-Samsung TV Line-up 2020-
JL_?
19 September 2008
15,415
Terra
Και Q(ueer) και T(ran)S(exual), πάει ολοταχώς για το pride 2020 η Samsung... :grinning-smiley-043
xavito
29 October 2008
8,991
CES: Samsung 2020 'Infinity Screen' QLED TV preview...https://nl.hardware.info/artikel/9843/ces-samsung-2020-infinity-screen-qled-tv-preview
μετάφραση google nl to en
8K LCD models:
Q950TS_(external One Connect Box,4.2.2 speaker configuration,65-, 75- and 85-inch)
Q900TS_(connections on the back of the TV_only available in the U.S.,goes up to 98 inches)
Q800TS_(connections on the back of the TV_55-, 65-, 75- and 82-inch)
4K LCD models:
Q95T
Q90T
Q80T
Q70T_(edge-lit)
Q60T_(edge-lit)
The edge-led models at the bottom of the QLED range get a new 'dual led' backlight, where LEDs with two different color temperatures are used. Samsung QLED models normally use blue LEDs with a color temperature of approximately 10,000 to 12,000 Kelving, the new dual-LED backlight uses yellow LEDs with a color temperature of 4000 to 5000 Kelvin and blue LEDs with a color temperature of "more than 20,000 Kelvin '. Thanks to this combination, the color temperature of the mixed backlight matches better with the desired white point of 6500 Kelvin, so that the LCD panels have to compensate less and the contrast of the Q60T and Q70T should be significantly higher than the edge led models of last year.
New TU series as a successor to the RU models
None Samsung’s 2020 screens support Dolby Vision, however they do boast refined active tone mapping, which is applied to both HDR10 and HDR10 plus on a frame-by-frame basis.
source:[nl.hardware.info]
source:[hardwarezone.com.sg]
source:[insideci.co.uk]
-Samsung’s midrange QLED LCD 4K TVs (in the new Q70T and Q60T and lifestyle series like "The Frame" ) are getting a dual-LED backlight to improve contrast and colours...https://www.hardwarezone.com.sg/tec...q70t-q60t-frame-qled-4k-tv-dual-led-backlight
...Versus typical LED-lit LCD TVs that use LEDs with a fixed colour temperature, Samsung says its dual-LED implementation enables the TV’s BLU to vary the color temperature until it finds one that best suits the content.
Light leakage is also reduced, which translates to a 27% increase in contrast in Movie mode.
Samsung bringing its vertical TV, The Sero, to global markets this year...https://flatpanelshd.com/news.php?subaction=showfull&id=1578281553
Samsung is announcing microLED TVs for a third time at CES 2020...https://flatpanelshd.com/news.php?subaction=showfull&id=1578279793
source:[flatpanelshd.com]
Samsung has launched three new ranges of 8K QLED TVs for 2020, namely the flagship Q950TS, the step down Q900T and the entry-level Q800T.
Key features on the Samsung Q950 include an ultra-thin design despite direct-lit LED backlighting with full-array local dimming, almost bezel-less "Infinity Screen" effect, AV1 codec support for Youtube 8K playback, satisfying CTA's 8K UHD specification of more than 50% contrast modulation (CM), as well as a host of sound improvements.
https://www.youtube.com/watch?v=gzpmQMkUgE0
source:[hdtvtest.co.uk]
https://www.youtube.com/watch?v=5scq4WjShEI
source:[avforums.com]
https://www.youtube.com/watch?v=btvg0S6tgEg
CES 2020 - Samsung Q950TS...https://www.lesnumeriques.com/tv-te...vec-un-systeme-audio-4-2-integre-n145469.html
28dc2777-samsung-q950ts-un-televiseur-qled-sans-bord-fin-et-avec-un-systeme-audio-4-2-integre__w800.webp
ea6047c7-samsung-q950ts-un-televiseur-qled-sans-bord-fin-et-avec-un-systeme-audio-4-2-integre__w800.webp
source:[lesnumeriques.com]
georget
31 March 2007
3,109
Λευκωσία
Αν και OLEDακίας πρέπει να το παραδεχτώ ότι η Samsung παρουσίασε πολύ ενδιαφέρον.... οι Infinity εμφανισιακά είναι πολύ ωραίες και οι Micro-Led φαίνονται πολύ ενδιαφέρον.
