The ARTA software consists of following programs:
The LIMP program is specialized for the loudspeaker impedance measurement and for the estimation of physical and Thiele-Small loudspeaker parameters.
http://www.fesb.hr/~mateljan/arta/index.htm
Αξίζει και μια ματιά στο http://www.fesb.hr/~mateljan/arta/support.htm
Enjoy
ARTA - program for the impulse response measurement and for real-time spectrum analysis and frequency response measurements.
STEPS - program for frequency response measurements with stepped-sine excitation.
LIMP - program for the loudspeaker impedance measurement and loudspeaker parameters estimation.
The ARTA program has functions of following measurement systems:STEPS - program for frequency response measurements with stepped-sine excitation.
Impulse response measurement system with signal generators: periodic white noise, periodic pink noise, MLS, linear and logarithmic swept-sine.
Dual channel Fourier analyzer with signal generators: white noise, pink noise, periodic white noise and periodic pink noise.
Single channel Fourier analyzer with signal generators: periodic white noise and periodic pink noise.
Spectrum, octave band and THD analyzer with signal generators: sine, two sine, multitone, white noise, pink noise, periodic white noise and periodic pink noise.
The ARTA program is also a powerful analyzer of:Dual channel Fourier analyzer with signal generators: white noise, pink noise, periodic white noise and periodic pink noise.
Gated frequency response,
Smoothed frequency response (in 1/n-octave bands),
Step response,
Impulse response envelope (ETC – curve),
Cumulative spectral decay curve and sonogram,
Energy decay in reverberant environments,
Room acoustical parameters,
Directivity patterns,
Speech intelligibility measures: MTF, STI, RASTI, %AL.
The STEPS program enables the measurement of the frequency response with a high dynamic range and a high noise immunity. Simultaneously with a frequency response measurement the STEPS estimates levels of 2nd, 3rd, 4th, 5th and higher order harmonic distortions. Smoothed frequency response (in 1/n-octave bands),
Step response,
Enjoy
