Zidoo X9S (4K,HDR,3D,Blu ray Menu,HD Audio)
leonkoum
20 December 2008
4,894
ΑΝ και ειναι πια για μενα 'old news' η παλια αγαπη δεν ξεχνιετε...
Model: ZIDOO_X9S
Version number: v2.1.42
Link: http://apidl.zidoo.tv/X9S/v2.1.43/ZIDOO_X9S-v2.1.42-202009192015-ota.zip
MD5: C4928AFE27DBD8905C02A8B7505B5EAB
System
1. Increase screen saver function
2. Add support for aiff music files
3. Optimize DLNA projection function
Player
1. Add press the information button to display poster information
2. Fix the problem of pressing the function key to continue playing during pause
3. Optimize subtitle download
4. Fix the problem that the shortcut keys cannot switch chapters
5. Optimize the display of player poster information
6. Added file name display for local player information key
7. Add external subtitles and press the delete button to delete subtitles
Picture Manager
1. New revision of functions
2. Add custom folder function
3. Add the function of setting folders as screensaver pictures
4. Optimize the slideshow function
5. Fix the problem that the vertical screen picture is stretched in the slide show
6. Add the function of exclude folder
7. Add the function of exclusion by folder name
Poster wall:
1. Upgrade version 4.0
2. Optimize the sorting function of the navigation interface
3. Fix the problem that Douban cannot match
4. Solve the problem that the child lock will be ignored when playing directly
5. Fix the problem of incorrect data after sorting widgets
6. Optimize the ratio of local trailers
7. Optimize the sorting function
8. Optimize the details interface
9. Fix the problem of incorrect TV viewing records
10. Modify the problem that the detailed title is too long
11. When optimizing the list display, the letter navigation and the left side bar prompt the picture at the same time
12. Optimize TV series matching
13. Fix the problem that Douban cannot match
14. Add the launch time setting of the trailer in the detail interface
Quick settings
1. Increase screen saver settings
4. Add input method selection settings
File manager
1. Optimize the display of playback records
2. Increase the playback record display switch
3. Fix the problem that the wallpaper of the file manager is not synced occasionally
Blu-ray navigation
1. Increase the function of the information button to display movie information
2. Fix the problem of not being able to navigate after entering the screensaver
Control center
1. Optimize connection stability
App installer
1. Optimize webpage installation function
Main interface
1. Optimize the boot display speed
2. Shortcuts increase sorting function (press the menu key or long press the OK key)
3. Optimize animation fluency
Οπως παντα υπ'ευθυνη σας και παντα να τσεκαρετε το MD5 οτι κατεβασετε σωστα το αρχειο και ειναι το σωστο για το μηχανημα σας. :antlers:
manmar
21 December 2015
1,197
Και η κλασσική ερώτηση /επιβεβαίωση : για το X10 κάνει;
Επίσης δε διάβασα τίποτα για το music player. Μένουμε με το παλιό;
leonkoum
20 December 2008
4,894
Απάντηση: Re: Zidoo X9S (4K,HDR,3D,Blu ray Menu,HD Audio)
ΟΧΙ ΔΕΝ ΚΑΝΕΙ!!!!!!
Τα μεγαλα γραμματα για να μην κανει κανεις καμια εξυπναδα κα παρει το μηχανημα του στο χερι....
Υπομονη μερικες μερες ακομα και θα ελθει και για το Χ10
Εχουν χοντρα θεματακια με το καινουριο και τρεχουν και δεν φτανουν...
shatzi
10 October 2007
99
Καλησπέρα. Έκανα και εγώ στο δικό μου αναβάθμιση με το τελευταίο firmware Model: ZIDOO_X9S
Version number: v2.1.42 και απο τότε πάω να παίξω ταινίες σειρές από το synology storage, και κολλάνε τα video κανέναν δεν παίζει σαν να μπουκώνει ένα πράγμα οποίο video και αν επιλέξω,, σε όποια ανάλυση και μέγεθος. Καμία ιδέα κανείς? Δικτυακά οι συσκευές βλέπονται χωρίς πρόβλημα παίζει σφαίρα το δίκτυο.
konstantinos79
15 July 2012
97
Καλησπέρα!
Μια χαζή ερώτηση σε κάτι που δεν με είχε απασχολήσει μέχρι τώρα λόγω παλαιάς τηλεόρασης.
Το x9s μπορεί να παίξει αρχεια 4K με HDR και h265 ?
polakis
19 September 2008
2,792
Ενας φιλος εχει ενα Ζ10 και εχει ενα θεμα και με ρωτησε. Εγω δεν εχω zidoo πλεον, εχω nvidia εδω και χρονια.
23,876
Έχει δοκιμάσει κανένας σας να παίξει 4K αρχείο σε παλιά τηλεόραση που δεν υποστηρίζει ΗDR;
Βάζω το HDR στο off και η εικόνα εξακολουθεί να είναι ξεπλυμένη και με χλωμά χρώματα.
Βασικά είτε ON είτε OFF ειναι το HDR , η εικόνα ειναι η ίδια (χάλια).
Δεν έπρεπε με κλειστό το HDR να είναι σωστή η εικόνα;
Babis K.
28,831
Ναί... Απλά δεν βλέπεται.
Δοκίμασα να παίξω το La La Land
