DENON 2010 A/V Receivers
kblachos
18 February 2009
17,134
ΑΓΙΟΙ ΑΝΑΡΓΥΡΟΙ
Στα πλαίσια της CES 2010 η Denon παρουσίασε τον S-5BD έναν ενισχυτή 5.1 καναλιών με ενσωματωμένο Blue Ray Player. Αναμένεται τον Μάρτιο στην Αμερική, με τιμή τιμοκαταλόγου 1.800 $.
Denon S-5BD
LAS VEGAS--We don't see many home theater AV receivers at CES, with home audio manufacturers generally waiting for their own line shows to release new product lines. However, most AV receivers don't have Blu-ray players built-in.
Denon has announced the S-5BD AV receiver/Blu-ray Disc player combo unit at CES 2010, melding the two components into a sleek, glossy package. Here's the initial info from the news release.
Key features of the Denon S-5BD:
The S-5BD certainly has a slick design and it's the first combo unit we've seen, but we can't help but feel it will ultimately have limited appeal. The integrated Blu-ray player has a relatively bare-bones feature set since it lacks Wi-Fi and the streaming media services (like Netflix) available on competing models. We also complain about the layout on Denon's remote controls in all our AV receiver reviews, and we can only imagine it being worse when that remote also controls your Blu-ray player.
Finally, the integrated design really limits your upgrade options. With separate components, it's easy to swap in a new Blu-ray player while you still try to squeeze some extra years out of your receiver. You could add a new Blu-ray player with the S-5BD (with its three HDMI inputs), but that's defeating the point of the unit in the first place. The S-5BD might make sense in certain applications where there's limited space or ease-of-use is a priority, but it's probably not the best choice for buyers who value flexibility in their home theater setup.
http://ces.cnet.com/8301-31045_1-10428991-269.html?tag=mncol;title
kblachos
18 February 2009
17,134
ΑΓΙΟΙ ΑΝΑΡΓΥΡΟΙ
DENON A/V Receivers 2010
Η Denon κυκλοφόρησε firmware upgrade για τον AVR-3310.
Μετά την αναβάθμιση, προστίθεται στον ενισχυτή η δυνατότητα επεξεργασίας Audyssey DSX την οποία μέχρι τώρα είχαν οι δύο ακριβότεροι ενισχυτές της εταιρείας AVR-4310 και AVR-4810.
Περισσότερα στο site της Denon
Λεπτομέρειες για το Audyssey DSX εδώ
gzoun
8 March 2008
1,959
Αθήνα-Μενίδι
DENON 2010 A/V RECEIVERS
Οι απανταχού λάτρεις της DENON δεν θα μείνουν παραπονεμένοι και εφέτος .
Η εταιρεία προχώρησε στην ανακοίνωση 10 νέων μοντέλων ενισχυτών,
οι οποίοι είναι έτοιμοι να διαχειριστούν 3D σήματα,
και αφορά ενισχυτές 5.1 αλλά και 7.1 καναλιών.
Η οικονομική σειρά , με διάθεση που ξεκινάει από τον Μαΐo, περιλαμβάνει τους εξής ενισχυτές :
AVR-391 (SRP: $249, July) 5.1-channel models
AVR-591
(SRP: $349, May) 5.1-channel models
AVR-791
(SRP: $499, May) 7.1-channel models
AVR-891
(SRP: $799, May) 7.1-channel models
AVR-991
(SRP: $999, July) 7.1-channel models
AVR-1611
(SRP: $399, June) 7.1-channel models
AVR-1911
(SRP: $599, June) 7.1-channel models
Και καταλήγει στην ακριβότερη σειρά CI,,με διάθεση που ξεκινάει τον Ιούνιο, και περιλαμβάνει τους εξής ενισχυτές:
AVR-2311CI (SRP: $899, June)
AVR-3311CI (SRP: $1,199, June)
AVR-4311CI (SRP: $1,999, Sept.)
http://www.engadget.com/2010/04/27/denons-2010-receivers-blu-ray-players-are-control4-streaming/
http://www.slashgear.com/denon-av-r...feed&utm_campaign=Feed:+slashgear+(SlashGear)
http://www.fullhd.gr/audio-video/38...-391--avr-4311ci-avr-3311ci-a-avr-2311ci.html
Johnson
12 March 2009
913
Mainly:Andalucia/Europe
Re: DENON 2010 A/V RECEIVERS
Ωραία μηχανήματα και ωραίες προτεινόμενες τιμές.:SFGSFGSF:
Αν δούμε και τίποτα έστω κοντά στις προτεινόμενες τιμές Ευρώπης καλά θα ναι...
kblachos
18 February 2009
17,134
ΑΓΙΟΙ ΑΝΑΡΓΥΡΟΙ
Γιώργο, ένωσα το νήμα που άνοιξες με το υπάρχον νήμα για τους Denon του 2010.
