CineVERSUM: New D-ILA™ Home Cinema projector the BlackWing Two
GeonX
2,755
One more D-ILA... :grandpa: :grinning-smiley-043 Προφανώς η JVC έχει σκοπό να τραβήξει την αντίθετη κατεύθυνση από την Sony και να δουλέψει το μοντέλο OEM στο έπακρο…έτσι να και η Cineversum με ένα D-ILA μοντέλο και ανταγωνιστική τιμή στο παιχνίδι… για να δούμε πότε με το καλό θα έρθει στο Ελλαντα μια και υπάρχουν αρκετοί φίλοι με Cineversum στο ταβάνι τους…ήρθε η ώρα τις αλλαγής ? -bye-
January 2007 - CineVERSUM will unveil the new BlackWing Two projector during the ISE Show in Amsterdam, NL (30/01 – 01/02/2007 Booth #J60).
The BlackWing Two is a Full-HD medium-sized projector that completes the current high-end D-ILA™ projectors series. The suggested price of the BlackWing Two is 7 699 euros.
Features
Display technology
The BlackWing Two features three Full HD panels (1920x1080 pixels), one per color channel : green, red and blue.
The innovative reflective liquid crystal panel is now processed into a 0,7 inches diagonal plate with a pixel pitch of 8.0 m to match the most exigent HDTV resolution available and to achieve the unsurpassed contrast with an breakthrough native ratio of 20,000:1
BlackWing Two reproduces without artifice the richest and deepest black level, whichever the movie, whichever the scene. Moreover, choice can be made between five different color presets, two of which being customizable.
The built-in video processor in enhanced by the Visual Excellence Processing (VXP™) technologies.
• Reality Expansion™ 10-bit internal video scaler
• TruMotionHD™ de-interlacing methods (Inverse telecine processing, film mode detection)
• FineEdge™ multi-directional edge adaptive processing
• FidelityEngine™ noise reduction and image contrast enhancements.
Ease of operation
The BlackWing Two projector, thanks to its 2x zoom, has been specifically conceived to operate almost anywhere from the screen. Its light weight makes the projector easily transportable.
The versatile, large horizontal and vertical optical shift, associated with the new frontal cooling system (only 22dB) reduce the BlackWing Two’s installation to a minimal space requirement. In addition to this ease of installation, the state-of-the-art French design (by Le Porcher) makes this model the ideal choice that would transform any room into a living theater.
BlackWing Two Pro version
The BlackWing Two Pro bundle will please the most exigent home cinema aficionados with its external 10-bit high-definition video processor, giving access to advanced video source managements and professional-grade adjustments such as VRS™ video processing, film grade de-interlacing methods, dedicated game modes.
Thanks to the four extended Plug and Play HDMI inputs (among others) and the 12V screen trigger, the BlackWing Two Pro features a rich connectivity, enjoyable by the whole family.
Specifications:
Display technology: 3x Full HD 0.7” D-ILA™ devices
Native resolution: 1920x1080 each
Native contrast: 20,000:1
Aspect Ratio: 16:9
Optical lens: full glass by Fujinon
Zoom: 2.0 x
Throw ratio: 1.4 - 2.8:1
Screen range: 50”-300” diagonal
Horizontal shift: yes
Vertical shift: yes
Light source: 200W Ultra High Pressure Lamp
Lifetime: 2,000 hours
Brightness: 1,000 lumens
Inputs connections: standard BlackWing Two (and BlackWing Two Pro version)
2x HDMI (4xHDMI)
1x Component (2xComponent, 1x RGBHV/Component)
1x Composite (2x Composite)
1x S-Video (2x S-video, 1x SD-SDI(optional))
1x RS232C for software upgrade and automation
Video compatibility:
NTSC, PAL, SECAM, 480i/p, 576i/p, HDTV (720p50/60, 1080i50/60 and 1080p24/50/60)
Miscellaneous:
Power consumption: 280W (3W in stand-by mode)
Dimensions W x H x D: 585 x 185 x 510 mm
Noise level: 22dB
Net weight: 11 Kg
AVAILABILITY :
Blackwing Two : February 2007
Backwing Two Pro : March 2007
About Cineversum : Cineversum was the former Home-Cinema brand of BARCO. French T.E.C. took the brand over in September 2004.
Contact : [email protected]
Babis K.
28,748
Αυτόν θα τον πάρει ο Σωκρατίδης... Μοιάζει με τον Darth Vader ...
Babis K.
28,748
Κι έχει κι αλλαγές ρε παιδιά... σημαντικές.
1000 ANSI αντί για 700
20.000:1 αντί για 15.000:1
22 db αντί για 25 db
...τί γίνεται; Καλά, η SDI είναι SD και optional.
Πόσο κάνει αυτός;
GeonX
2,755
Μπάμπη το μικρό μοντέλο (όχι το PRO) 7.699 retail… τώρα πόσο θα κάνει street χμμμ…μην ξεχνάς ότι η Barco ποτέ δεν ήταν φθηνή από την άλλη πάντοτε ήταν ποιοτική εκεί είχε το κάτι παραπάνω… προφανώς το δούλεψε το μηχάνημα…
Chris, Dreamvision – Barco Cineversum είναι η ίδια εταιρεία μετά την εξαγορά της Barco από την Dreamvision απλά κάπου αποφάσισαν να μην χρησιμοποιούν το όνομα Barco (υποθέτω ότι υπάρχει θέμα με τα αλλά προϊόντα που κράτησε η μαμά Barco… ) και σπρώχνουν το brand Cineverum πλέον…
Browser
10,575
Απάντηση: Re: CineVERSUM: New D-ILA™ Home Cinema projector the BlackWing Two
Για δες λοιπον την ονειρεμενη μελισσα.....dreambee....
img.cfm
στο...
http://www.projectorcentral.com/Dream_Vision-DreamBee.htm
NassosT
4,714
K. Καστρουνή θα θέλατε να μας πείτε δύο λογάκια για τον Blackwing Two που εξετάζετε στο τρέχον τεύχος (Μαΐου) του Ηχου? Ιδίως σε σχέση με JVC και Amethyst. Ή και με τα άλλα καμάρια της Sony?
3,031
Θα συμφωνήσετε μαζί μου νομίζω ότι είναι αντιδεοντολογικό να αναφέρω κρίσεις και απόψεις για μηχανήματα που αναφέρονται στο τρέχον τεύχος του περιοδικού.
Kosh
7 September 2006
91,587
Εκεί ψηλά.....
πετεσουλη κανε υπομονη λιγες εβδομαδες .....
Ο Μανωλης θα μας τα αναλυσει ολα οταν ερθει η ωρα με το νι και με το σιγμα......
NassosT
4,714
Re: Απάντηση: Re: CineVERSUM: New D-ILA™ Home Cinema projector the BlackWing Two
Σύμφωνοι. Απλά επειδή είμαι κάργα αντι-Sonάκιας θέλω πολύ να ακούσω ότι τους πατάει κάτω σαν σκουλήκια...
AFam
11 September 2006
26,961
Και που να δείτε τιμή μαζί με τον scaler !!!!!!!!:bigcry: :bigcry:
NassosT
4,714
Η τιμή του Blackwing Two είναι 8.700.
Η τιμή του Blackwing Two Pro (με το scaler δηλαδή) δεν ξέρω ποια είναι, αλλά δε με απασχολεί καθώς scaler έχω.
