To **Επίσημο** Νήμα του Raspberry Pi
tmjuju
Administration Team
21 January 2007
21,651
Ο υπολογιστής των $25 ?
http://www.raspberrypi.org/
The Raspberry Pi Foundation is a UK registered charity (Registration Number 1129409) which exists to promote the study of computer science and related topics, especially at school level, and to put the fun back into learning computing.
We plan to develop, manufacture and distribute an ultra-low-cost computer, for use in teaching computer programming to children. We expect this computer to have many other applications both in the developed and the developing world.
Our first product is about the size of a USB key, and is designed to plug into a TV or be combined with a touch screen for a low cost tablet. The expected price is $25 for a fully-configured system.
How would you use an ultra-low-cost computer? Do you have open-source educational software we can use? Contact us at [email protected].
Provisional specification:
• 700MHz ARM11
• 128MB of SDRAM
• OpenGL ES 2.0
• 1080p30 H.264 high-profile decode
• Composite and HDMI video output
• USB 2.0
• SD/MMC/SDIO memory card slot
• General-purpose I/O
• Open software (Ubuntu, Iceweasel, KOffice, Python)
Μακάρι να κυκλοφορήσει!
Όντος πρόκειται για έξυπνη ιδέα, μικρή τιμή και σίγουρα από επεκτασιμότητα μπορεί να πάει μακριά…
http://www.bbc.co.uk/blogs/thereporters/rorycellanjones/2011/05/a_15_computer_to_inspire_young.html
http://www.geek.com/articles/games/...braben-creates-a-usb-stick-pc-for-25-2011055/
Portioli
3 June 2007
3,900
Dystopia
Raspberry Pi: the Upcoming $25 1080p-Capable ARM-Based Hobby Computer
http://www.avsforum.com/avs-vb/showthread.php?t=1375757
$25 1080P-CAPABLE ARM-BASED HOBBY COMPUTER
Re: Raspberry Pi: the Upcoming $25 1080p-Capable ARM-Based Hobby Computer
Πολύ ενδιαφέρον για τους hard core κομπιουτεράδες, καθότι είναι πρακτικά τζάμπα και μπορεί να προσφέρει ατελείωτες ώρες προγραμματιστικής χαράς. :D
Για τους HTPCάδες μάλλον είναι πολύ περιορισμένο, τη στιγμή που οι περισσότεροι θέλουν να τρέχουν και ένα XBMC ή έναν ζόρικο renderer.
Λογικά όμως θα βρει χρήση σαν embedder συσκευή σε τηλεοράσεις.
tmjuju
Administration Team
21 January 2007
21,651
Απάντηση: Raspberry Pi: the Upcoming $25 1080p-Capable ARM-Based Hobby Computer
Καλά οι τηλεοράσεις μας σε λίγο καιρό θα έρχονται με 12 πύρινους υπολογιστές όπως το πάνε το πράγμα :D
Portioli
3 June 2007
3,900
Dystopia
Libraries, codecs, OSS
Codecs
Two licensed codecs will be provided at launch, MPEG4 and h.264. Codec licences have quite an impact of the cost of the device which is why there are only two at this stage. There are non-licensed Codecs such at MPEG2, VC1 etc, but for the moment they will not be accelerated by the GPU.
Dom adds: As an aside, the GPU can hardware decode H264, MPEG1/2/4, VC1, AVS, MJPG at 1080p30. It can software (but still vector accelerated) decode VP6, VP7, VP8, RV, Theora, WMV9 at DVD resolutions. We are restricted due to licensing what we can support. We should be able to support VP8, MJPG and Theora, as I believe they are license free.
Open vs Closed Source
The Open/Closed source debate can become quite heated, as those perusing the comments and forums may have noticed. As stated above, the host side libraries for the graphics acceleration are closed source and are provided by the SoC supplier. The Foundation has no control over the closed nature of these libraries. Since the vast majority of people simply use libraries such as these, it was deeded a trade off worth making to get the high graphics performance. It’s worth noting there are no other SoC devices with a similar graphics performance that are open source. There is no GPL issue here, these are user side libraries not linked in any way to the kernel.
There are a few drivers for the SoC which are linked in to the kernel, these are GPLed and hence OSS. One of these drivers is the interface from the user space libraries to the GPU. The user side libraries use this ‛driver’ to communicate with the GPU and tell it what to do.
Here’s a handy diagram that may help visualise what’s what.
έχει ωραίες συζητήσεις από κάτω στα comment.
