Formatwarscentral reports that they have read on the AVForums that someone has discovered a workaround for region coding on Blu-ray titles.
He has found that it works on New Line titles and essentially uses controller commands to jump past the warning to the main menu.
It will be interesting to see if this workaround can be applied to titles from other studios, and Region B titles to play on Region A PS3.
Of course, now that he has talked about it, it will probably be disabled on future firmware releases.
Aπό ότι φαίνεται ο AlanBryant από το AVForums βρήκε λύση στις ταινίες Blu-Ray όπου είναι κλειδωμένες να παίζουν παντού με το υπάρχον firmware.
Όπως λέει: "So on the last try when the "region incombatibility" message came up i pressed the triangle on the controller, which brings up the pop-up menu and clicked on "TOP MENU" then BINGO the films menu came on"
Πηγή: N4G
Πηγή: N4G
