- 29 October 2008
- 8,989
-Panasonic TV Line-Up 2019-
Panasonic presents GZ2000 OLED with HDR10+, Dolby Vision & Atmos...https://www.flatpanelshd.com/news.php?subaction=showfull&id=1546917571
Panasonic-TV-Line-Up-2018
Το μέγιστο μέγεθος θα ειναι οι 65 ίντσες;
Panasonic TV | ||||||
2016 | -> | 2017 | -> | 2018 | -> | 2019 |
OLED Ultra HD | ||||||
- | -> | EZ1000 | -> | FZ950 | -> | GZ2000 |
-> | -> | FZ830 (FZ800 + THX + RC from FZ950) | -> | |||
CZ950 | -> | EZ950 | -> | FZ800 | -> | GZ ? |
LCD Ultra HD | ||||||
DX900 | -> | - | -> | - | -> | ? |
DX800 | -> | - | -> | - | -> | ? |
DX780 | -> | EX780 | -> | FX780 | -> | GX ? |
DX750 | -> | EX740 | -> | FX740 | -> | GX ? |
DX730 | -> | EX730 | -> | FX730 | -> | GX ? |
DX720 | -> | EX720 | -> | FX720 | -> | GX ? |
DX700 | -> | EX700 | -> | FX700 | -> | ? |
DX650 | -> | - | -> | FX650 | -> | ? |
- | -> | EX620 | -> | FX630 | -> | |
- | -> | EX610 | -> | FX620 | -> | |
DX600 | -> | EX600 | -> | FX600 | -> | |
LCD Full HD | ||||||
DS630 | -> | - | -> | - | -> | |
DS600 | -> | - | -> | - | -> | |
- | -> | ES510 | -> | - | -> | |
DS500 | -> | ES500 | -> | FS500 | -> | - |
DS400 | -> | E400 | -> | FS400 | -> | - |
Panasonic OLED & LCD TV 2019 Line-up - european models | |||||||||
Type | OLED - UltraHD | LCD - UltraHD | LCD - FullHD | ||||||
Series _______________________ | GZ2000E _________________________________April-May | GZ1000E ____________________________ | GXx00E ____________________ | GXx50E ____________________ | GXx40E ____________________ | GXx20E ____________________ | GXx50E ____________________ | GXx00E ____________________ | GSx00E ____________________ |
Variants for different countries | GZW2004 (DE) GZ2000B (UK) GZ2000C (Canada) | GZW1004 (DE) GZ1000B (UK) GZ1000C (Canada) | |||||||
Size | 65", 55" | 65", 55" | 43", 49", 55", 65" | ||||||
Resolution | 3840(WRGB)x2160, UHD | 3840(WRGB)x2160, UHD | 3840(RGB)x2160, UHD | 1920x1080, | |||||
Certificates | |||||||||
Ultra HD Premium Cerified | yes | yes | |||||||
THX 4K Certified Display ensuring that you experience the filmmaker's vision exactly as it was intended | THX Cinema THX Bright room THX 4K Cinema | THX Cinema THX Bright room THX 4K Cinema | |||||||
ISF mode | yes | yes | |||||||
HDR | HDR10+, HDR10, HLG, DolbyVision, HSP (HLG Photo) To playback HDR, a HDR source is required (H.264 or H.265(ST2084 or HLG format)). | ||||||||
Dynamic Scene Optimizer | Y(w/ Metadata Creation) | ||||||||
CPU | |||||||||
Processor (CPU) | HCX Pro (Marketing name) MediaTek 5598 ? STV7804 ? Hi3751V811 ? | HCX | |||||||
Display | |||||||||
Manifacturer: Model: Type: Resolution: Display aspect ratio: Pixel Format: Display Colors:: Luminance(cd/m²): Viewing Angle: Color Gamut: Contrast Ratio: Response speed (ms): Frame Rate: Life Time: White Uniformity: | LG Display LE650AQD / LE550AQD / Specially reworked Professional Edition panel. AM-OLED, Oxide-WOLED-Color Filter 3840(RG/BW)x 2160, UHD 16:9 (H:V) RGBW Vertical Stripe 1.07B (8-bit + Dithering) 500 (Typical) 60/60/60/60 (Typ.) (Left, Right, Up, Down) 97% DCI-P3 150000:1 (Typ.) (Transmissive) 14 (Typ.)(G to G); 8 (Typ.)(MPRT) ms 120Hz 30K (Typ.) (Hours). After that time, the brightness may drop about 50%. 1.25/1.43 (Typ./Max.)(9 points) Luminance variation = Maximum/Minimum | LG Display LC ? S-IPS-VI, a-Si TFT LCD 3840 x 2160, UHD 16:9 (H:V) RGB 1.07B (8-bit + Dithering) ? - 90% DCI-P3 1100-1400:1 (Typ.) 5 (G to G); 8 (MPRT) 120Hz 30K(Min.) (Hours) 1.54 (Max.)(9 points) | |||||||