Stergios Giotas
4 November 2006
833
Ειλικρινά, δεν καταλαβαίνω την τακτική της συγκεκριμένης εταιρείας. Αντιλαμβάνομαι την ανάγκη να υποστηρίξει τα δικά της φορμά, αλλά από την άλλη το να λες στον καταναλωτή θα βλέπεις μόνο αυτά που θέλουμε εμείς εν έτει 2020 είναι κάπως. No Dolby Vision, No Atmos, No Dts, No Divx, στο τέλος ας τη μετονομάσουν από Samsung σε Noseolaung να ησυχάσουν. Τουλάχιστον, φέτος προσέθεσαν στη γκάμα τους και direct led μοντέλα.
georget
31 March 2007
3,109
Λευκωσία
Η Samsung τα τελευταία χρονια στην CES αναλώνεται σε κινήσεις εντυπωσιασμού παρα ουσίας. Παρουσίασε Infinity και Micro-Led . Πανέμορφες οι πρώτες, υποσχόμενες οι δευτερες αλλα καμια δεν απευθύνεται στον μέσο καταναλωτή. Πάντως αν κατάφεραν να διατηρήσουν την "ποιότητα" εικόνας των QLED στις Infinity μπράβο τους.
dpantos
27 December 2019
29
έχουμε καμία πιθανή ημερομηνία κυκλοφορίας των νέων μοντέλων του 20 ??? αξίζει να περιμένουμε ???
λέει πουθενά ημερομηνία κυκλοφορίας γιατί δεν βρήκα κάτι στο άρθρο .......
hristoslav2
8 January 2016
359
Varna, Bulgaria
https://www.4kfilme.de/q95t-q90t-q80t-q70t-q60t-samsungs-4k-qled-lineup-2020/
https://www.tvhifipro.com/noticias/gama-televisores-samsung-2020/
Q950TSQ800TS
TechnologyQLEDQLED
Resolution8K8K
BacklightFull Array 480 zonesFull array
Image processorAI Quantum Processor 8KAI Quantum Processor 8K
Brightness4000 nits2000 nits
HDR FormatsHDR 10+, HLG and HDR 10HDR 10+, HLG and HDR 10
Color depth10 bit panel10 bit panel
Ultra Black panelYesYes
Ultra Viewing AngleYesYes
Refresh rate120 Hz native120 Hz native
Panel typeMVAMVA
DimmingSupreme UHD DimmingSupreme UHD Dimming
Real Game EnhancerYesYes
4K HFR 120 fps--
Sound4.2.22.2
OtsYesYes
One connectYes-
Ambient ModeYesYes
Smart tvTizenTizen
Voice controlYes, premiumYes, premium
Voice assistantsGoogle Assistant, AlexaGoogle Assistant, Alexa
Inches available65, 75 and 8565, 75, 82 and 98
Q95TQ90TQ80TQ70TQ60T
TechnologyQLEDQLEDQLEDQLEDQLED
Resolution4K4K4K4K4K
BacklightFull arrayFull Array 96 zones Local DimmingFull Array 48 zones Local DimmingEdge LED Dual LEDEdge LED Dual LED
Image processorAI Quantum Processor 4KAI Quantum Processor 4KAI Quantum Processor 4KAI Quantum Processor 4KQuantum Processor 4K Lite
Brightness2000 nits1500 nits1000 nits--
HDR FormatsHDR 10+, HLG and HDR 10HDR 10+, HLG and HDR 10HDR 10+, HLG and HDR 10HDR 10+, HLG and HDR 10HDR 10+, HLG and HDR 10
Color depth10 bit panel10 bit panel10 bit panel8-bit panel + FRC8-bit panel + FRC
Ultra Black panelYesYesnonono
Ultra Viewing AngleYesYesnonono
Refresh rate120 Hz120 Hz120 Hz120 Hz
(60 Hz at 49 β€³)
60 Hz
Panel typeMVAMVAMVAMVAMVA
DimmingSupreme UHD DimmingSupreme UHD DimmingSupreme UHD DimmingSupreme UHD DimmingSupreme UHD Dimming
Real Game EnhancerYesYesYes (except 49 β€³)Yes (except 49 β€³)no
4K HFR 120 HzDo notDo notnonono
Sound--2.2.2 60W2.0 20W2.0 20 W
OtsYesYesYes (except 49 β€³)Do notDo not
Ambient ModeYesYesYesYesYes
Smart tvTizenTizenTizenTizenTizen
Voice controlYes, premiumYes, premiumYesYesYes
Voice assistantsBixbyBixbyBixbyBixbyBixby
Inches available55, 6555, 6549, 55, 6549, 55, 65 and 7543, 49, 55, 65 and 75
xavito
29 October 2008
8,991
Samsung has unveiled its full 8K TV lineup at the company's annual European Forum in Malta. The range-topper is the gorgeous Samsung Q950TS with "Infinity Screen" design. The step-down model is the Samsung Q900T that lacks the One Connect Box; while the entry-level model will be the Samsung Q800T.
