Απάντηση: AZBOX Me & MINI ME
Πληροφορίες για το blindscan στο Aztrino 1.82NA
Currently, blind scan only supports the following LNBF types regardless of how your LNBF is configured in Antenna Setup:
- C-band using a 5150 LNBF either with or without a 22Khz switch
- Ku-band using a 10750 LNBF either with or without a 22Khz switch
- Ku-band using a 9750/10600 LNBF
Based on your system, here are the settings that need to be used:
10750 Ku-Band LNBF on the ON side of a 22Khz switch
In antenna setup:
- LNB low band frequency: 10750
- LNB high band frequency: 10750
- LNB switch frequency: 11700
In blind scan parameters:
- Start Frequency: 11700 or higher
- End Frequency: at least 10 MHz higher than Start Frequency
- 22 Khz tone: On
10750 standard Ku-Band LNBF on the OFF side of a 22Khz switch
In antenna setup:
- LNB switch frequency: 12700
- 22 Khz tone: Off
9750/10600 universal Ku-Band LNBF
In antenna setup:
- LNB low band frequency: 9750
- LNB high band frequency: 10600
- LNB switch frequency: 10700
- Start Frequency: MUST range anywhere between 10700 to 11699
- End Frequency: MUST be at least 10 Mhz higher than Start frequency and can range anywhere between 10710 to 12750
- 22 Khz tone: Auto
5150 standard C-Band LNBF on the ON side of a 22Khz switch
In antenna setup:
- LNB low band frequency: 5150
- LNB high band frequency: 5150
- LNB switch frequency: 3600
- Start Frequency: 4800 or lower
- End Frequency: at least 10 MHz higher than Start Frequency but 4800 or lower
- 22 Khz tone: On
5150 standard C-Band LNBF on the OFF side of a 22Khz switch
In antenna setup:
- LNB switch frequency: 4800
- 22 Khz tone: Off
In the next release, we will fix this so that blind scan can work on all system types as configured in Antenna setup, including non-standard LNBF's such as 10700 but for now, please pay attention to the start frequency parameter as it does have an impact on how the blindscan is being performed.