Lamp Type: Local Dimming: | self-emitting pixels - | ||||||||
Adaptive Backlight Dimming | - | - | AI HDR remastering | ||||||
Audio | |||||||||
Dolby Atmos | yes | - | |||||||
Surround | yes | yes | yes | ||||||
Speaker Output | 140W (40 W x 2 + 20 W x 3) | 30W (15W x 2) | |||||||
Sound mode | - | - | - | ||||||
Smart Features | |||||||||
Smart TV platform | my Home Screen 4.0 | my Home Screen 4.0 | my Home Screen 4.0 | ||||||
Voice Personal Assistant Voice Guidance | yes yes | yes yes | |||||||
EPG | yes | yes | yes | ||||||
Digital TV | DVB-T/T2/C/S2 | DVB-T/T2/C/S2 | DVB-T/T2/C/S2 | ||||||
Twin Tuners | yes | yes | |||||||
TV Anywhere | yes Due to network conditions or certain broadcaster restrictions, this function may not be available. | ||||||||
In-House TV Streaming (DVB-IP) | Y (Server / Client) | ||||||||
Panasonic TV Remote Apps | yes | ||||||||
Swipe & Share | yes | ||||||||
Web Browser | yes The Web Browser cannot display some web pages correctly. And viewable contents by the Web Browser are subject to the following conditions; - viewable contents may vary depend on models, - viewable contents may differ from those for PC, - viewable contents may be limited. | ||||||||
Easy Mirroring | yes | ||||||||
Network Contents Playback (DLNA) | Y (Server / Client) File formats that are not supported by your Network Contents server (DLNA compatible server, etc.) cannot be played. | ||||||||
Bluetooth | yes (Keyboard/Mouse/Audio Device)/Supporting HOGP profile HID (Human Interface Device Profile), A2DP (Advanced Audio Distribution Profile) | ||||||||
Bluetooth Audio Link | yes When a Bluetooth device is connected to the TV, it is possible that the Bluetooth audio output may not be synchronized (i.e. be delayed) with relation to the images on the screen. This is not a defect of the TV or the device. The delay time will differ depending on the device. | ||||||||
IP Home Control | yes | ||||||||
Media Player | yes | ||||||||
Teletext Reception | 2000p | ||||||||
USB-HDD Recording | Y(w/ Rewind live TV) USB1 (HDD 5V-900mA MAX) This feature requires a USB hard drive or flash drive with a capacity of at least 160 GB. | ||||||||
Multi Window | 2T PAP/PIP/PAT | ||||||||
HDAVI Control | yes | yes | |||||||
Connections | |||||||||
HDMI | ver: 2.0, 18Gbps, 2 (side), 2 (rear) HDMI (4K 60/50p with HDCP2.2) Audio Return Channel (Input 2) HDMI2.1 Auto low latency mode Viera Link (HDMI CEC) | ? | |||||||
HDMI Signal | |||||||||
HDMI PC Signal support | 4:4:4 chroma UHD/60p/50p/30p/25p/24p 4:2:2 chroma UHD/60p/50p/30p/25p/24p 4:2:0 chroma UHD/60p/50p DCI 4K (4096x2160) 60p,50p,30p,25p,24p, the actual resolution is 3840x2160 | ||||||||
USB Type A | 3 (1 side USB 3.0; 2 rear USB 2.0) | 3 (1 side USB 3.0; 2 rear USB 2.0) | |||||||
Ethernet RJ-45 | 1 | 1 | 1 | ||||||
CI (Common Interface) | 1 (CI Plus, Version 1.4, ECP) | 1 (CI Plus, Version 1.4, ECP) | |||||||
Scart Connector | no | no | |||||||
Component Video Input shared with Composite | RCA phono type x 1 (rear) | RCA phono type x 1 (rear) | |||||||
