CRYSTAL AUDIO AppStreamer | Gigabit Media Player με Δικτυακές Εφαρμογές
Karmakoma
19 February 2007
206
Μήπως έχεις κάποιο firewall που εμποδίζει το μηχάνημα να δει το pc?
Αν όχι, και υποθέτοντας πως έχεις windows7 κάνε τις παρακάτω ενέργειες στο pc σου:
Start => Control Panel => Programs and Features => Turn Windows Features On or Off => tick the Media Features, Network stuff, Telnet Client, TFTP => OK.
Next, go to Start => Control Panel\All Control Panel Items\Network and Sharing Centre => click on Choose homegroup and sharing options => Choose the folders to share. Tick the option to "Stream your pictures, music and videos on my home network".
Click on Change Advanced Sharing Options. You are in Control Panel\Network and Internet\Network and Sharing Centre\Advanced sharing settings:
turn on network discovery
turn on file and printer sharing
stop the "Public Folder Sharing".
Go to Media Streaming Options, which is in Control Panel\Network and Internet\Network and Sharing Centre\Media streaming options => and there...
Name your media library [your nick, for instance]
Show devices in the local network => Allow all
Media programs etc. etc. => Allowed.
Go back [BACK button]:
leave the 128b encryption to on
turn off password protected sharing
allow Windows to manage homegroup connections.
Then, start your Windows Explorer and
find all the folders you want to share;
right click on each folder and go to Properties;
click on Share tab => click on the little arrow downwards to get the drop down menu and choose Everyone, then click on Add.
Give "Everyone" the permission to READ ONLY and click on Share.
You have more controls/options under Advanced Sharing button in the little window, too. Go to it and check the permissions etc. When you're done, in the main Properties little window, finish by clicking on Apply and Close.
giorgostri
16 October 2007
61
Αντιμετωπίζω κι ο ίδιος πρόβλημα διασύνδεσης με το NetFasteR WLAN της HOL. Συγκεκριμένα:
Αξιοποιώ στο router WAP κρυπτογράφηση, ενεργό DHCP και τις βασικές ρυθμίσεις (ήτοι δίχως να δηλώσω username/password για το PPPoE, μια και παίρνει τα default της HOL, όντας μέρος του δικτύου της). Έχω κλείσει το firewall, τόσο στο router, όσο και στα Windows 7 (64bit). Έχω ακολουθήσει τις παραπάνω οδηγίες για να κάνω shared φακέλους, αλλά το πράγμα σκαλώνει ακόμα ακόμα ήδη από την προσπάθεια να συνδεθεί με το router το wifi dongle της Crystal Audio (CA-Wi-Fi). Ενώ το τοποθετώ στην μία ελεύθερη USB υποδοχή του Appstreamer (η άλλη κουβαλάει έναν εξωτερικό 3,5'' σκληρό) και πηγαίνω κανονικά στα settings του Network, στην επιλογή Wireless, μολονότι τοποθετώ κανονικά το WAP key, μου βγάζει "Test failed" στην προσπάθεια να συνδεθεί με το AP. Το wireless παραμένει off. Εννοείται πως έχω τσεκάρει ουκ ολίγες φορές τον κωδικό, τον άλλαξα μάλιστα με ένα απλό 12345678 απλώς και μόνο για να τεστάρω, αλλά και πάλι τζίφος. Τόσο ένα Samsung S2, όσο κι ένα iPhone 4 συνδέονται κανονικά με το wifi, όσο αυτό συμβαίνει.
Το Appstreamer είναι σε απόσταση 4-5 μέτρα όλα κι όλα από το router με έναν τοίχο και πόρτα ανοιχτή ενδιάμεσα, γεγονός που δεν θα έπρεπε να συνιστά πρόβλημα.
Ως έχει, έχω σηκώσει τα χέρια ψηλά. Όποιος έχει κάποια ιδέα, θα του ήμουν ευγνώμων.
Edit: Ηλίθια ίσως απορία, αλλά: το dongle δεν θα έπρεπε να βλέπει καπάκι το netfaster router (που είναι συνδεδεμένο μέσω ethernet με τον υπόλογιστή); Χρειάζεται να κουβαλάει και τo desktop ανάλογο usb stick;
papdoux
14 December 2007
3,404
το router που χρησιμοποιείς είναι ασύρματο οπότε το AppStreamer θα συνδεθεί ασύρματα στο router. Οπότε η επικοινωνία θα είμαι μέσω του router και δεν το ενδιαφέρει πως είναι η σύνδεση μεταξύ router - PC.
Μία κίνηση είναι να αφήσεις ελεύθερο το wireless στο router για να δεις αν συνδέεται ασύρματα το AppStreamer. Αν όχι τότε υπάρχει θέμα μάλλον.
Αν συνδέεται τότε ενεργοποίησε πάλι κωδικούς. Κοίτα επίσης μήπως το router είναι σεταρισμένο να δέχεται συγκεκριμένες MAC addresses.
