DarkBox HD PVR REV 2008.
john 78
Banned
29 December 2008
1,684
Digital High Definition
Satellite Receiver
Con@x (multicas) with 2CI
k*y* FEATURES
Full Compliant of MPEG-S, DVB-S2 Digital & DVB broadcasting
Standard Definition/High Definition contents (MPEG2 and support MPEG4 AVC/H.264)
High Definition Video output : HDMI (HDCP Option) and YPbPr
Event Timer by EPG
PC Channel Editor
MAIN FEATURES
Audio Decoding :ISO/IEC13818-3(MPEG-2 audio/MUSICAM) Dolby AC-3
Smart card reader & Dual Common Interface
950-2150 MHz input Frequency (IF Loop Throughout)
Satellite Scan - Simultaneous Scan with 10 Satellites
Flexible receiption of SCPC & MCPC from C/Ku-Band Satellites
Variable Input Symbol Rate (1-45 Msps)
Video output resolution: 576p,720p,1080i
User selectable output resolution
EPG (Electronic Program Guide)
Multi-language OSD
Fast Channel Change
10,000 Channels TV & Radio program
Timer Function (Automatic Turn On/ Off by Setting Function)
RTC (Real Time Clock)
PIG (Picture In Graphic)
5 Favorite List & Unlimited Programs per each
Powerful Channel Editing Fuction
- Sorting: Alphabetic, Satellite, FTA/Scramble, Parental Lock
- Move, Delete, Favorite Edit
- Parental Lock, Channel Rename, Channel Skip
Manual PID/ Satellite & TP/ Network Scan Date
S/PDIF (Digital Audio or Dolby AC3 stream out)
DiSEqC 1.2 and USALS Compatible
Comparable of Setting the Frequency for SMATV System
Software Upgrade via USB
Dolby Digital Decoder
Support teletext and subtitle
2. Specifications
Tuner / LNB (Satellite)
1 Input Connector F-type, IEC 169-24
IF Input Frequency 950MHz to 2150MHz
IF Loop Throughout 950MHz to 2150MHz
Input Level -65 dBm~-25 dBm
LNB Power 13 /18VDC / 500mA Max
DiSEqC Control 1.0,1.2 &USALS compatible
Band Switch 22KHz Tone(22 +/- 4KHz,Amplitude :0.6 +/- 0.2V)
Modulation method LDPC/BCH(DVB-S2) 8PSK/QPSK, DVB-S QPSK
Symbol Rate LDPC/BCH(DVB-S2) 8PSK/QPSK :10~30Msps
DVB-S QPSK : 1~45Msps
Viterbi Decoding Rate 1/2,2/3,3/4,5/6 and 7/8
Bandwitdth 36MHz
LDPC/BCH Punctured Code ,1/2,2/3,3/4,3/5,4/5,5/6,8/9,9/10 in DVB-S2
MPEG transport Stream A/V Decoding
Demultiplex According to ISO/IEC 13818-1(MPEG-2 system)
Input syream Max. 90Mbit/s
Aspect Ratio 4:3(default), 16:9 letterbox
Vidoe Deocding ISO/IEC 13818-2(MPEG2 vidoe) MP@HL,ISO/IEC 14496-10 HP@L4
Video Resolution 576p,720p,1080i
Audio Decoding ISO/IEC13818-3(MPEG2 audio/MUSICAM), Dolby AC-3
Audio Mode Single Channel /Dual Channel, Stereo, Joint Stereo
Video Ouput HDMI/HDCP (Option),SCART,RCA
Microprocessor & Memories
CPU Clock 280MIPS
Flash Memory 4 Mbyte
SDRAM 160 Mbyte
EEPROM 32 Kbit
A/V output
Digital output HDMI/HDCP (Option), YPbPr
TV SCART Video output(CVBS,RGB,S-Video),Audio left/right
VCR SCART Video input(CVBS),Vidoe output(CVBS) ,audio in/output (left,right)
Video RCA 1 output
Audio RCA 2 output
Digital Audio 1 optical output S/PDIF
Front Panel
4 Digits LED Display Channel Number Display (Green )
8 k*y* Power,Channel Down/Up, Volume up/down,Menu,Exit,OK