Digital Audio Output (Optical) | 1 (rear) | 1 (rear) | |||||||
Headphone Output | 1 x 3.5 mm (side switchable to Subwoofer) | 1 x 3.5 mm (side switchable to Subwoofer) | |||||||
Satellite in | 1 - Main, F-type female 1 - Sub, F-type female | ||||||||
Antena | 1 RF female | 1 RF female | 1 RF female | 1 RF female | 1 RF female | ||||
SD Memory Card Slot |
Type | OLED - UltraHD | LCD - UltraHD | ||||||
Series ______________________ | GZ2000E ______________________ | GZ1500E ______________________ | GZ1000E _____________________ | GZ960E _____________________GZ950Е | GX940E ____________________ | GX900E ____________________ | GX800E ______________________ | GX700E ____________________ |
Variants for different countries | GZW2004 (DE) GZC2004 (CH) GZ2000B (UK) | GZW1504 (DE) GZC1504 (CH) GZT1506 (Flanders) GZ1500B (UK) | GZW1004 (DE) GZC1004 (CH) GZ1000B (UK) | GZW954 (DE) GZC950 (CH) GZ950B (UK) | GX942 (FR, BE, NI, ES) GXW945 (DE) GXW940 (DE) GX920B (UK) | GXW904 (DE) GX900B (UK) | GXW804 (DE) GX800B (UK) | GXW704 (DE) GX700B (UK) |
Size - time | 65" - July 55" - July | 65" - June 55" - june | 65" - June 55" - June | 65" - June 55" - June | 75" - May | 65" - the end of March 55" - the end of March 49" - the end of March 43" - April | 65" - April 58" - April 50" - April 40" - April | 65" - April 58" - April 50" - April 40" - April |
Ultra HD Premium | tbd | tbd | No | No | No | |||
THX 4K Certified Display | THX Cinema THX Bright room THX 4K Cinema | No | No | No | No | |||
ISF Mode | Yes | No | No | No | No | |||
CPU | ||||||||
Processor (CPU) | HCX Pro Inteligent MediaTek 5598 ? STV7804 ? Hi3751V811 ? | HCX Pro MediaTek 5597 ? | HCX Pro Inteligent | HCX Pro MediaTek 5597 ? | - - | |||
DRAM | -- GB | -- GB | -- GB | --GB | - GB | - GB | - GB | - |
Storage / Flash | -- GB | -- GB | -- GB | --GB | - GB | - GB | - GB | - |
Display | ||||||||
Manifacturer: Model: Type: Resolution: Display aspect ratio: Pixel Format: Display Colors:: Luminance(cd/m²): Viewing Angle: Color Gamut: Contrast Ratio: Response speed (ms): Frame Rate: Life Time: | LG Display Professional Edition AM-OLED - Color Filter 3840(RG/BW)x 2160, UHD 16:9 (H:V) RGBW Vertical Stripe 1.07B (8-bit + Dithering) 500 (Typical) 60/60/60/60 (Typ.) 97% DCI-P3 150000:1 (Typ.) 14 (G to G); 8 (MPRT) 100/120Hz 30K (Typ.) (Hours). | LG Display -- AM-OLED - Color Filter 3840(RG/BW)x 2160, UHD 16:9 (H:V) RGBW Vertical Stripe 1.07B (8-bit + Dithering) 500 (Typical) 60/60/60/60 (Typ.) (Left, Right, Up, Down) 97% DCI-P3 150000:1 (Typ.) (Transmissive) 14 (Typ.)(G to G); 8 (Typ.)(MPRT) 100/120Hz 30K (Typ.) (Hours). After that time, the brightness may drop about 50% | Innolux - S-MVA 3840x2160, UHD 16:9 (H:V) RGB Vertical Stripe - - - - - - 100/120Hz 30K (Hours) | LG Display ? - IPS ? 3840x2160, UHD 16:9 (H:V) RGB Vertical Stripe - - - - - - - 30K (Hours) | Innolux - S-MVA 3840 x 2160, UHD 16:9 (H:V) RGB vertical Stripe 10-bit (8-bit + Dithering) - - - - - 50/60Hz 30K (Hours) | Innolux - MVA 3840 x 2160, 16:9 (H:V) RGB Vertical Stripe (8-bit + Dithering) - - - - - 50/60Hz 30K (Hours) | ||
Backlight Type: Local Dimming: | self-emitting pixels | - Local Dimming Pro | - - | Edge LED Local Dimming | Edge LED Frame Dimming | |||
