Audiolab M-Dac+
Gojakla
20 May 2009
5,856
Audiolab launches the premium version of the M-DAC this month. The new M-DAC+ will sell alongside the classic M-DAC,
sporting a number of enhancements both inside and out in return for an additional £200.
Like the M-DAC, the new M-DAC+ is a high-performance, multipurpose audio DAC (Digital-to-Analogue Converter) for home use,
designed to sit on a desk or table, or integrate into a hi-fi system. It incorporates an audiophile-quality digital preamp and Class A
output stage for connection to a power amp and speakers (the output can be fixed for use with an existing preamp or integrated amp).
A high-quality headphone output is also provided.
The new M-DAC+ is based firmly on the classic M-DAC, with carefully targeted improvements in key areas – a logical move,
given the original model’s sustained popularity over the last four years. Like the M-DAC, the M-DAC+ is built around the ESS Sabre32 9018, a 32-bit DAC chipset.
There’s a proprietary, discrete master clock to minimise jitter, coupled with extensive time domain isolation and there’s a A JFET Class A output stage.
Compared to the classic M-DAC, the most immediately obvious change is to the aluminium case and control scheme.
The M-DAC+ features a new chassis, with the OLED display window now centrally positioned and rounded at the sides, in keeping with
Audiolab’s recently launched 8300 Series components. The display is flanked by two rotary controls, one to adjust volume and the other to select
settings, replacing the buttons found on the classic M-DAC.
Under the hood lie a number of performance-related enhancements. The M-DAC+ now processes audio data up to 32-bit/384kHz via USB;
this is a far higher specification than that required by current hi-res music formats, ensuring this new addition to the M-DAC family is fully equipped
for future advances in ultra-high-definition digital sound.
The USB input now also supports DSD files (the digital audio system originally developed for Super Audio CD),
offering compatibility with DSD64, DSD128 and DSD256. This is a significant addition, as DSD has an important role to play
in the developing high-resolution downloading and streaming scene.
Like the classic M-DAC, the M-DAC+ features user-selectable filters for optimal listening and measurement modes,
in addition to more conventional types for easy comparison.
These filter settings allow the user to tune performance to suit his or her preference, depending on system configuration, digital file quality
and musical taste. The M-DAC+ inherits seven filter settings from the M-DAC for PCM files and adds four more for DSD playback, allowing the user
to optimise the noise floor to suit the performance of the source file and the bandwidth of associated equipment such as amps and speakers.
Another important change relates to the power supply, which has been upgraded and is now fully incorporated within the M-DAC+’s chassis
(hence its slightly taller and deeper case compared to the classic M-DAC). A precision-wound toroidal transformer uses multiple windings
to feed separate analogue and digital rectification stages. From there, multiple power supply sections feed the necessary voltages to each area of the DAC,
keeping any crossover interference to a minimum.
Around the back, digital input options have been expanded with an AES/EBU socket and an additional USB Type A input
(ideal for connecting Apple devices)€“ alongside the existing USB Type B connection. These join a full complement of inputs/outputs retained from
the classic M-DAC: 2x coaxial digital inputs; 2x optical digital inputs; 1x coaxial digital output; 1x optical digital output;
single-ended RCA and balanced XLR analogue outputs; 12V trigger loop.
The Audiolab M-DAC+ comes with a redesigned remote control and is available in black or silver from late-January 2016,
at an RRP of £799.95. The classic M-DAC continues at £599.95.
Πηγή.
DomieMic65
10 July 2006
9,692
εγώ έχω να πω πως σε κανά δυό χρόνια θα έχουμε καινούρια ντακ κάθε βδομάδα.....
πολύ όμορφο είναι ...
Gojakla
20 May 2009
5,856
Εγω παρατηρω τωρα πως το ασημι με το μαυρο δεν ειναι ιδια... sorry.
