Ρίξτε μια ματιά στα review.Θεωρώ οτι η sony είναι καλύτερη επιλογή για ΤΗΛΕΟΡΑΣΗ. Κυρίως σε θέματα ομοιομορφίας banding-bleeding-clouding.Καθώς και σε επεξεργασία εικόνας αλλά και στο gaming.
Τώρα τα 3d και smart τετραπυρινα κτλ είναι να είχαμε να λέγαμε. Προσωπική άποψη πάντα.
http://www.avforums.com/review/sony-w8-kdl-50w829b-led-television-review.10178
No banding, no dirty screen effect? Are we sure this is LED?
But it wasn’t just with sports where the 50W829B looked great. Across the board, the deep blacks helped the Sony deliver images packed with clarity and contrasty punch and it was only from relatively acute viewing angles where colours washed out. Even lowly standard definition sources (we watch them only for test purposes, you understand) looked remarkably clean on the 50-inch panel, which is testament to Sony’s X-Reality Pro processing engine. Naturally HD is where it’s at but there are still some worthwhile movies yet to make the transition to Blu-ray disc.
Gaming:Using our specialised testing equipment we took measurements ranging between
19.5 to 22.3 milliseconds lag
http://www.avforums.com/review/samsung-h6400-ue55h6400-3d-led-lcd-tv-review.10295
There was a little bit of panel banding sometimes evident on panning shots but, other than that, general screen uniformity was good and the 3D output of the H6400 wasn't too far off matching that of the 2D, although we'd probably seek out some of Samsung's after market 3D eyewear, rather than use the included as they let in too much light for our liking.
Gaming:
As it was, the H64000 has a
lag to controller input of 40.6 milliseconds, which will be a fraction high for demanding online competitive gamers but will be fine for the average single player title.