Want to pre-order your Raspberry Pi?
http://www.element14.com/community/groups/raspberry-pi
Technical Documents for Raspberry Pi
Robert Mullins, Co-Founder, Raspberry Pi Foundation Introduces Board B
lykman
29 June 2006
5,798
Aθήνα
η δική μου σκέψη είναι με ένα τέτοιο προϊόν, να μετατρέψω την τηλεόραση μου σε κάτι πιο... smart. Βασικά να έχει πρόσβαση στο νετ, αλλά και μέσα από browser, να έχω εικόνα από την ΙΡ κάμερα μου από το δωμάτιο των παιδιών... ψήνομαι να πάρω ένα πάντως. (είχα δει και άλλο, ένα σαν usb στικ με android... είχε ανέβει και στο φόρουμ, αλλά φαντάζομαι η τιμή θα είναι αλλού σε σχέση με το Ρi)
Babis110
27 November 2010
192
+1 σε αυτά που λέει o lykman (εκτός απο τα παιδιά, μιας και δεν έχω ακόμα!)
Δεν ξέρω αν κατάλαβα καλά, αλλά ακόμα δεν μπορεί να υποστηρίξει όλα τα format εικόνας ή μπορούμε να παρακάμψουμε αυτό το πρόβλημα με την χρήση codecs? Λέτε να παίζει και 3d?!?!?!?!?! :Banane0:
Portioli
3 June 2007
3,900
Dystopia
OpenELEC for Raspberry Pi
The guys at OpenELEC, an embedded OS built specifically to run XBMC, have announced their first ARM port and with it, support for Raspberry Pi. (Please note that although their website says that they can only support the Model B, the post was written just before we announced the upgrade doubling the Model A’s RAM.) I’m a week or so late to the party on this – apologies to Gimli and Stephan for the delay in posting this while we wrestled with launch stuff here.
When a download is available (which should be pretty soon, and I should point out that we have been the limiting factor here; we need to get one of the boards with a replaced magjack out to the guys so they can test it on a production board – that’s Gimli’s alpha board you can see in the video), we’ll be hosting it on our downloads page.
πηγή : http://www.raspberrypi.org/archives/810
naxian
30 October 2007
1,091
HTPC killer :) Αν δουλευει σωστα δεν χρειαζεται να στηνουμε ολοκληρο pc!!!!!!
lykman
29 June 2006
5,798
Aθήνα
Απάντηση: Re: Raspberry Pi: the Upcoming $25 1080p-Capable ARM-Based Hobby Computer
Ε, ΟΚ είπαμε: δεν ξέρουμε τι κάνει με τον ήχο (τώρα τα HD audio ας μην τα αναφέρω καν, μιλάω μόνο για downmix ή passthrough από απλό AC3 / DTS 5.1 αν έστω μπορεί να κάνει), δεν ξέρουμε πως τα πάει από κίνηση και 23,976... και όλο και άλλα θέματα ίσως να υπάρχουν. Και καταλήγω στο εξής: Το θέλω!!
Τη στιγμή που εγγυημένα δεν παίζει με MadVR, δεν θα παίζει μενού σε BD και κατά πάσα πιθανότητα θα έχει θέματα και με DTS-MA κτλ, τα HTPCs μάλλον είναι ασφαλή.. ;)
naxian
30 October 2007
1,091
για htpc στην κρεβατοκαμαρα ειναι τελειο...μενου ουτε τωρα-ακομα παιζει το xbmc..... αν θα περναει ηχος και εικονα για ολα τα φορμα στην Τ.Β θα ειναι οτι πρεπει εκει στα 30-35 ευρα :)
kernel panic
18 November 2008
970
Κεφαλλονιά
μπαααα
μην χαρείτε
no mpeg2 από hardware
εντωμεταξύ ο ελληνας αντιπρόσωπος τα πουλάει (όταν έρθουν) προς 60 + ΦΠΑ :bang:
Portioli
3 June 2007
3,900
Dystopia
κάτι άσχετο επειδή αναφέρεται συχνά σαν μειονέκτημα είτε για το XMBc είτε για το Openelec, ειτε για τoυς DsPlayers & τα DsFilters.
Tα BD μενού και το DTS-MA θέλουν λεφτά. Είναι κλειστά φορμά. H arcSoft και η Cyberlink πληρώνουν για αυτά.
απο θεμα δύναμης επεξεργαστή στην χειρότερη πρέπει να είναι λίγο πιο δυνατό
από το μεσσαίο το αρμάντα ή το αλλο που έχει το apple tv 2,
Δηλαδή οπως ελεγε και το video της guardian για stable λειτουργία 1080p δεν το βλέπω.
Kάτι τελευταίο που δεν ξέρω αν θα μπορούσε κάποιος εδώ να απαντήσει.
Οι εταιρείες των CE , τα μεγάλα τα armada πόσο τα αγοράζουν?
Ποσο να είναι η τιμή χονδρικής?
Η oppo πχ σιγά μην τα αγοράζει πιο ακριβά :p
Απο την άλλη ίσως τα παραλέω λίγο για τα 1080p
γιατί είναι 2 χρονιες νεότερο απο το armada το 1000.
Θα δούμε , ελπίζω σε λίγο καιρό και από πρώτο χέρι
γιατί άλλο τι βλέπει ενας κομπιουτεράς κι αλλο ενας videophile.