USB USB2.0 Host
Smart Card Reader Con@x CAS 7 Embedded
Accessaries
Rear Panel - Remote control Unit
IF Input F-type Connector - Battery
IF Loopthrough output F-type Connector - User's manual
6RCA Video, Audio L, Audio R, YPbPr - HDMI Cable
Scart TV / VCR - 3 Pin uk Connector
S/PDIF Optical
HDMI Type A
Remote Control
Type IR RCU
Battery 2x1.5V AAA Type
Date
Electrical and Mechanical
Input Voltage AC 90-250V, 50/60Hz
Power Consumption Max. 45 Watts
Standby Power Max 18 Watts
Dimension (WxDxH) 340x245x65mm
Weight 3.0kg 7KEE-REV
Ο δεκτης κατεβαζει οποιοδηποτε καναλι και ειδικα τα HD.To cardreader διαβαζει τις επισημες καρτες της Νοβα (v.4-5-zeta) και του Digitalb,οπως και Vi@cc3ss.Κανενα προβλημα δεν υπαρχει χρησιμοποιωντας τις καρτες με cam Ird3to (μπλε) η'Con@x.Αρκετα καλη λειτουργια του με το diablo cam αν και καποιες φορες δεν αποφευγεται η απομακρυνση του και επανατοποθετηση του.Βεβαια αυτο ειναι περισσοτερο προβλημα του diablo μιας και τα ιδια η' παρομοια προβληματα δημιουργει σε ολους τους δεκτες,ακομα και στους απλους.Ελληνικο μενου και epg εχει.Βγαινει σε 3 μοντελα (LED Display-VFD Display-VFD Display combo).Λειτουργια σκληρου δισκου eSATA υποστηριζει με τα τελευταια λογισμικα.Αναβαθμιση-ετοιμη λιστα καναλιων μοτερ-ολη η διαδικασια παιρνει 3 λεπτα το πολυ.
φωτο........
http://www.zshare.net/image/5306037421768d77/
http://www.zshare.net/image/53555422786f8b94/
http://www.zshare.net/download/5306039394347288/
Eki_13
2,208
φιλε ολυμπιακος εισαι οκ αλλα μου εβγαλες τα ματια με το κοκκινο!!-bye-
john 78
Banned
29 December 2008
1,684
Συγνωμη αλλα μου φανηκε καλη ιδεα.Στην αρχη πηγα να το κανω μπλε.Εκει θα χαναται την οραση σας τελειως.
2,226
Ενδιαφέρων δέκτης ,δώσε μας και μια ενδεικτική τιμή.
Από εικόνα τι λέει, τον δοκίμασες σε hd και sd κανάλια και σε σύγκριση με ποιους άλλους και σε τι μέσο προβολής?
Το diseqc 1.1 δεν βλέπω να το υποστηρίζει .
Εthernet δεν έχει ?
Η αναβάθμιση λογισμικού γίνεται μέσω usb στικ ?
john 78
Banned
29 December 2008
1,684
H τιμη του ειναι στα 250Ε.DiseqC 1.1 δεν υποστηριζει,ομως ειναι κατι που εχει επισημανθει και πιστευω θα διορθωθει.Γενικως οι περισσοτεροι δεκτες HD δεν το υποστηριζουν αλλα και αυτοι που λενε οτι το υποστηριζουν στην πραξη υπαρχουν προβληματα.Αυτο το θεμα ειναι λιγο δυσκολο και τα χουν βρει μπαστουνια οι κατασκευαστες θα ελεγα.Στα sd καναλια λειτουργει ο upscaler του δεκτη και διορθωνει κατα πολυ την εικονα στα καναλια που εχουν χαμηλο bitrate ιδιαιτερα.Στα HD καναλια συγκρινομενος με εναν αλλο HD δεκτη ακριβοτερο παρουσιασε την ιδια εικονα.Σε τηλεοραση Samsung 32'.Eθερνετ δεν εχει και η αναβαθμιση,λιστα καναλιων,softcam περναει μεσω του usb.To βασικοτερο ειναι οτι δεν μου εχει κανει κανενα κολλημα εδω και 8 μηνες.
petasis
17,003
Μπα, δεν φαντάζομαι να είναι τόσο δύσκολο το 1.1. Νομίζω απλά δεν ασχολούνται, γιατί δεν το θεωρούν τόσο διαδεδομένο... Ουσιαστικά, οι εντολές diseqc 1.0, 1.1., 1.2 είναι πανομοιότυπες. Οι τιμές μερικών bytes αλλάζουν...