Θα σου έλεγα να κάνεις και κανένα restart στο router.
giorgostri
16 October 2007
61
Re: Απάντηση: CRYSTAL AUDIO AppStreamer | Gigabit Media Player με Δικτυακές Εφαρμογές
Σ' ευχαριστώ για την απάντηση. Θα τσεκάρω μήπως άνευ κωδικού μπαίνει, μολονότι δεν υπάρχει περίπτωση να αφήσω το router άνευ wap. Το θέμα των MAC το έχω αποκλείσει γιατί συνδέονται κανονικά wireless τόσο ένα laptop, όσο και τα δύο κινητά, δίχως κάποια ρύθμιση από το router και αποκλεισμού συγκεκριμένων διευθύνσεων (ή αποδοχή μόνο συγκεκριμένων πάλι). Restart στο router έγινε άνευ αποτελέσματος.
Υποθέτω πως το dongle το συνδέω καπάκι με το Appstreamer, δίχως οποιαδήποτε πρώτα εγκατάσταση του λογισμικού του στον υπολογιστή.
akilleas
Το ίδιο ακριβώς πρόβλημα έχω και εγώ!!!
Αλλά όχι μόνο αυτό αλλά και την ίδια απορία!!!!
Θα το κάνω και εγώ και βλέπουμε...
papdoux
14 December 2007
3,404
Λογικά το dongle θα πρέπει να παίζει κατευθείαν πάνω στο player χωρίς να χρειάζεται κάποιο software στο PC.
Στο xtreamer που είχα, έπαιρνε USB κεραία πάνω του χωρίς να χρειάζεται κάποια άλλη ρύθμιση ή να τη συνδέσω πρώτα στο PC.
healler
12 March 2007
176
Μια ερώτηση ελαφρώς off-topic
το CRYSTAL AUDIO AppStreamer ΤV με το dvb-t διπλό δεκτη και τη δυνατότητα τοποθέτησης σκληρού, γνωρίζει κανείς αν θα βγεί πρίν ή μετα απο τις 20 Ιουλίου?
lykman
29 June 2006
5,798
Aθήνα
Παιδιά πολύ σύντομα θα ανεβάσω μια παρουσίαση για το AppStreamer (χωρίς wifi), αν θέλει κάποιος κάτι συγκεκριμένο να δοκιμάσω ας το πει... αν μπορέσω θα το συμπεριλάβω.
Βασικά εδώ και αρκετές μέρες θα ήθελα να την έχω ανεβάσει, αλλά όλο αναποδιές μου κάθονται και δεν μπορώ να ασχοληθώ όπως θα ήθελα...
akilleas
Ρε παιδιά όταν πάω να παίξω μια ταινία μου ζητάει κωδικό.
Ποιον ακριβώς μου ζητάει και που τον βρίσκω;;;
Τι στο καλό κάνω λάθος;;;;
SoCiaL
26 September 2007
1,174
Στο pc συνδεεσαι σε καποιον λογαριασμο χρηστη πχ akilleas, αυτο θα βαλεις σαν username μαζι με το password.
akilleas
Έχω όνομα χρήστη αλλά δεν έχω κωδικό.
Οπότε βάζοντας μόνο το όνομα χρήστη και κενό το πεδίο του κωδικού θα μπει λες;;
Το δοκιμάζω σε λίγο....
akilleas
Έφτιαξα ένα νέο χρήστη και έβαλα και κωδικό και είναι όλα καλά.
Τώρα το πρόβλημα είναι πως θα γίνεται να συνδέεται στο WIFI με κωδικό, γιατί τώρα το έχω χωρίς security.
Καμιά ιδέα και γι'αυτό;;;;
lykman
29 June 2006
5,798
Aθήνα
Απάντηση: Re: CRYSTAL AUDIO AppStreamer | Gigabit Media Player με Δικτυακές Εφαρμογές
Σε όσους το έχουν: Η θύρα gigabit δουλεύει κανονικά; Έχει δοκιμάσει κανείς streaming HD;
ναι συγχρονίζει κανονικότατα στα 1000. Τι streaming HD εννοείς? BRs και mkv, εννοείται ναι...
akilleas
Ρε παιδιά κατάφερε κάποιος να συνδεθεί ασύρματα με WIFI κλειδωμένο;;;
Δεν μου δέχεται το κλειδί με τίποτα.
Μήπως είναι θέμα του appstreamer τελικά και δεν φταίει ο ρούτερ;;;
neof1z
14 January 2009
848
ΠΕΡΙΣΤΕΡΙ
Σήμερα το αγόρασα κι' εγώ.Μόλις είδα μια ταινία blu - ray (Folder οχι ISO) και μπορώ να πω ότι την έπαιξε τζάμι χωρίς σπασίματα.Το πρόβλημα που έχω είναι μόλις κάνω παύση, μετά αναπαραγωγή η πατάω το στοπ ακούγονται παράσιτα που σε ξεκουφαίνουν!!!!!!!!!!!!!!
Αυτό συμβαίνει μόνο σε HD ήχο μιας και το έχω πάνω στον ενισχυτή (Yamaha RX- V3900). Έχει κανένας άλλος παρόμοιο πρόβλημα?
neof1z
14 January 2009
848
ΠΕΡΙΣΤΕΡΙ
Τελικά το (πρόβλημα) ήταν στον ενισχυτή.Είχα το audio selection στο auto και με το skip, stop, pause υποθέτω ότι έψαχνε άλλη πηγή ήχου (γύρναγε σε coaxial / optical , analogue) .Το έβαλα manual στο hdmi και παίζει μια χαρά.