Key features include full-array local dimming (FALD) direct-lit LED backlighting, QLED quantum dot colours with 100% DCI-P3 colour volume, Anti Reflection screen, as well as Object Tracking Sound Plus (OTS+) and Q-Symphony audio technologies.
HDMI 2.1 features supported include 4K@120Hz (8-bit 4:2:0), Variable Refresh Rate (VRR), Auto Low Latency Mode (ALLM) and enhanced ARC (eARC).
https://www.youtube.com/watch?v=Yry70-V_g2A
Samsung 2020 TV lineup LCD ...http://www.tvtest.pl/telewizory-samsung-2020-pierwsze-opinie/
μετάφραση google pl to en
source:[tvtest.pl]
Samsung announces TV and audio line-up for 2020...https://www.homecinemamagazine.nl/2020/02/samsung-kondigt-tv-en-audio-line-up-voor-2020-aan/
source:[homecinemamagazine.nl]
-All the details of Samsung's new QLED 2020 range: 8K ahead...https://www.dday.it/redazione/34125/samsung-qled-8k-2020-novita-gamma-4k
source:[dday.it]
-Samsung: the features (and prices) of the QLED TVs that we will see in 2020...https://www.hdblog.it/tv/articoli/n516798/samsung-qled-tv-2020-caratteristiche-prezzi/
source:[hdblog.it]
-We present you the complete TV and audio lineup from Samsung: TU7100, TU8000, TU85000, Q60T, Q70T, Q80T, Q90T, Q95T, Q800T, Q950T, The Sero, The Frame, The Serif, HW-650T, HW-Q60T, HW-Q70T, HW-Q800T and much more.
https://www.youtube.com/watch?v=1ApiwVYHkRg
Samsung 2020 line-up of 8K and 4K "QLED" LCD TVs
Dynamic Crystal Display,QLED : marketing terms for Wide Color Gamut -WCG- tvs.
TU71000 (PurColor-Crystal display,50Hz )
TU8000 (PurColor-Crystal display,50Hz,one remote )
TU8500 (Dynamic Crystal Display with Edge LED(Dual),50Hz)
Q60T (4K QLED LCD tv with Edge LED (Dual) + 50Hz)
Q70T (4K QLED LCD tv with Edge LED (Dual) + 100Hz)
Q80T (4K QLED LCD tv with Direct LED FALD + 100Hz,except 49" 50/60Hz)
Q90T (4K QLED LCD tv with Direct LED FALD + 100Hz)
Q95T (4K QLED LCD tv with Direct LED FALD + 100Hz + One Connect Box)
Q800T (8K QLED LCD tv with Direct LED FALD + 100Hz + HDMI 2.1)
Q950T (8K QLED LCD tv with Direct LED FALD + 100Hz + HDMI 2.1 + One Connect Box)
The Sero (4K QLED LCD tv with dual LED + rotatable display)
The Frame (4K QLED LCD tv with Dual LED)
The Serif (4K QLED LCD tv)
Note: Unfortunately, we do not go into HDMI compatibility in the video (ash on our head). The 8K QLED TVs Q800T and Q950T support HDMI 2.1 including eARC, ALLM and VRR. The 4K QLED TVs, on the other hand, rely entirely on HDMI 2.0 with eARC, from the Q70T series even with ALLM and VRR).
