DVDO iScan VP50 PRO
Browser
10,573
World's First HDMI 1.3 Enabled Video Processor
Mosquito Noise Reduction - reduces random noise which appears along the edges of compressed images
Fine Detail Enhancement - to extract fine detail in low-resolution or compressed sources
Edge Enhancement - to sharpen edges without adding any ringing
Precision Deinterlacing™
480i/576i/1080i 10-bit Motion, Edge & Source-Adaptive Deinterlacer
  • Five-field motion adaptive deinterlacing
  • Edge adaptive processing for smooth diagonal edges
  • Three frame video processing delay (Max)
  • Game Modes with very low latency
  • Sub-1 frame delay with edge adaptive processing
  • 2 frame delay with edge and motion adaptive processing
PReP™
Progressive Reprocessing of 480p, 576p, and 1080p input signals allows poor deinterlacing of any source to be undone and done correctly using Precision Deinterlacing™
Precision Video Scaling II™
10-bit Scaling with Enhanced Sharpness Control up to 1080p
Progressive Cadence Detection™
Enables 24/48/72Hz and 25/50/75Hz output from film-based content at 480p, 576p, 720p and 1080p resolutions
Precision Gamma Correction™– Individual R/G/B Adjustments
Precision AV LipSync™
intelligent digital audio delay technology to match Audio & Video timing
RightRate™
High-Performance Framerate Conversion
AutoVFR™
Intelligent Component Video Inputs with Automatic Video Format Routing
AutoCUE-C™
Automatic Chroma Upsampling Error detection & correction
Key Features
HDMI 1.3 Inputs (4) that process up to 1080p-24/25/50/60
ISF ccc Day/Night Modes
Two Programmable 12V triggers
Upgradeable to SD/HD-SDI Dual Input Module
Analog HD Transcoding and Processing
Flexible Input and Output Aspect Ratio Controls
Display Profiles
For multiple display, framerate, and image shift configurations (10)
10-bit, 300 MHz Instrumentation Quality DACs (2x Oversampling for 1080p)
Full-frame Timebase Correction
High performance, multi-standard video decoder (10-bit: 480i/576i; 12-bit: 480p/576p/720p/1080i)
High-quality super-adaptive comb filter with 2D Y/C separation
Flexible Digital and Analog Audio switching and routing - 4 HDMI 1.3 audio/video inputs, 5 assignable audio inputs (4 digital, 1 analog) with 1 HDMI 1.3 audio/video output and 2 active digital audio outputs.
Software Upgradeable
mr_rebelos
10 July 2006
11,510
Κερατσίνι
Πολυ καλο μηχανημα. Το μονο που με χαλαει ειναι οτι εχει μονο μια hdmi output. Αν θες να στελνεις σημα ποτε στον προτζεκτορα και ποτε στην τηλεοραση τοτε χρειαζεσαι και hdmi switcher.
argi
Banned
17 July 2006
7,032
salmonela
το πρωτο σκειλερ με τσουξινι σφραγιδα
το ειχε παρουσιασει το homecinemachoice πριν 2 μηνες
και το audiovideo που το κοντραρει με αλλα scalers και noise killers
spyrmak
19 February 2007
4,748
Aθηνα
Re: Απάντηση: DVDO iScan VP50 PRO
ΠΟΣΟ ???????
ειχα δει στο ιντερνετ και κατι ακριβοτερα...!
(ο αντιπροσωπος στην Ελλαδα βγαζει τα λεφτα του? δηλαδη ποιος θα το αγορασει? -πλην καποιων με εντελως hi end και εξειδικευμενες εγκαταστασεις?)
24,692
Για όσους ενδιαφέρονται κυκλοφόρησε στο site το 1.02 firmware που βελτιώνει μεταξύ άλλων κάποια πρώτα Bugs με την αυτόματη αναγνώριση σημάτων input signals.
Οι τύποι έχουν κάνει καλές βελτιώσεις σε σχέση με το VP50:
1) Υπάρχει passthrough που δουλεύει μια χαρά.
2) Τα 24fps δουλεύουν μια χαρά χωρίς σπασίματα πλέον. Στην ουσία έχω βάλει καρφωτά 23.98 και ήρθε κι έδεσε το "γλυκό"
3) έχουν βάλει διάφορα pcοειδή φίλτρα , στην ουσία για βελτίωση των sd σημάτων. Αυτά είναι: Mosquito NR, Fine Detail, Edge Enhancement τα οποία παίρνουν και θετικές και αρνητικές τιμές.
Εχουν βάλει κάτι μνήμες έχτρα για isf night-day , κάτι αντίστοιχο όπως έχουν οι Pioneer τηλεοράσεις.
Και φυσικά όλα τα παραπάνω μπορούν να σωθούν ανά μνήμη (έχει 10 μνήμες όπως και το προηγούμενο μοντέλο).
Τα hdmi είναι 1.3 , αλλά δεν έχω ενισχυτή ανάλογο για να δοκιμάσω αν όντως δουλεύουν σωστά.
themis
2 December 2007
32
τι δουλεία έχει το 1,3 της εικόνας με τον ήχο ,η βλακεία είπα?:AFADF0:
themis
2 December 2007
32
δηλαδή περνά ήχος μέσω scaler αν κατάλαβα καλά?
η συνεχίζω να λέω βλακείες:2thumb22sup:
