παιδια επειδη ποτε μου δεν ασχοληθηκα με media players θα ηθελα την γνωμη σας για εναν media player που παρήγγειλα και ο οποιος εχει τα παρακατω τεχνικα χαρακτηριστικα
Specification:
Model: Bluetimes 3548-1186
CPU: Realtek 1186DD SoC, 1200 DMIPS MIPS Processor 750MHz
RAM: 512MB DDR3
Flash: 2M Byte Nor Flash, 4GByte NAND Flash
3D Formats Supported: Frame Packing(Blu-ray 3D), Side-By-Side(Left/Right), Over/Under(Top/Bottom), NOT work with Frame Sequential 3D
3D TV Supported: Active Shutter / Polarization 3D TV
Video Codecs Supported: RM/RMVB, H.264, VC1, WMV, MPEG 1/2/4, Divx, Xvid, Flash Video H.264
Video Formats Supported: BDMV, BD-ISO, MKV, MOV, WMV, TS, M2TS, MTS, FLV, AVI,
Video Formats Supported: DVD-ISO, VOB, M2P, MP4, MPG, DAT, ASF, TP TRP, SWF
Video Output Supported: 480i, 480p, 576i, 576p, 720p, 1080i, 1080p/24Hz, 1080p/50Hz, 1080p/60Hz
Audio Formats Supported: DTS-HD Master, DTS, Dolby True HD, Dolby Digital Plus,
Audio Formats Supported: AC3, LPCM, ADPCM, FLAC, APE,
Audio Formats Supported: LC-AAC, HE-AAC, MP3, OGG, WAM ,WAV
A/V Out: HDMI 1.4 interface up to 1080p
A/V Out: Composite Audio/Video
A/V Out: Y/Pb/Pr Video
A/V Out: SPDIF Coaxial (digital audio)
A/V Out: SPDIF Optical TOSLink (digital audio)
Storage Supported: Internal 3.5" SATA HDD rack to easily and quickly insert and exchange an internal 3.5" HDD
Storage Supported: USB external HDD/DVD ROM/BD ROM
Storage Supported: Can work as USB 3.0 external HDD with your computer
Media Cards Supported: SD, SD(HC), MMC, MS, MS Pro
USB Supported: 1 x USB 3.0 Slave Port
USB Supported: 3 x USB 2.0 Host Port
External SATA Port, connect SATA HDD/DVD/Blu-ray Drive to this player(Not work with original discs)
Wired Gigabit Network: RJ-45 Gigabit LAN 10/100/1000Mbps
Built-in 802.1b/g/n WiFi adapter with external antenna to get rid of the wired network bond(provide faster and stronger WiFi signals)
Subtitles Format Supported: SRT, SUB, idx+SUB, SSA, SMI, PGS subtitle
Subtitle Codecs Supported: Unicode (UTF8), ANSI, BIG5 (Traditional Chinese),
Subtitle Codecs Supported: Simplified Chinese, Western, Turkish, Central European,
Subtitle Codecs Supported: Greek, Cyrillic, SE European, Russian, Hebrew, Arabic, Japanese, Thai
Menu OSD Language: English, Simplified Chinese, Traditional Chinese, Japanese, Spanish,
Menu OSD Language: French, German, Italian, Korean, Dutch, Russian, Thai, Vietnamese
Image Formats Supported: JPE, HD JPEG, TIFF, PNG, BMP, GIF
Discs Formats Supported: RBD, MiniBD, AVCHD, DVD, VCD, CD
Dimension: 190 x 168 x 58mm (approx.)
Net Weight: 0.94kg
Package Weight: 1.6kg
