Fujifilm X-H1 will be Fuji’s first IBIS Camera...
cacau
7 June 2008
20,434
Αφού μου την είπατε, να κι εγώ: https://www.fujirumors.com/fujifilm-x-h1-will-fujis-first-ibis-camera-no-longer-x-t2s/
Λέει διάφορα, μεταξύ άλλων "In the comments, some suggested that "H" stands for "Hybrid", meaning stills/video hybrid camera. Makes perfectly sense. The new Fujinon MK Cine lenses have no OIS, and of course Fujifilm designed them without stabilization, knowing the X-H1 would come with IBIS."
edit: αν τραβάει καλές φωτογραφίες μπορεί να την πάρω πακέτο με μερικούς κοντούς primes...
cacau
7 June 2008
20,434
...αν τραβάει καλές φωτογραφίες μπορεί να την πάρω πακέτο με μερικούς κοντούς primes...[/FONT][/COLOR]
Ίσως και όχι πάλι αν προλάβει να βγεί καμιά m4/3 στα 10-12mp για low light καταστάσεις ΚΑΙ σχετικά μαζεμένο μέγεθος, ΚΑΙ λογική τιμή, ΚΑΙ μετά ξύπνησα... :flipout::bigcry:
cacau
7 June 2008
20,434
Οι φημολογούμενες προδιαγραφές της μηχανής (copy paste from fuji rumors https://www.fujirumors.com/)
Despite what Fujifilm managers said about X-mount not being compatible with IBIS, the X-H1 will have IBIS
IBIS will work with all Fujinon X-mount lenses.
As opposed to Olympus & Co, IBIS and OIS will not work together… at least currently that’s not possible. Maybe Fujifilm will tweak the firmware in future. But at launch I don’t expect IBIS and OIS to work together.
Fujifilm’s IBIS solution will not allow the sensor shift multishot
There will be design changes over the X-T2, such as a better hand grip
The X-H1 will have the 24MP megapixel X-Trans III sensor
The release is (currently) scheduled for the first half of 2018
Shipping in February
Will cost around $2,000
New Film simulation Eterna is coming
IBIS Full sensor readout
Internal F-Log
No Exp.Comp dial but top LCD screen like GFX
Fuji X-T2 Vs. X-H1 Size Comparison
X-Processor Pro of Fujifilm X-T2 & Co
tiniakos
7 August 2007
16,197
Τήνος / Ελλάς
Γιατί τι περιμένατε.
Εδώ όλοι πια έχουν τις τιμές στα ύψη ποιος ο λόγος η Fuji να μην ακολουθήσει.
Σούπερ αισθητήρας, παρά πολύ καλό πια βίντεο, εστίαση άριστη, jpeg σημείο αναφοράς και μια προίκα φακών για όλα τα γούστα.
Οι Ιάπωνες της fuji μπήκαν δυναμικά και έχουν το momentun.
Κάθε γκρίνια την κάνουν παρελθόν, μια η εστίαση, μια το βίντεο, τώρα το ibis, τι έμεινε τώρα για να είναι μια ολοκληρωμένη μηχανή;
_tzo_
Banned
18 November 2007
11,985
Θα δούμε τώρα τα παπαγαλάκια, καλά ντε, τους fuji ambassadors/x-photographers να εκθειάζουν το ibis, ενώ πριν το έβγαζαν αχρείαστο.
Ή μάλλον θα το αναγάγουν σε χαρακτηριστικό περιορισμένης χρησιμότητας, αφού θα το έχει αρχικά μόνο ένα μοντέλο.
kbouk
8 January 2010
22,816
ΠΕΙΡΑΙΑΣ
Απάντηση: Re: Fujifilm X-H1 will be Fuji’s first IBIS Camera...
Εμάς σαν καταναλωτές δεν πρεπει να μας αγγίζουν αυτά, όποια νέα τεχνολογία ενσωματώνεται σε μια εταιρία νομοτελειακά καποια στιγμή θα την υιοθετήσουν και οι υπόλοιπες, είτε αυτο λέγεται σταθεροποίηση, pixel shift κλπ. σήμερα, είτε liveview , pixel mapping, φίλτρο καθαρισμού σκόνης κλπ. μια δεκαετία πριν.
Η τιμή της μηχανής ακολουθεί τον ανταγωνισμό στις ακάθρεπτες που έχουν δυστυχώς ορίσει δική τους τιμολογιακή πολιτική .
