AZBox Elite/Premium, part II
Karmakoma
19 February 2007
206
μπα ουτε και ετσι δεν εμφανιστηκε παραμενη αριστερα το εικονιδιο του δισκου με κοκκινο x
Αυτό το 192.168.1.77 είναι σίγουρα η ip του pc σου???
Το "movies HD" είναι το ακριβές όνομα του shared φακέλου???
Παρακάτω κάνω paste τι πρέπει να κάνεις στα windows 7 για να ενεργοποιήσεις το δίκτυο. Δοκίμασε το.
Start => Control Panel => Programs and Features => Turn Windows Features On or Off => tick the Media Features, Network stuff, Telnet Client, TFTP => OK.
Next, go to Start => Control Panel\All Control Panel Items\Network and Sharing Centre => click on Choose homegroup and sharing options => Choose the folders to share. Tick the option to "Stream your pictures, music and videos on my home network".
Click on Change Advanced Sharing Options. You are in Control Panel\Network and Internet\Network and Sharing Centre\Advanced sharing settings:
turn on network discovery
turn on file and printer sharing
stop the "Public Folder Sharing".
Go to Media Streaming Options, which is in Control Panel\Network and Internet\Network and Sharing Centre\Media streaming options => and there...
Name your media library [your nick, for instance]
Show devices in the local network => Allow all
Media programs etc. etc. => Allowed.
Go back [BACK button]:
leave the 128b encryption to on
turn off password protected sharing
allow Windows to manage homegroup connections.
Then, start your Windows Explorer and
find all the folders you want to share;
right click on each folder and go to Properties;
click on Share tab => click on the little arrow downwards to get the drop down menu and choose Everyone, then click on Add.
Give "Everyone" the permission to READ ONLY and click on Share.
You have more controls/options under Advanced Sharing button in the little window, too. Go to it and check the permissions etc. When you're done, in the main Properties little window, finish by clicking on Apply and Close.
tayros
26 December 2010
9
Απάντηση: Re: AZBox Elite/Premium, part II
φιλε αν εχεις ps με ασηρματο πληκτρολογιο δουλευη υπεροχα
thmls
29 April 2010
257
23.9E/38.0N
ok δουλεψε:drummer:
ευχαριστω για τον οδηγο:worshippy:
ακολουθησα το οδηγο και τα μονα που δεν ειχα τσεκαρισμενα ηταν το telnet client kai TFTP
και στο φακελο τον κοινοχρηστο το Everyone το ειχα READ και WRITE ενω ηθελε READ
τωρα τι εφαιγε δεν ξερω. το περιεργο ειναι οτι οπως το ειχα πριν στο official fw δουλευε
τωρα αμα φτιαξουν και τους υποτιτλους δυσκολα θα βαλω ξανα το official fw
mv_best
11 September 2010
534
ok δουλεψε:drummer:
τους φτιαξανε τους υποτιτλους...
pilotsvvv
14 January 2010
81
Παιδιά είμαι με την fw 5309 και αντιμετωπίζω πρόβλημα με το youtube το οποίο φορτώνει παίζει μερικές φορές αλλά μετά κολλάει και θελεί reboot ..... υπαρχει όντως πρόβλημα ας μου απαντήσει κάποιος...................................
mv_best
11 September 2010
534
Οσοι εχουν βαλει το spaze 2.0 μην κανουν την αναβαθμιση videohardware-fix γιατι θα εχουν μονο 720/p μεσω hdmi.Αναμενεται διορθωση.
Karmakoma
19 February 2007
206
Θέλει utf-8. Έφαγα μία ώρα να μετατρέψω όλους τους υπότιτλους αλλά χαλάλι.
Για πες μου, πως σου φαίνεται η εικόνα σε σχέση με το OF?
thmls
29 April 2010
257
23.9E/38.0N
εχω την εντυπωση πως του ofw ειναι καλυτερη στα ψηφιακα
αλλα μπορει να θελει καποια ρυθμιση στο video sittings
στο media center παιζει φοβερα
maggel
5 September 2010
21
Τι ωραια που θα ηταν να το ειχα δει αυτο πριν κανα 3ωρο. Τωρα σκ@τ@ παω για επανεγκατασταση. δοκίμασα να αντικαταστήσω το videohardware.py με ενα παλιότερο αλλα τιποτα. Τέσπα...
EDIT: Βγήκε Fix.
chris.px
13 July 2011
67
AzBox HD MC - Plugin το έχω κάνει εγκατάσταση ε2 αλλά δεν διαβαζη υπότιτλους [SRT Subtitle] λίγη βοήθεια,
maggel
5 September 2010
21
Αν εννοεις ελληνκους υποτιτλουσ οπωσ εχει αναφερθει πολλεσ φορεσ πριν, πρεπει να μετατρεπεισ τα srt απο ANSI σε UTF-8 encoding με το Notepad ++ το εκανα εγω.
Karmakoma
19 February 2007
206
Και επιπλέον τα αρχεία να έχουν την ίδια ονομασία.
thmls
29 April 2010
257
23.9E/38.0N
Notepad++ λίγη βοήθεια πως μπορώ να μετατρεπσο .srt σε utf-8
Εγκατεστησε το notepad++ και πανω στον υποτιτλο πατα δεξι κλικ ανοιξε με notepad++ μετα κωδικοποιηση μετα μετατροπη σε utf8
nakata
11 June 2007
2,230
var/etc/home
RTi Core v1.4 Enigma 2
Drivers of 18.11.2011
Enigma 2 of 18.11.2011
What is new:
- Many changes in smp8634dvb.ko main driver which will result in better overall stabillity, especially on audio part, faster zapping.
- Fixed audio selection in DVB part.
- New Media Center files inside, with new keymap and better support for PCM and RAW over HDMI, added support for some specific divx formats.
- Better support for Teletext and added caching support
- New keymap.xml in Enigma 2 and MediaCenter.
http://www.multiupload.com/14NTSI0EWZ
chris.px
13 July 2011
67
Notepad++ λίγη βοήθεια πως μπορώ να μετατρεπσο .srt σε utf-8 το έκανα αλλά τίποτα καπειο λάθος κάνω μπορείτε να μου δωσεται έναν υπότιτλο σε utf-8