Adaptive Backlight Dimming | - | - | AI HDR remastering | - | No | No | No | No |
HDR | ||||||||
HDR | HDR10+, HDR10, HLG, DolbyVision, HSP (HLG Photo) To playback HDR, a HDR source is required (H.264 or H.265(ST2084 or HLG format)). | HDR10+, HDR10, HLG | ||||||
Dynamic Scene Optimizer | Y(w/ Metadata Creation) | - | - | - | ||||
Picture Mode | - | - | - | - | Dynamic, Normal, Cinema, True Cinema, Custom, Sport, Game, DolbyVision (Vivid/Bright/Dark) | - | - | - |
Audio | ||||||||
Formats: | Dolby Atmos | No | ||||||
Surround: | Cinema Surround Pro | Cinema Surround | - | 830 - Cinema Surround Pro 820 - Cinema Surround Pro 810 - Cinema Surround Pro 800 - Cinema Surround | Yes | |||
Speaker Configuration: | 2 + 2 | Blade Speaker - Front firing | Down Firing | - | - | - | - | |
Speaker Type: | --- | --- | --- | - | - | - | - | - |
Power Output: | 140W (40 Wx2 + 20 Wx3) | 50W (2 x 15W + 2 x 10W) | 20W (2 x 10W) | - | 20W (2 x 10W) | 20W (2 x 10W) | ||
Sound mode: | Standart, Music, Speech, Stage, User, | - | - | - | Standart, Music, Speech, Stadium, User, | - | - | - |
Smart TV platform | my Home Screen 4.0 | - | - | - | ||||
Voice Personal Assistant Voice Guidance | Yes Yes | - | - | - | No | |||
EPG | Yes | |||||||
Tuner | Dual - DVB-T/T2/C/S2 | DVB-T/T2/C/S2 | ||||||
Twin Tuners | Yes | No | ||||||
TV Anywhere | Yes Due to network conditions or certain broadcaster restrictions, this function may not be available. | - | - | No | ||||
In-House TV Streaming (DVB-IP) | Y (Server / Client) | No | - | - | No | |||
Panasonic TV Remote Apps | Yes | - | - | No | ||||
Swipe & Share | Yes | - | - | No | ||||
Easy Mirroring | Yes | - | - | - | ||||
Network Contents Playback (DLNA) | Y (Server / Client) File formats that are not supported by your Network Contents server (DLNA compatible server, etc.) cannot be played. | Yes - Client | ||||||
IP Home Control | Yes | - | No | |||||
Media Player | Yes | |||||||
Teletext Reception | 2000P | 1500P | - | - | 1000P | |||
PVR External Media Recording | Y(w/ Rewind live TV) USB1 (HDD 5V-900mA MAX) This feature requires a USB hard drive or flash drive with a capacity of at least 160 GB. | - | - | Yes | ||||
Multi Window | 2T PAP/PIP/PAT PIP (Image embedded in the main image)• PAP (Side-by-Side Image)• PAT (Picture and Text Side by Side) PIP Function Note: Source Restrictions May Apply | - | - | No | ||||
HDAVI Control | Yes | No | ||||||
HDMI | Ver: 2.0b, 18Gbps, 2 (side), 2 (rear) | - | 2 (side), 1 (rear) | - | ||||
HDMI Supported features | HDMI (4K 60/50p with HDCP2.2) Audio Return Channel (Input 2) Auto low latency mode Viera Link (HDMI CEC) | - | - | - | ||||
HDMI Signal | - | - | - | - | - | - | - | - |
HDMI PC Signal support | 4:4:4 chroma UHD/60p/50p/30p/25p/24p 4:2:2 chroma UHD/60p/50p/30p/25p/24p 4:2:0 chroma UHD/60p/50p/30p/25p/24p DCI 4K (4096x2160) 60p,50p,30p,25p,24p, the actual resolution is 3840x2160 | - | - | - | ||||
USB Type A | 1 side USB 3.0 2 rear USB 2.0 | 1 side USB 3.0 1 rear USB 2.0 | ||||||
Bluetooth | Yes / HID / HOGP (keyboard / mouse) / A2DP (audio on / off) | - | - | No | ||||
Bluetooth Audio Link | Yes When a Bluetooth device is connected to the TV, it is possible that the Bluetooth audio output may not be synchronized (i.e. be delayed) with relation to the images on the screen. This is not a defect of the TV or the device. The delay time will differ depending on the device. | - | - | No | ||||
