dreambox-dvb-modules.bb: update dm800/dm8000 drivers
changes both:
- implement FE_TIMEDOUT flags in all tuner drivers (used in e2 to speedup the service searching a little bit)
- add new option to change scaler sharpness (/proc/stb/vmpeg/0/pep_scaler_sharpness)
- fix kernel freeze caused by demux problem when try to use more the 64 section filter (i.e. much recordings on the same transponder are running)
- deinterlacer optimizations please no more use "off" when the vertical input/output resolution are not equal "bob" is the equivalent to the old "off" option... but "auto" should generate better quality as off/bob in most case .. so changing the default behaviour is no more needed
changes dm8000:
- fix no more working 1080p24/25/30 output (in 20090916 drivers)
- fix stuttering video on (cvbs) analog output when no hdmi cable was connected but a DVI option was configured
dreambox-dvb-modules_2.6.12-5.1-brcmstb-dm8000-20091005-r1_dm8000.ipk
changes both:
changes dm8000:
