόμα δεν ξέρουμε αλλά πιστεύω ότι θα παίξουν αρκετά πιο πάνω από τα 300+
Διαφοροποιήσεις μην περιμένεις πολλές (πρακτικά πιστεύω ‛καμια’) μιας και μιλάμε βασικά για το ίδιο SoC..
RDT1296 & RTD1295 είναι πανομοιότυπα εκτός του ότι το πρώτο έχει περισσότερες θύρες. Γιαυτο και χρησιμοποιείται στα καινούργια NAS πχ της SYNOLOGY.
Εκεί που θα υπάρχει διαφορά θάναι στο PRO λόγο της παρουσίας του εξειδικευμένου chip ήχου (αλλά δεν ξέρω πόσους αυτό πρακτικά θα ενδιαφέρει..)
Τον άλλο μήνα θα έχουμε τις ‛επίσημες’ ανακοινώσεις και εκεί θα ξέρουμε περισσότερα
leonkoum
20 December 2008
4,892
«The New ZIDOO X20 and ZIDOO X20 PRO will release after May 15th
The retail price will be around $400 for X20 and $650 for X20 PRO.»
Lef7234
Inactive User
5 May 2007
6,504
Ωρε αυτα βλεπει η Dune και τριβει τα χερια της.
Βλεπω την τυχη της Oppo να εχει και αυτη.
vertical
15 November 2011
3,347
Γιατί να τρίβει η Dune τα χέρια της; Έχει μηχάνημα σε price range κοντά στο κατοστάρικο; Κάτω από αυτό; Η Zidoo έχει μεγάλο product range με ανάλογη ποικιλία στις τιμές. Καμία σχέση με Oppo.
baspav
21 January 2010
1,800
Η Intel και η nVidia θα τρίβουν τα χέρια τους. Φτιάχνεις ένα HTPCακι με 500 ευρώ και όμορφο και 4K και όλη την software βιβλιοθήκη ενός pc.
Lef7234
Inactive User
5 May 2007
6,504
θα τα τριβει γιατι αυτο που εχει βγαλει με 200 δεν πιστευω να ειναι τοσο πολυ κατωτερο απο αυτο που θα πουλαει με 400 η zidoo απο την αλλη εχει δικιο γιατι και το X9s ειναι του κατοσταρικου και δεν ειναι τοσο κατωτερο απο το Dune που εχει 200 ευρω.
Μηπως ειναι υπερβολικα τα λεφτα που ζητανε για το λιγο καλυτερο; απο τα 100 του Χ9 παμε στα 200 του Dune και στα 400 του X20 δεν ειναι καπως υπερβολη αυτο με αυτα που προσφερουν.
vadergr
17 August 2007
27,565
Μεταμορφωση
Με 500 πολυ αμφιβαλλω για το αισθητικο κομμάτι. Και υπαρχει παντα η πληγη της ευχρηστίας στα htpc.
Lef7234
Inactive User
5 May 2007
6,504
+1 και πολλα λες.
leonkoum
20 December 2008
4,892
KΆι που να δείτε και το αντίστοιχο dune όταν έλθει...
Πάντως ειλικρινά την παρουσίαση μηχανημάτων αυτής της κατηγορίας δεν την καταλαβαίνω...
vadergr
17 August 2007
27,565
Μεταμορφωση
Re: Απάντηση: Zidoo X20
Δεν θεωρώ πολλά τα 400$/340 αν οντως ειναι καλύτερο/πιο απροβληματιστο σε θεματα αναπαραγωγής απο τα Dune και Zidoo που συζητάμε. Ειδικά στα Zidoo, οι τιμές ηταν πάντα ευέλικτες.
Αν ειναι να ξεμπερδέψεις απο πονοκεφάλους μια χαρά ειναι. Εχουμε κάνει και χειρότερα στο παρελθον. Μην ξεχνα´τε οτι ειναι και μακράν καλύτερη υλοποίηση σε επιπεδο κατασκευής.
Εγω θα ζητούσα τα παρακάτω:
  1. Να μην υπάρχουν θεματα με banding / Colorspace selection
  2. Να μην υπάρχουν θεματα με aspect ratio σε SD υλικο
  3. Οπωσδήποτε καλαίσθητο user interface. Βασικά δεν θα ηθελα κατι που θα μου θυμίζει Android. Ουτε καν Android TV. Οσο πιο κλειστό, τοσο πιο καλά.
  4. Προφανώς να κραταει τα σωστα της τωρινής γεννιάς (4K/HDR, ATMOS/DTS:X κλπ)
  5. Αν και δεν θα συμβεί, καλό θα ηταν να βλέπαμε και εναν επεξεργαστη εικόνας σαν τον VXP της προηγουμενης φουρνιας Dune
  6. Αναπαραγωγή BD/DVD menu.
Θεωρώ και εγω πάντως την υπαρξη του κορυφαιου μοντέλου με DAC/XLR ανούσια. Δεν ειναι brand γνωστα για τετοιου είδους υλοποιήσεις. Απουλητα θα πάνε (Dune + Zidoo)
vertical
15 November 2011
3,347
Re: Απάντηση: Re: Zidoo X20
Τα έχεις δει κι έβγαλες συμπέρασμα αν είναι καλύτερα/χειρότερα από τα Dune;
Lef7234
Inactive User
5 May 2007
6,504
Απάντηση: Re: Απάντηση: Re: Zidoo X20
Δεν τα εχω δει και δεν εβγαλα κατι που εχει 400 χειροτερο απο αυτο που εχει 200 αλλα η απορια μου ηταν αξιζει τα διπλασια λεφτα;
Για σενα η διπλασια τιμη του Dune απο το Χ9 ειναι λογικη; Η διπλασια τιμη του Χ20 απο το Dune ειναι λογικη;
