- 17 June 2006
- 12,625
To βρήκα τυχαία, είναι κάτι που παρακάλαγα να γίνει εδώ και χρόνια και να που η "επαγγελματική" σειρά της Denon το έκανε.
Ένας 7.1 προενισχυτής με XLR συνδέσεις. Η τιμή του θα είναι γύρω στα 1000
The DN-A7100 AV pre-amplifier is compatible the with most advanced surround sound formats, and because of its unique design, the DN-A7100 is ideal for any installation that requires high-quality, channel separated audio outputs - in particular those installations where adapting unbalanced RCA preamp outputs is completely unacceptable, or the extra weight of unused consumer power amps is not needed. Many installations now require surround sound decoding - From big installations with many multiple amps driving line array systems to small boardrooms and private theatres with active monitor systems, the Denon Professional DN-A7100 is the most affordable, professional option.
7.1 Balanced Line Level XLR Outputs (+4dB/-10dB - switchable)
Balanced XLR Auxiliary Audio Input (+4dB/-10dB - switchable)
HDMI Video Switching (ver. 1.1) (2 sources)
192kHz/24 bit Crystal® DAC for all 8 Channels
32 bit Digital Surround Processing Chipsets
Set-up menu via Video Outputs (Composite, S-Video, Component)
Video Convert Feature (Composite/S-Video to Component)
Dolby Digital EX, Dolby Digital, DTS ES (Discrete 6.1, Matrix 6.1, Neo:6) Decoding
Dolby Pro Logic IIx (Movie, Music, Game)
Circle Surround II (Movie, Music, Mono)
HDCD Decoding
RS-232C Terminal for System Control
Περισότερα στο http://www.d-mpro.eu.com/index2.php?lang=eng&main=prod&ver=&CID=3&sub=&action=detail&Pid=131&brand=2
HDCD Decoding
