1080p HDMI HDTV H.264 DTS MKV DLNA Network Media Player
oxygen
17 April 2011
16
This Full-HD 1080p media player is a powerful USB and network HD media player which truly decodes, playback and outputs High Definition 1080p videos through HDMI interface. This player is able to play the HD MPEG2, HD VC-1, HD AVC/H.264, Blue-Ray ISO movies from external USB/internal hard drive devices to HDTV screen. The advanced Network function allows you to browse the video file from your PC or NAS in your study room and play it on TV in the living room. The player also support NAS function with build in Samba Server, which is able to share the whole USB storage device to the network, so you can easily access you media files via your computer.
Besides, you can also install extension plugin to this player and enable the BitTorrent downloading function. Then you can download movies without your computer.
We also have the USB 802.11n wireless Dongle for this media player. Just plug this dougle into USB port on this player and enable the wireless function, then you can easily enjoy playback your movie from your computer or NAS server wirelessly.
Please NEVER use other firmware to upgrade this player, it may make this player become brick. Please check us for new firmware
*You need install the NAS and BitTorrent Downloading plugin to enable such function
Realtek RTD1073 DD C+ Full-HD Digital Media Processor.
Compatible with almost all media formats
Support DTS HD Master/Dolby True HD RAW output.
Ethernet port supports Network player function.
NAS function share the USB drive to the network and copy/delete/edit files through your computer.
Internal 3.5" SATA hard drive slot
Simple hdd rack design, install/unistall HDD quickly and easily
USB to PC port, connect to your PC and work as external hard drive.
Built-in anti-dust card reader(SD/MMC/MS memory card, supports SDHC card)
High performance video playback. Experience fluent playback control like Zoom out/in, Pan the picture, Fast Forward, Fast Reverse, Slow-motion.
Fully supports the subtitle format. Dynamically change the subtitle display by remote control.
Photo playback via HD. Supports Up to 40 mega-pixel photo files, 16X Zoom in, 3-direction rotation.
Supports external USB DVD/Blue-ray drive
Connect USB DVD/Blue-ray optical drive to this player via USB port, then you can play RBD/MINIBD/DVD/VCD/CD/BD25/BD50 disks
Fully compatible with AVCHD/BD ISO
Could display Blue-Ray PGS subtitle
Playback TS, M2TS without interval(seamless playing)
Parent Control function
Powerful subtitle function(you can adjust subtitle track/codec/font size/color/positioin)-This function works with external subtible only
Full metallic case provides best protection from overheating and reduces electro-magnetic interference.
Player dimension: 190mm x 173mm x 64mm
If you need an USB 802.11n Wi-Fi adapter for this player, please check our store or contact us.
Specification:
CPU: Realtek RTD 1073 DD C+ 400MHz MIPS
DDR2 SDRAM: 128MB
NAND FLASH: 256MB
Video Output:
Decode and output High Definition 1080p video and Photo.
Support Mainstream formats of HD video including MPEG-2, VC-1, H.264/AVC and RMVB HD.
HDMI1.3 output,resolutions :480P, 576P, 720P@50Hz, 720P@60Hz, 1080I@50Hz, 1080I@60Hz, 1080P@50Hz, 1080P@60Hz
Y/Pb/Pr, resolution:480P, 576P, 720P@50Hz, 720P@60Hz, 1080I@50Hz, 1080I@60Hz, 1080P@50Hz,1080P@60Hz
Composite, Resolution, 567i@PAL, 480i@NTSC
Audio Output:
Stereo Output/Digital Optical Output/Coaxial Output
USB 2.0 Host:
USB host, 2 Ports, connect with various USB Devices directly.
Hot swap SATA Interface
Internal SATA Port for internal 3.5" SATA hard drive,up to 2TB SATA HDD
Simply slide the HDD tray out and insert the Hard drive, install hard drive in seconds. Once the internal HDD is full, you can easily swap with an secondary hard drive without using any screws or tools.
Network Connection:
Network 10/100 ethernet LAN, support playback via network.
Support USB WiFi Dongle, 802.11n (optional)
Support uPnP,SAMBA, BitTorrent downloading, allows users to stream their files from their PCs
File Management:
Support file copy/move/delete/rename function.