source:[4kfilme.de]
-Range of TV models and recommended prices (in euros)_Samsung_Belgium
file.php
source:[avcesar.com]
Αρχικές ενδεικτικές τιμές Samsung LCD tvs 2020 (29.03.2020) στην ελληνική αγορά:
QE85Q950TS : 13.199
QE75Q950TS : 8.799
QE65Q950TS : 6.599
QE82Q800T : 7.699
QE75Q800T : 5.999
QE65Q800T : 4.399
QE55Q800T : 3.299
QE85Q95T : 6.599
QE75Q95T : 4.899
QE65Q95T : 3.199
QE55Q95T : 2.399
QE75Q90T : 4.399
QE65Q90T : 2.799
QE55Q90T : 2.199
QE85Q80T : 5.499
QE75Q80T : 3.799
QE65Q80T : 2.399
QE55Q80T : 1.799
QE50Q80T : 1.449
QE49Q80T : 1.499
QE75LS03T : 3.799 The Frame v.2020
QE65LS03T : 2.399
QE55LS03T : 1.799
QE50LS03T : 1.499
QE43LS03T : 1.299
QE32LS03T :
QE55LS01TA : 1.599 The Serif
QE49LS01TA : 1.399
QE43LS01TA : 1.299
QE85Q70T : 4.399
QE75Q70T : 2.999
QE65Q70T : 1.799
QE55Q70T : 1.399
QE85Q60T : 3.799
QE75Q60T : 2.399
QE65Q60T : 1.599
QE55Q60T : 1.199
QE50Q60T : 999
QE43Q60T : 799
UE65TU8502 : 1.349
UE55TU8502 : 949
UE50TU8502 : 829
UE43TU8502 : 679
UE82TU8072 : 2.799
UE75TU8072 : 1.699
UE65TU8072 : 949
UE55TU8072 : 699
UE50TU8072 : 599
UE43TU8072 : 489
UE75TU7172
UE70TU7172
UE65TU7172
UE55TU7172
UE50TU7172
UE43TU7172
UE65TU7072 : 899
UE55TU7072 : 649
UE50TU7072 : 549
UE43TU7072 : 449
UE32T5302 : 329
UE32T4302 : 279
-Samsung LCD tvs 2020: prices and dates of the new lineup (Germany)
GQ85Q950TSTXZG 11.999
GQ75Q950TSTXZG 7.999
GQ65Q950TSTXZG 5.999
GQ82Q800TGTXZG 6.799
GQ75Q800TGTXZG 5.299
GQ65Q800TGTXZG 3.799
QE55Q800T : 2.999
GQ85Q95TGTXZG 5.799
GQ75Q95TGTXZG 4.499
GQ65Q95TGTXZG 2.899
GQ55Q95TGTXZG 2.199
GQ75Q90TGTXZG 3.999
GQ65Q90TGTXZG 2.699
GQ55Q90TGTXZG 1.999
GQ85Q80TGTXZG 4.799
GQ75Q80TGTXZG 3.499
GQ65Q80TGTXZG 2.199
GQ55Q80TGTXZG 1.599
GQ49Q80TGTXZG 1.399
GQ85Q70TGTXZG 3.999
GQ75Q70TGTXZG 2.699
GQ65Q70TGTXZG 1.799
GQ55Q70TGTXZG 1.299
GQ85Q60TGUXZG 3.199
GQ75Q60TGUXZG 2.199
GQ65Q60TGUXZG 1.499
GQ58Q60TGUXZG 1.199
GQ55Q60TGUXZG 1.099
GQ50Q60TGUXZG 899
GQ43Q60TGUXZG 749
GQ32Q50RGUXZG 699
GU65TU8509UXZG 1.199
GU55TU8509UXZG 849
GU50TU8509UXZG 699
GU43TU8509UXZG 579
GU82TU8079UXZG 2.799
GU75TU8079UXZG 1.599
GU65TU8079UXZG 999
GU55TU8079UXZG 699
GU50TU8079UXZG 599
GU43TU8079UXZG 499
GU75TU7199UXZG 1.399
GU70TU7199UXZG 1.099
GU65TU7199UXZG 899
GU58TU7199UXZG 749
GU55TU7199UXZG 659
GU50TU7199UXZG 549
GU43TU7199UXZG 449
GU75TU7079UXZG 1.299
GU65TU7079UXZG 799
GU55TU7079UXZG 569
GU50TU7079UXZG 469
GU43TU7079UXZG 399
GQ75LS03TAUXZG 3.499
GQ65LS03TAUXZG 2.199
GQ55LS03TAUXZG 1.599
GQ50LS03TAUXZG 1.399
GQ43LS03TAUXZG 1.199
GQ32LS03TAUXZG (FHD) 549
GQ43LS05TAUXZG 1.599
GQ55LS01TAUXZG (white) 1.399
GQ49LS01TAUXZG (white) 1.199
GQ43LS01TAUXZG (white) 1.099
GQ55LS01TBUXZG (blue) 1.399
GQ49LS01TBUXZG (blue) 1.199
GQ43LS01TBUXZG (blue) 1.099
source:[4kfilme.de]
-We interviewed Craig Cunningham, senior product strategy manager for Samsung Europe, talking about the South Korean brand's 2020 TV lineup (including 8K & 4K QLED), eARC firmware update for last year's Q90R television, lack of Dolby Vision support, as well as other lifestyle displays (The Frame, Serif & Sero).
