με βλεπω να μπαινω σε εξοδα,,το θεμα ειναι να κανω αυτο που λεω?
η να βαλω ενα ζευγαρι rs-42 ακομα? αν θυμαμαι τα 52 με τα 42 εχουν 210Ε διαφορα..γτ απο τα χαρακτηριστικα δν βλεπω τοση διαφορα?μπορει καποιος να συγκρινει να μου πει?
±±±±±±RS-42±±±±±±±
TIMH:390E
- Frequency response: 52Hz-23kHz ± 3dB
- Power handling: 75W RMS / 300W Peak
- Sensitivity: 93dB @ 2.83V / 1m
- Nominal impedance: 8 ohms compatible
- High frequency drivers: Dual 1" (2.54cm) Titanium diaphragm compression drivers mated to 90x60 square Tractrix® Horns
- High frequency crossover: 1700Hz
- Low frequency drivers: Dual 4" (10.2cm) Cerametallic™cone woofers
- Enclosure type: Bass-reflex via dual side-firing ports
- Height: 10" (25.4cm)
- Width: 10.75" (27.3cm)
- Depth: 7.75" (19.7cm)
- Mounting: Keyhole bracket and Dual 1/4"-20 threaded inserts
- Weight: 10 lbs (4.5kg)
- Finish: Matte Black vinyl
±±±±±±RS-52±±±±±±±
TIMH:600E
- Frequency response: 62Hz-23kHz ± 3dB
- Power handling: 100W RMS / 400W Peak
- Sensitivity: 95dB @ 2.83V / 1m
-High frequency drivers: Dual 1" (2.54cm) Titanium diaphragm compression drivers mated to 90°x 60° square Tractrix
- Low frequency drivers Dual 5.25" (13.3cm) Cerametallic
- Height: 33 cm
- Width: 32 cm
- Depth: 21.6 cm
- Weight: 6.8 kg
