- 13 April 2008
- 331
USR 9108 Wireless
Πωλείται ο Router USR 9108 Wireless MAXg.
Είναι σε άριστη κατάσταση και φυσικά λειτουργεί κανονικά.
Τεχνικά χαρακτηριστικά, σύμφωνα με την σελίδα του κατασκευαστή:
Τιμή: 39Ευρώ.
Συνάντηση στον σταθμό του Μετρό Νομισματοκοπείο ή στην Αρτέμιδα.
Για αποστολή Πανελλαδικά, έξοδα αποστολής παραλήπτη, 5,50Ευρώ.
Ευχαριστώ.
http://www.usr.com/products/broadband/broadband-product.asp?type=specs&sku=USR9108
Standards and Specifications
General
* MAXg Technology for up to 125 Mbps performance
* 802.11b/802.11g
ADSL
* ADSL2 (ITU-T G.992.3/ADSL2+ (ITU-T G.992.5): up to 24 Mbps†
* S=1/2 for up to 12 Mbps†
* Supports full-rate G.DMT (ITU-T G.992.1) and T1.413 Issue 2 ADSL: up to 8 Mbps downstream and up to 1 Mbps upstream†
* Supports G.lite (ITU-T G.992.2) ADSL: up to 1.5 Mbps downstream and up to 512 Kbps upstream†
* Supports DSL handshaking (ITU-T G.994.1)
* RFC 2516 PPP over Ethernet (Client)
* RFC 2364 PPP over ATM
* RFC 2684 (formerly 1483) Multi-protocol over ATM (Bridged and Routed)
* Annex A or B (ITU & ETSI)
* Multicast video streaming - VLAN
Wireless & Firewall Security Features
* Wi-Fi Protected Access 2 (WPA2)/802.11i
* Wi-Fi Protected Access, TKIP
* AES Encryption
* 64/128-bit Wired Equivalent Privacy (WEP) encryption
* SSID Broadcast Disabling
* 802.1x authentication
* WDS (Wireless Distribution System)
* Denial of Service
* IP Filtering – Destination for address or port and by IP protocol (outbound only)
* Syslog – Reporting of firewall events
* VPN Traversal (Pass-through IPSec, PPTP, L2TP)
* VPN termination upgradable
* SPI – Stateful Packet Inspection
* Password protected configuration access
* DMZ and virtual server support
Physical
* 2 dBi swivel dipole removable antenna with reverse polarity SMA connector
* 4 RJ-45, 10/100 auto-sensing/auto-switching Ethernet ports
* RJ-11 ADSL port
* USB 1.1/2.0 port (for attaching USB printer)
User Features
* IP Quality of Service (QoS)
* Dynamic DNS
* Parental Control (Time of Day & Days of Week)
Frequency Band
* 2400 ~ 2462 MHz for North America
* 2400 ~ 2483.5 MHz for ETSI
* 2454 ~ 2483.5 MHz for France, Outdoor 10mW
* RF Output Power: 19.8 dBm EIRP Average
Operating Channels
* 11 channels for North America
* 13 channels for ETSI
Regulatory
* EMI - FCC Class B
* Safety - UL, CUL
* EMI & Safety - CE Class B
Package Dimensions/Weight
* 11 x 3.8 x 8.9 in (27.94 x 9.66 x 22.6 cm)
* 3 lb (1.362 kg)
Product Dimensions/Weight
* 5.5 x 9.2 x 1.6 in (13.97 x 23.36 x 4.06 cm)
* 1 lb (0.454 kg)
Minimum Systems Requirements
* HTML configuration is supported by any computer that supports TCP/IP and HTML Web Browser (4.01 specification or greater)
* Ethernet networking requires computers with an installed network interface card (NIC)
* Print Service works with any printer that supports a page description language (e.g. PostScript, PCL, etc.)
Package Contents
* USRobotics Wireless MAXg ADSL Gateway
* Ethernet Cable
* Phone Cable
* Power Adapter
* Quick Installation Guide
* Installation CD-ROM
* Swivel Antenna
* Microfilter (included in some models)
Τιμή: 39Ευρώ.
Ευχαριστώ.