Video format:
RM / RMVB
MPEG1/2/4 Elementary (M1V, M2V, M4V)
MPEG1/2 PS (M2P, MPG)
MPEG2 Transport Stream (TS, TP, TRP, M2T, M2TS, MTS)
VOB
AVI, ASF, WMV
Matroska (MKV)
MOV (H.264), MP4, RMP4
IFO
FLV
BD-ISO, DVD-ISO
MINI BD,BD-9,BD25, RBD, D5, D9, DVD, CD
VideoCodec:
MPEG1,VCD1.0/2.0,SVCD(up to 1920*1080@30P/60I or 1280*720@60P)
HD MPEG2 MP/HL,ISO,IFO,VOB,TS(up to 1920*1080@30P/60I or 1280*720@60P)
HD MPEG4 SP/ASP,Xvid(up to 1920*1080@30P/60I or 1280*720@60P)
H.264 BP L3,MP L4.1,HP L4.1 (up to 1920*1080@30P/60I or 1280*720@60P)
WMV9,VC-1 AP L3(up to 1920*1080@30P/60I or 1280*720@60P)
DivX3/4/5(up to 1920*1080@30P/60I or 1280*720@60P)
XVID SD/HD(up to 1920*1080@30P/60I or 1280*720@60P)
RM/RMVB 8/9/10(up to 1280*720@30P)
Flash Video H.264, Sorenson H.263(up to 352*288)
Audio Format:
AAC, M4A
MPEG audio (MP1, MP2, MP3, MPA)
WAV
OGG
WMA
FLAC
APE
Audio Codec:
MPEG I Layer 1/2/3 (2-CH), MPEG II 1/2 (Multi-Channel)
LPCM, ADPCM, FLAC, AAC, WAV, OGG
DTS HD Master Aduio, LBR
Dolby Digital Plus/Dolby True HD
RA1/RA-cook/RA-Lossless
Sutitle Format:
.sub/.srt/.ssa/.smi/idx+sub/PGS subtitle
OSD Language*:
English/Simplified Chinese/Traditional Chinese/Portuguese/Japanese/Spanish/French/German/Italian/Turkish/Dutch/Russian/Polish/Thailand/Korean/Hungarian
Subtitle Language*:
Unicode(UTF-8)/Simplified Chinese/Traditional Chinese/Turkish/Japanese/Korean/Western/Greek/Hebrew/SE European/Central European/Cyrillic/
*Dolby Digital: "Dolby" and the double-D symbol are trademarks of Dolby Laboratories. Manufactured under license from Dolby Laboratories
*Additional formats & languages available in future firmware releases.
Packing Content:
1 x Fully HD 1080p HDD Media TV Player
1 x Power Adapter
1 x Power Cord
1 x Remote Control
2 x Screws
1 x USB Data Cable
1 x User Manual
1 x Software CD
http://cgi.ebay.co.uk/1080p-HDMI-HD...?pt=Home_Theater_in_a_Box&hash=item19c374c362 παιδια την γνωμη σας μια ερωτηση με εξωτερικο δισκο θα δουλευει? γιατι για τωρα δεν παιζουν αλλα λεφτα για δισκο. 80 euro εχει to media player (Composite/Componet/HDMI cable NOT included(optional HDMI cable for extra payment)
HDD NOT included
USB WiFi Adapter NOT included(optional for extra payment)
oxygen
17 April 2011
16
Specification:
DDR2 SDRAM: 128MB
NAND FLASH: 256MB
Video Output:
Audio Output:
USB 2.0 Host:
Network Connection:
File Management:
Video format:
RM / RMVB
VOB
AVI, ASF, WMV
Matroska (MKV)
IFO
FLV
BD-ISO, DVD-ISO
VideoCodec:
Audio Format:
AAC, M4A
WAV
OGG
WMA
FLAC
APE
Audio Codec:
Sutitle Format:
OSD Language*:
Subtitle Language*:
Packing Content:
1 x Power Adapter
1 x Power Cord
1 x Remote Control
2 x Screws
1 x USB Data Cable
1 x User Manual
1 x Software CD
HDD NOT included
dfoust
2 April 2009
785
ΧΙΟΣ
oxygen
17 April 2011
16
Re: Απάντηση: 1080p HDMI HDTV H.264 DTS MKV DLNA Network Media Player
καλύτερα πάρε από τον IntelligentPro αυτό
http://cgi.ebay.co.uk/1080p-Media-P...s_Video_HomeCinemaSystems&hash=item35b0aac13a
αυτό http://cgi.ebay.co.uk/1080p-HDMI-DL...127?pt=LH_DefaultDomain_0&hash=item3cafb5d12f
ή το himedia HD200A με 56 από τον ίδιο http://cgi.ebay.co.uk/USB-3-0-Porta...?pt=Home_Theater_in_a_Box&hash=item35b0e1dcb1
είναι τσεκαρισμένος όλοι το HD300A από τον ίδιο το πήραμε.
Σκεφτηκα να παρω το δευτερο απο τα παραπανω link, αλλα επειδη απο οτι βλεπω ερχεται απο κινα θα εχω προβλημα με τελωνειο με κινδυνο να πληρωσω περισσοτερα?
Επισης σκεφτομαι να παρω και αυτο το φλασακι. θα κανει?
dfoust
2 April 2009
785
ΧΙΟΣ
αν πάρεις καλύτερα να πάρεις το πρώτο που έχει και διπλό δέκτη mpeg4 για Digea και σαφώς καλύτερο τσιπάκι . το στικάκι θα κάνει μια χαρά.
και το τελωνείο μην το φοβάσαι κανείς δεν πλήρωσε προχώρα άφοβα
Μην φοβασε καθολου εγω εχω το δευτερο χωρις τον δεκτη.
Το εχω 2 μηνες τωρα το μηχανημα ειναι καταπληκτικο χωρις πολλα φρου-φρου.
