- 17 June 2006
- 4,700
Πωλούνται δύο (2) εγγραφείς ήχου μαζί με τα μικρόφωνά τους Tascam DR-10L.
Αγορασμένα από Athens Pro Audio τον Ιούνιο του 2020 (άρα εντός εγγύησης, υπάρχει και η απόδειξη αγοράς), έχουν χρησιμοποιηθεί μόνο σε ένα προτζεκτ, και είναι σε άψογη κατάσταση. Δεν υπάρχουν τα κουτιά τους.
The TASCAM DR-10L is an ultra-compact, incredibly convenient digital recorder/lavalier microphone combo. For added flexibility, the included wired lavalier microphone is affixed via a 1/8" screw-down lock connector compatible with most Sennheiser lavalier mics and mics with the same connector.
Designed for both the creative filmmaker and the busy videographer, the DR-10L is an immensely powerful problem-solving tool, delivering professional sonics and revolutionary convenience.
Ideal for location recording, a DR-10L can be mounted to each on camera actor, removing the need for booms, wires or expensive (an unpredictable) wireless systems. Perfect or live events, a DR-10L can be worn by each and every member of even the biggest wedding party to ensure that every last word is captured. And lastly, the combination of a portable, high quality digital recorder and a tiny, professionally spec’d microphone makes the DR-10L an inspiring tool for the experimental audio designer.
Εδώ το review από τον Curtis Judd
140 το ένα / 250 και τα δύο μαζί.
Αθήνα, αλλά αποστέλλονται οπουδήποτε με έξοδα παραλήπτη αφού προηγηθεί κατάθεση.