DomieMic65
10 July 2006
9,692
Ωχ όντως... για αυτό έγραψα πως δεν έχει εν/τη ακουστικών και μετά το έσβησα... θα έχει δυο μοντέλα δλδ;
zoukou
25 December 2007
68
Το μαύρο είναι το απλό από ότι φαίνεται και το ασημί είναι το PLUS.
Και διαφορετική οθόνη έχουν πάντως
Gojakla
20 May 2009
5,856
Η πρωτη φωτο ειναι λαθος. Αν μπορει καποιος (Σωκ) συντονιστης, ας την αντικαταστησει... :)
Παντως ανακοινωνουν και ανανεωση σε τελικους και σε ολοκληρωμενο. Φουλ γκαμα.
Η πλατη του μαυρου εχει ενδειξη DSD. Σιγουρα δεν προκειται για "απλο".
DomieMic65
10 July 2006
9,692
Το μαύρο είναι το σωστό... το ασημί δεν ξέρω τι είναι. Όχι το M-DAC+ πάντως
για φωτοσοπιά του Αντώνη το κόβω .... χαχαχ
10Ω αντίσταση εξόδου ...
sokmav
5 February 2012
14,227
Βρήκα ένα ασημί στην σελίδα της audiolab,κι αυτό διαφορετικό :flipout:
Οκ,βρήκα το σωστό,done!
bower
19 October 2010
497
Βασικα εχουν καταλαβει οτι, ειδικα για τα ντακ, τα μοντελα "παλιωνουν" καθε 2-3 χρονια, μειωνεται το hype και ο ντορος και οι πωλησεις πεφτουν. Ειδικα τωρα που ντακ βγαζει και η κουτση μαρια, υπαρχει 1 καινουργιο μοντελο απο καποια εταιρια καθε εβδομαδα. Οποτε αν θελουν να ειναι μεσα στην αγορα, δωστου νεα μοντελα.
Αντε να δουμε ποτε θα καταλαβουν οτι πρεπει να ριξουν το βαρος στη σχεδιαση των αναλογικων σταδιων και οχι στα τσιπ.
sokmav
5 February 2012
14,227
Τα καλά δεν παλιώνουν.
(Το λέω από συμφέρον,αυτό που ζαχαρώνω έχει 1704 επάνω,αρχαίο chip :flipout: )
ΚΩΣΤΑΣ ΖΑΓΓΟΓΙΑΝΝΗΣ
20 October 2007
17,845
Μεσευρώπη
Re: Απάντηση: Audiolab M-Dac+
+1. Άμα δείς τι τιμές πιάνουν κάτι παλιά ντακ της Sonic Frontiers ή της Theta Digital στο μπέι....
petronik
18,519
Θεσσαλονικη
Απάντηση: Re: Απάντηση: Audiolab M-Dac+
Ε γιατί το κρατώ το Sonic Frontiers SF D2 mk 2 πού έχω ; είναι σαν το παλιό κρασί ....
Βέβαια έχω αρχίσει να το σκέφτομαι να το αποχωριστώ ,εκτός αν το αναβαθμίσω σε mk 3 [με 1704 -8 τσιπ νομίζω ]
ΚΩΣΤΑΣ ΖΑΓΓΟΓΙΑΝΝΗΣ
20 October 2007
17,845
Μεσευρώπη
Re: Απάντηση: Re: Απάντηση: Audiolab M-Dac+
Αν πιστέψουμε τις φήμες το μόνο που μπορεί να το υποκαταστήσει είναι ένα Schiit Yggdrasil.
Gojakla
20 May 2009
5,856
Συμφορουμιτες μας που το ακουσαν δεν επαληθευσαν τις φημες παντως. Καλο dac βεβαιως, αλλα μαλλον οι φημες υπερεβαλλαν και δημιουργησαν ενα (ακομα) hype. Εγω παντως ομολογω πως θελω σαν τρελος να το ακουσω.
ΚΩΣΤΑΣ ΖΑΓΓΟΓΙΑΝΝΗΣ
20 October 2007
17,845
Μεσευρώπη
Αντώνη, για το Sonic Frontiers λες ή για το Yggdrasil;
