AZBox Elite/Premium, part II
Vag Vas
29 November 2008
65
Κερατσίνι
Προσοχή: όσοι περάσουν την 1.0.3 μην αλλάξουν στα A/V settings τίποτα γιατί μαυρίζει η οθόνη και θέλει από την αρχή πέρασμα το image.
makists
26 November 2010
75
Λύση:
Τροποποιήστε το "/etc/init.d/bootup" ως εξής:
insmod /lib/modules/2.6.22.19-19-the_ripper/extra/em8634dvb.ko options="-analog -f PAL_BG -digital -f HDMI_1080p50 -hdmi_chip $hdmichip 0 14 15 100 0"
#Vmode=`cat /etc/videomodeaz`
#if [ -n "$Vmode" ]; then
# insmod /lib/modules/2.6.22.19-19-the_ripper/extra/em8634dvb.ko options="$Vmode"
#else
# insmod /lib/modules/2.6.22.19-19-the_ripper/extra/em8634dvb.ko options="-analog -f PAL_BG -digital -f HDMI_720p50 -hdmi_chip $hdmichip 0 14 15 100 0"
#fi
Vag Vas
29 November 2008
65
Κερατσίνι
Απάντηση: Re: AZBox Elite/Premium, part II
Λύση:
#else
#fi
ok. thx!:a0210:
makists
26 November 2010
75
Και η έκδοση της DS TEAM με όλες τις διορθώσεις:
DS 3.0.3
based on RTi 1.0.3 BETA ( drivers + kernel )
DS ChangeLog:
- Fixes on Ds Devices Menu - now it recognize DOM, HDD and USB corretly.
- There is not possibility to FORMAT HDD and DOM. To format HDD please use Enigma2 Hard Drive Management
- Fixed Napiprojekt Subtitles Download ( Polish English )
- Fixed mouting points ( /mnt/usb, /mnt/usb2, /mnt/dom, /mnt/hdd)
- Fixed Wizard -> We use newer Wizard source code then RTi
- Fixed Blue Panel Button crash when there was not sat signal
- Some bugs on Wizard yet to choose HDMI, COMPONENT or SCART
www.dsteam.cwispy.com
RTi Changelog:
1.0.3
- Applied New Audio FIX
- Interlace/Deinterlace FIX
- CPU 30% usage FIX
- Better VFD Support
- Fixed System clock
- Volume UP/Down fully fixed
- Better overall stabillity
- A lot of changes on Enigma 2 ( A/V Settings EXPERIMENTAL , Welcome wizzard )
- Fixed Multimedia ( MKV, AVI ) now OK
- A lot of other small fixes and changes internally
http://www.speedyshare.com/files/25719169/ds_3.0.3_15.12.2010.rar
dbfan
23 April 2008
289
athens
DS 3.0.3
DS ChangeLog:
RTi Changelog:
1.0.3
- CPU 30% usage FIX
Την εχεις δοκιμαση φιλε???
Αν........ναι πες μας την γνωμη σου.
Regards dbfan
makists
26 November 2010
75
Record και timshift αναμένονται στην επόμενη έκδοση. Έχει και η έκδοση της DS Team τα κουσολυρια της. Είπαμε όλα μέχρι στιγμής είναι δοκιμαστικά, η επόμενη έκδοση λένε ότι θα είναι πολύ πολύ καλύτερη (φεύγουμε απο τις beta εκδόσεις).
Pstelios
28 September 2006
2,489
Καλημέρα, αν ξέρει κανείς πως περνάς στο Enigma "χρήσιμα" plugins και που τα βρίσκεις ας στείλει ένα pm.....
Κατά τα άλλα προσπαθώ να το δουλέψω, παρ'ότι έχω 5-6 χρόνια dreambox.....
Επίσης σε βαρύ scroll ( στα κανάλια π.χ ) τρώει κολλήματα, έλλειψη μνήμης?
mv_best
11 September 2010
534
κανε εγκατασταση αυτο DS 3.0.3 και ψαξτο λιγο(πρασινο κουμπι) κατι θα βρεις.:firstprize:
Pstelios
28 September 2006
2,489
Το 3,0,3 έβαλα..... αλλά πράσινο κουμπί δεν θυμάμαι να πάτησα.....
Ευχαριστώ πολύ!!! :BDGBGDB55:
nakata
11 June 2007
2,249
var/etc/home
μια μικρη απορια!!!αμα βαλω ενα usb hub στον δεκτη μπορω να βαλω παραπανω εξωτερικους σκληρους???
σε γνησιο λογισμικο ναι εγω εχω στην μια usb ενα στικακι για swap και στην αλλη ενα 7αρι hub με 3 σκληρους του ενος τερα και τους βλεπει και τους τρεις χωρις κανενα προβλημα