This video was filmed and uploaded in HLG HDR, so please watch on a compatible HDR display for the best experience.
https://www.youtube.com/watch?v=NMI7nqS61nI
-Samsung unveils its 2020 line-up of 8K and 4K "QLED" LCD TVs...https://flatpanelshd.com/news.php?subaction=showfull&id=1581922986
-Samsung's most advanced "QLED" LCD tech is now reserved for its 8K TVs...https://flatpanelshd.com/news.php?subaction=showfull&id=1581925126
-At the Samsung European Forum in Malta, the South Korean brand also announced its 4K QLED TV lineup. The top model is the Samsung Q95T which is very similar to last year's Q85R in terms of the number of local dimming zones and provision of One Connect Box as well as Anti Reflection Screen. US model number may be different, likely Q90T.
The European step-down model is the Samsung Q90T which lacks the One Connect Box. Specs-wise, it's similar to 2019's Q80R, featuring full-array local dimming (FALD) direct-lit LED LCD backlighting, Anti Reflection Screen, and a central stand.
The Samsung Q80T is the successor to last year's Q70R, with FALD but no Anti Reflection Screen. The Q70T and Q60T are both edge-lit LED LCDs with "Dual LED" technology to improve contrast & viewing angles.
Samsung's 2020 4K TVs will have HDMI 2.0b inputs with certain HDMI 2.1 features supported, such as VRR (Variable Refresh Rate), ALLM (Auto Low Latency Mode) and eARC (enhanced Audio Return Channel). To get 4K@120fps support, you will have to step up to the 8K range such as the Q800T, Q900T or Q950T.
https://www.youtube.com/watch?v=Yis6620nR3s
-Samsung tvs 2020 - the first opinions and controversies...http://www.tvtest.pl/telewizory-samsung-2020-pierwsze-opinie/
source:[tvtest.pl]
-Samsung 2020 TV line-up...https://www.flatpanelshd.com/article.php?subaction=showfull&id=1585564505
georget
31 March 2007
3,109
Λευκωσία
Πάντως η Samsung για ακόμη μια φορα δέχεται κράξιμο για 2 λόγους. Ο πρώτος είναι ότι παραπλανεί με τα νέα μοντέλα. Έχει αλλάξει την σειρά. ΠΧ αντικαστάτης της Q60R είναι η Q70T, της Q70R είναι η Q80T κλπ.
Βασικά είναι ότι πληρώνεις μεγαλύτερη σειρά και στην ουσία παίρνεις μικρότερη.
Ο δεύτερος ο λόγος είναι ότι αν θέλεις την αντικαταστάτη της Q90R που ήταν πέρσι το κορυφαίο μοντέλο πρέπει να πας αναγκαστικά σε 8K με ψηλότερη τιμή.
xavito
29 October 2008
8,991
xavito
29 October 2008
8,991
55"...[rtings.com]...Samsung UN55TU8000F review...https://www.rtings.com/tv/reviews/samsung/tu8000
UN55TU8000F: VA panel RGB-vertical stripe,50/60Hz
...Like the RU7100, small highlights in dark scenes are dimmed by the TV's frame (CE) dimming feature, which can't be disabled,...
https://www.youtube.com/watch?v=c31ie4F8HJ8
Made in Mexico
65"...[Abt Electronics]...Samsung UN65TU8000 first look
https://www.youtube.com/watch?v=dV4-_llCe7E
65"...[Abt Electronics]...Samsung UN65TU7000 first look
https://www.youtube.com/watch?v=l6bqqp0ovI4