Να μιλάγαμε για 2.0, 2.1, 2.2, ναι θέλει και υποστήριξη από το υλικό...
john 78
Banned
29 December 2008
1,684
Δεν σου κανει εντυπωση ομως οτι οι περισσοτεροι δεκτες δεν το εχουν?Και καλα εμεις εδω,λιγοι το χρησιμοποιουν, αλλα στην Ισπανια μαθαινω οτι ειναι πολυ διαδεδομενο.Πολλες εγκαταστασεις ειναι ετσι.Παντως αν ειναι τοσο απλο τοτε θα φτιαχθει.
petasis
17,003
Μα οι περισσότεροι δέκτες δεν έχουν και τα diseqc 2.x. Εμείς φταίμε που αγοράζουμε ελλειπή προϊόντα... :blush:
john 78
Banned
29 December 2008
1,684
Θα μπορουσες να μου πεις τι εξυπηρετει το Diseqc 2.χ?Δεν το γνωριζω αυτο.
petasis
17,003
Κάνει ότι ακριβώς το diseqc 1.x, μόνο που σε κάθε εντολή αυτός που την έλαβε στέλνει πίσω επιβεβαίωση ότι εκτελέστηκε. Είναι δηλαδή αμφίδρομη επικοινωνία.
Και ενώ πολλά LNB και αρκετοί διακόπτες είναι diseqc 2.x, δεν ξέρω κάποιον δέκτη που να είναι...
john 78
Banned
29 December 2008
1,684
Nα δουμε τι θα γινει με το 1.1 και μετα βλεπουμε και αυτο.Στον Octagon SF918 HD παντως απ οτι μαθαινω με το 1.1 λειτουργουν μεχρι 8 lnb.Αν μπορει ο Λευτερης να μας το επιβεβαιωσει.
2,226
Ναί , μέχρι 16.
Πάντως ,αναφορικά με την λειτουργία Disecq 1.1 ,να επισημάνω πως η δυνατότητα του είναι μέχρι 8 lnb (αν και έχει 2 ειδών ρυθμίσεις για diseqc 1.1 Diseqc1.1 1-16 δεν μου δουλεύει &
Diseqc1.1 ΙΝP1-INP8 σε αυτήν την ρύθμιση δουλεύει).
john 78
Banned
29 December 2008
1,684
Σ εμενα,μαλλον, εχει μπει στο προγραμμα να φτιαχτει,σε σενα να τελειοποιηθει.
petasis
17,003
To diseqc 1.1/2.1 πάει μέχρι 64 LNB... 16 uncommitted switches, όπου κάθε ένας μπορεί να χειριστεί 1 committed switch. 16*4 δηλαδή...
2,226
Θεωρητικά ναι ,αν και αναφερόμουν στο δικό μου δέκτη που δεν έχει στο μενού commited/uncommited ρυθμίσεις όπως στους π.χ dreambox ,μάλλον εννοείς κάτι σαν το παρακάτω:
http://www.sdtv.gr/smf/index.php?topic=9446
Αμφιβάλω όμως αν τελικά έχει κατορθώσει κάποιος να κατεβάσει με ένα καλώδιο 64 θέσεις ή και 32 που φαίνεται πιο εφικτό.(ασυμβατότητες με πολλούς δέκτες).
Αν υπάρχει άλλος τρόπος θα σε παρακαλούσα να μας το αναπτύξεις λίγο περισσότερο θεωρητικά και σχηματικά για να το κατανοήσουμε, σε ένα νέο θέμα γιατί με ενδιαφέρει.
Σε ευχαριστώ.
petasis
17,003
Ναι, κάτι τέτοιο εννοώ, αν και νομίζω ότι οι εντολές για το 4/1 που έβαλε στην 8η πόρτα του 8/1(v2) δεν είναι σωστή. To committed δεν πρέπει να είναι none...
Τι ακριβώς ρυθμίσεις έχει ο δέκτης σου; Σε αφήνει να βάλεις εντολές diseqc απ' ευθείας;
2,226
Diseqc 1.1 1-16----------->δεν μου δουλεύει(μόνο την 1η τετράδα βρίσκει)
Diseqc 1.1 INP1-INP8 ---->έτσι δουλεύει(μόνο για 8 όμως)