Μακαρι να ειχα προλαβει βεβαια το κανουργιο με το δεκτη θα το επαιρνα σιγουρα για τα χρηματα που ζηταει.
mtlfn
16 October 2006
75
Για πειτε ρε παιδια γιατι κι εγω ενδιαφερομαι για δικτυακο ΜΡ και αυτο το πρωτο με το δεκτη που εχετε στο λινκ ειναι ενδιαφερον.
Υπαρχει καμια συγκριση με το popcorn A210-εκτος το θεμα του δεκτη-για το οποιο τοσα ακουγονται?
xrthammp
6 June 2008
495
Σύντομα αναμένεται και αυτό από την Himedia.
Himedia 600Α specs.
1) RTD1185 based media player,256MB DDR2, 256 memory
Flash,500Mhz CPU
2) Mini portable size without fan, could save more power, with no
noise
3) HDMI 1.3 to support 1080P Full HD playback and TRUEHD,DTS-HD MA
passthrough
4) Optical, coaxial digital and 2.0 analog audio output.
5) New User interface, with meida lib support, and Cover art for
movie list
6) Integrated Web Browser with keyboard and mouse supported
7) Web services such as YouTube, Picasa, RSS news and weather
8) DLNA Digital Media Receiver
9) Adobe Flash User interface can be upgraded
10) Ethernet 1000 Mb/s, supports internal wifi,and external USB
dongle
11) External SATA to connect HDD, DVDROM, and BDROM
12) Adobe swf file is supported
13) Black and White color for your choice
*** All the great stuff on your Iphone or Andriod — your music,
και αντίστοιχα το 600Β που παίρνει δίσκο και έχει ότι και το παραπάνω και επιπλέον
Himedia 600B specs.
1) All features same as above, except
2) VFD display panel & Smart Touch button
3) Initiative clamshell for Internal 3.5" HDD design
4) Built-In 802.11N WIFI and Optional USB WIFI Dongle
5) No FAN system , so no noise.
6)USB3.0 file transfer up to 5Gbps
*** High quality aluminum media Player with VFD, Touch-key and
Fanless design
lykman
29 June 2006
5,798
Aθήνα
φίλε xrthammp καλημέρα,
η σελίδα της εταιρίας είναι αυτή? http://www.netexplorer.gr/
υπάρχει στα πλάνα σας να φτιαχτεί ώστε με μια ματιά να ξέρουμε ανά πάσα στιγμή ποια player υπάρχουν και σε τι τιμή? Το 600Α π.χ. το θεωρώ ότι είναι από τα πιο hot που αναμένονται αυτή την στιγμή, αλλά δεν μπορώ να ψάχνω σε φορουμ για να βρω μια τιμή, ή κάποιο χαρακτηριστικό... (αν και αυτό μπορώ να το κάνω και από την διεθνή σελίδα).
xrthammp
6 June 2008
495
Κοίτα σωστή η απορία σου. Η προσέγγιση μας όμως είναι λίγο διαφορετική. Αντί να εντάξουμε τα προϊόντα μας στο εταιρικό site προτιμάμε να έχουμε το κάθε ένα ξεχωριστά. Έτσι μπορείς να επισκεφτείς το www.popcornhour.gr ή το www.iamm.gr (που επίσης είναι δικά μας) και να δεις αναλυτικές προδιαγραφές και μοντέλα. Για τα Himedia που είναι πολύ πρόσφατη αντιπροσωπεία ακόμα δεν έχουμε site αλλά το www.himedia.gr κάνει επανακατεύθυνση στο www.e-hw.gr που είναι και το εταιρικό μας eshop. Εκεί μπορείς να δεις και την δική μας διαθεσιμότητα αλλά και τις προτεινόμενες τιμές λιανικής που είναι και αυτές που κατά κανόνα ισχύουν και στους μεταπωλητές μας.
Ελπίζω να σε κάλυψα.
tasatva
18 June 2010
74
Τα mp που στέλνει είναι no-name ή τα HiMedia?
Εγγύηση, αν χτύπα ξύλο, πάθει κάτι σας δίνει αυτός ?
dfoust
2 April 2009
785
ΧΙΟΣ
Απάντηση: Re: Απάντηση: 1080p HDMI HDTV H.264 DTS MKV DLNA Network Media Player
himedia στέλνει
tasatva
18 June 2010
74
Και γιατί δεν αναφέρει εταιρεία και μοντέλο ?
Ας πουμε αυτό με το διπλό δέκτη η HiMedia έχει τα μοντέλα 500 και 560 ?
Για την εγγύηση καλύπτεσαι από τον εδώ αντιπρόσωπο ?
Σορρυ για τις πολλές ερωτήσεις, αλλα προκύπτουν από τη μη χρήση της φίρμας και η τόσο μεγάλη διαφορά τιμής
dfoust
2 April 2009
785
ΧΙΟΣ
Απάντηση: Re: 1080p HDMI HDTV H.264 DTS MKV DLNA Network Media Player
θα έχει τους λόγους του και δεν αναφέρει πιο μοντέλο είναι.
με μια ματιά που έριξα αυτό με τον διπλό δέκτη μου μοιάζει με αυτό http://www.ebluetimes.com/en/ProductView.asp?ID=167&SortID=171
με την εγγύηση όχι δεν σε καλύπτει.