Προσωπικά χαίρομαι πολύ με αυτή την κίνηση της Fuji γιατί ήταν ένας βασικός λόγος μέχρι τώρα που δεν θα αποκτούσα ποτέ μηχανή Fuji, εχω δυστυχώς καλομάθει πολύ και δεν έχω καμία όρεξη να αλλάξω συνήθειες.
tiniakos
7 August 2007
16,197
Τήνος / Ελλάς
Δίνει επιλογές για όλους η fuji.
Εμένα προσωπικά δε με απασχολεί το ibis αν το χρειαζόμουν το έχει καιρό τώρα η sony με την a6500 και θα την επέλεγα.
Θα συμφωνήσω με Κώστα ότι οι τιμές πια είναι καρτέλ στις ακάθρεπτες αφού και η παραδοσιακά φτηνή panasonic βαράει πια στα αυτιά.
Τα παπαγαλάκια είναι πληρωμένα από όλες τις εταιρείες γιατί να ασχοληθούμε μαζί τους.
karamela
6 November 2013
10,930
Οικονομικοί φακοί για αυτούς που δεν θέλουν να δώσουν μια περιουσία, φακοί με Powerzoom για βίντεο, φακοί με μεγάλο εύρος και σταθερό διάφραγμα π.χ. Sony 18-105f4 ή Olympus 12-100f4.....έγραψα απλός 2-3 λόγους που αποτρέπουν κόσμο να πάει στην Fuji.....κατά τα άλλα μια χαρά μηχανή φαίνεται με την κλασική τιμή των 2.000 ευρώ που παίζει πολύ αυτή την εποχή!!!
Anetheron
9 August 2013
1,208
Σαν να έκαναν παιδί η GFX με την X-T2 :)
Ίδια μπαταρία με την X-T2 γράφεται...περίεργη απόφαση με δεδομένου του αρκετά μεγαλύτερου μεγέθους.
22 June 2006
34,878
NEO HRAKLEIO
επρεπε να βαλουν μεγαλυτερη μπαταρια... στην ΧΤ2 που ειχα, στο βιντεο την ετρωγε για πλακα.
Με τοσο μεγαλο σωμα δεν δικαιολογειται τοσο μικρη μπαταρια.
cacau
7 June 2008
20,434
Δεν μου αρέσει καθόλου η αύξηση μεγέθους, ήδη θεωρώ μεγαλούτσικη για τα γούστα μου την ΧΤ-2. Με αυτά τα λεφτά και αυτό το μέγεθος γιατί να μην πάρω μια FF Sony? Φάουλ και αποβολή (από την λίστα μου)...
22 June 2006
34,878
NEO HRAKLEIO
Προφανώς έχει να κάνει με το βίντεο... Το 4κ είναι δύσκολο και προκαλεί υπερθέρμανση.
Στην χτ2 δε μπορείς καν να τραβήξεις πάνω από 10 λεπτά συνεχόμενα, παρά μόνο με extra grip.
Sent from my LG-H870 using Tapatalk
kbouk
8 January 2010
22,816
ΠΕΙΡΑΙΑΣ
Το ibis θέλει τον χώρο του, στα πρώτα μοντέλα της OLYMPUS με την πενταξονική φιλοξενούνταν στην άκομψη δυσανάλογη καμπούρα του hot shoe π.χ. Δες τε την πρώτη ΕΜ5 π.χ. τα γυροσκόπια, ηλεκτρομαγνητες κλπ. όσο ο αισθητήρας αυξάνει σε μέγεθος θέλουν τον χώρο τους για να είναι αποδοτικά. Πιστεύω ότι θέλει 1-2 γενιές να τρέξουν τουλάχιστον για να δούμε το τελικό μοντέλο της εταιρίας ταυτόχρονα σε καλή απόδοση Ibis και όμορφο ζυγισμένο σχεδιασμό.
22 June 2006
34,878
NEO HRAKLEIO
ενταξει, κι αυτα που κανει πια η fuji δεν ειναι λιγα...μεσα σε λιγο καιρο εφτιαξε την εστιαση, εβαλε καλο βιντεο κι ετοιμαζει και IBIS.... αυτα να τα βλεπει καμια Nikon , Canon που κοιμουνται τον υπνο του δικαιου !
Skywriter55
11 January 2015
952
Re: Fujifilm X-H1
15 λεπτά είναι η εγγραφή 4Κ χωρίς grip .Αντε να δούμε τι θα τσιμπίσουμε οι υπόλοιποι από specs με πιθανό update
22 June 2006
34,878
NEO HRAKLEIO
Re: Fujifilm X-H1
Το πρόβλημα με αυτή τη μηχανή είναι ότι απευθύνεται κυρίως στους βιντεάδες...κι εκεί έχει έντονο ανταγωνισμό.
Sent from my Pixel XL using Tapatalk