Audio L / R in: | Yes | - | - | - | ||||
Wi-Fi | Yes | |||||||
Ethernet RJ-45 | 1 | |||||||
CI (Common Interface) | 2 (CI Plus, Version 1.4, ECP) | 1 (CI Plus, Version 1.4, ECP) | ||||||
Scart Connector | No | - | ||||||
Component Video Input shared with Composite | RCA phono type x 1 (rear) | - | - | - | ||||
Digital Audio Output (Optical) | 1 (rear) | |||||||
Headphone Out | 1 x 3.5 mm (side switchable to Subwoofer) | 1 x 3.5 mm | ||||||
Satellite in One-cable function for DVB-S 2.0 JESS | 1 - Main, F-type female Yes 1 - Sub, F-type female | - | - | - | - | - | - | - |
Antena | 1 RF female | |||||||
Series | GZ2000E | GZ1500E | GZ1000E | GZ950E | GX940E | GX900E | GX800E | GX700E |
Panasonic GZW 954 – Hervorragendes Bild aus dem Hause Panasonic
Der brandneue 2019er Panasonic TX-65GZW954 kommt mit neuer und überragender Bild- und Klangkonzepten und wird durch Panasonics neusten HCX Prozessor unterstützt. Ausgestattet ist der GZW954 mit einem neuen UHD Master HDR OLED Panel mit 4K UHD Auflösung (4-fach HD). Dieses neue Panel ist gegenüber dem Vorjahr nochmals überarbeitet worden. Durch diese zusätzlichen Optimierungen erreicht der TX 65 GZW 954 eine beispiellose und naturgetreue Farbwiedergabe mit deutlich verbesserter Helligkeit von 1300 Nits.
Panasonic GZW 1004 – Das Beste Bild aus dem Hause Panasonic
Der brandneue 2019er Panasonic TX-65GZW1004 kommt mit neuer und überragender Bild- und Klangkonzepten und wird durch Panasonics neusten HCX Prozessor unterstützt. Ausgestattet ist der GZW1004 mit einem neuen UHD Master HDR OLED Panel mit 4K UHD Auflösung (4-fach HD). Dieses neue Panel ist gegenüber dem Vorjahr nochmals überarbeitet worden. Durch diese zusätzlichen Optimierungen erreicht der TX 65 GZW 1004 eine beispiellose Farbwiedergabe mit deutliche verbesserter Helligkeit von 1500 Nits.
Panasonic GZX 1509 – Das Beste Bild aus dem Hause Panasonic
Der brandneue 2019er Panasonic TX-55GZX1509 kommt mit neuer und überragender Bild- und Klangkonzepten und wird durch Panasonics neusten HCX Prozessor unterstützt. Ausgestattet ist der GZX1509 mit einem neuen UHD Master HDR OLED Panel mit 4K UHD Auflösung (4-fach HD). Dieses neue Panel ist gegenüber dem Vorjahr nochmals überarbeitet worden. Durch diese zusätzlichen Optimierungen erreicht der TX 55 GZX1509 eine beispiellose Farbwiedergabe mit deutlicher verbesserter Helligkeit von 1500 Nits.
Panasonic GZW 2004 – Das Beste Bild aus dem Hause Panasonic
Der brandneue 2019er Panasonic TX-65GZW2004 kommt mit neuer und überragender Bild- und Klangkonzepten und wird durch Panasonics neusten HCX Prozessor unterstützt. Ausgestattet ist der GZW2004 mit einem, von Panasonic, maßgeschneiderten und ganz neuen Master HDR OLED Professional Edition Panel mit 4K UHD Auflösung (4-fach HD). Dieses neue Panel wurde nochmals eigens von Panasonic Ingenieuren optimiert und zudem von Hollywood-Kolorist Stefan Sonnenfeld abgestimmt. Durch diese zusätzlichen Optimierungen erreicht der TX 65 GZW 2004 eine beispiellose Farbwiedergabe mit deutlicher verbesserter Helligkeit von 1500 Nits. Darüber hinaus kann die Helligkeit partiell um bis 30% gesteigert werden.