Ευχαριστούμε για την ενημέρωση!! :ernaehrung004:
LefterisV
9 June 2010
73
Πήρα στην Denon (Γλυφάδα) και δεν ξέρανε τον 591...
Μήπως είναι μοντέλο για Αμερική είπανε.
Που θα τον βρώ?
kblachos
18 February 2009
17,134
ΑΓΙΟΙ ΑΝΑΡΓΥΡΟΙ
Oι AVR-591, 791, 891 εκτιμώ ότι αφορούν αποκλειστικά την Αμερικάνικη αγορά, όπως και τα αντίστοιχα περυσινά μοντέλα AVR-590, 790, 890, 990. Στην Ελλάδα θα κυκλοφορήσουν τα μοντέλα απ' τον AVR-1611 και πάνω. Με κάθε επιφύλαξη βέβαια καθώς δεν γνωρίζω την πολιτική της Denon, αλλά για να μην γνωρίζουν κάτι σχετικό και στην Κινοτεχνική μάλλον έτσι θα είναι.
Ολα αυτά τα μοντέλα αναφέρονται στο Αμερικάνικο site, αλλά όχι στο Ευρωπαϊκό.
http://www.usa.denon.com/ProductDetails/AVReceivers.asp
http://www.denon.co.uk/site/frames_...=1&Gruppe_C=4&action=prodlist&main=prod&sub=1
DR.GEO
19 June 2010
8
Παντως παιδια για πληροφορια εαν ενδιαφερεστε δειτε αυτο το site:
http://www.hifiglobe.com
Ειναι εγκυρο εχω αγορασει εγω απο αυτο τον Onkyo tx-nr3007 kαι ειμαι απολυτα ευχαριστημενος με τις τιμες και τη αμεση εξηπηρετηση.Απλα το γραφω γιατι εχω βαρεθει με το κλεψιμο που γινεται συνεχως σ'αυτη τη χωρα λες και ειμαστε μια ζωη κοροιδα!!Το site αυτο εχει πληθωρα απο DENON.Στη αρχη ειμουνα διστακτικος αλλα αγορασα με Paypal για να εχω το κεφαλι μου ησυχο.Οποιος θελει πληροφοριες ας μου στειλει pm.Αυτα απο εμενα για τους λατρεις το cine.
MoDis
20 June 2006
3,660
στον κοσμο μου...
Τιμές απο Γερμανία , στην Ελλάδα ο "θείος" δε βγάζει ακόμα κάτι ...
1611 - 403Ε παραδοτέος
1911 - 507Ε όχι ακόμα
2311 - 1034Ε όχι ακόμα
gzoun
8 March 2008
1,959
Αθήνα-Μενίδι
HDMI, Audyssey DSX, AirPlay Support: Denon AVR-4311
Introducing the AVR-4311 in Japan is Denon, putting a 9.2-channel AV Surround Receiver in the world for 252,000 JPY, with HDMI 1.4a ports that support 3D graphics and Audyssey DSX, capable of 11.2-channel surround sound. It also supports Apple’s AirPlay, hooking into a network router with a wired Ethernet connection to stream music from a computer with iTunes 10. Planned release is the middle of October in two colors – black and “premium silver”.
http://en.akihabaranews.com/61701/a...-airplay-support-denon’s-av-surround-receiver
http://denon.jp/company/release/avr4311.html
FragoulisNaval
4 November 2009
7,820
Δίπλα στον Pseiras.....
Αναρτήθηκε σήμερα στο What Hi-Fi :
Denon launches high-end nine-channel receiver
YESTERDAY
Denon AVR-4311: £1945
New from Denon is the AVR-4311, a nine-channel high-end AV receiver complete with nine 170W amplifier channels, full 3D capability, network streaming and compatibility with the company's Remote App for iPhones and the iPod Touch.
The new model has even HDMI inputs and two outputs, with 3D passthrough, and as well as decoding all the current HD audio formats, offers Audyssey DSX processing, allowing it to support systems of up to 11.2 channels.
A full suite of preouts is available for all channels, and the receiver can be set to operate in preamp mode when used with external power amplifiers.
Audyssey MultEQ XT32 room equalisation and automatic set-up is used, along with MultEQ Pro for professional set-up by registered installers, giving even more accurate calibration through the use of up to 32 measurement points.
It has network streaming and internet radio, along with Apple iTunes AirPlay speaker capability via an optional upgrade, and the receiver also has digit direct play from iPods and iPhones via its USB connection.
Control of the receiver over a home network is also possible using the new Denon Remote App for iPhones and iPod Touch, which is available as a free app.
