[Επίσημο] Google Pixel 3 and 3 XL
airb
25 May 2008
15,129
Λιβαδειά
Pixel 3Pixel 3 XL
Operating system- Android 9 Pie
- Minimum 3 years of OS and security updates
- Android 9 Pie
Display
- 5.5" Display
- FHD+ flexible OLED at 443 ppi
- 18:9
- Corning Gorilla Glass 5
- Always-on display
- Now Playing
- 100,000:1 super contrast ratio
- Full 24-bit depth or 16.77 million colours
- True black level
- HDR support (UHDA certification)
- 6.3" Display
- QHD+ OLED at 523ppi
- 18.5:9
- Always-on display
- Now Playing
- True black level
Camera
Back
- 12.2 MegaPixel dual-pixel
- 1.4 mm
- Autofocus + dual pixel phase detection
- Optical + electronic image stabilisation
- Spectral + flicker sensor
- f/1.8 aperture
Front
- 8 MegaPixel Wide-Angle and Telephoto Cameras
- Wide-angle: f/2.2
- Telephoto: f/1.8
Back
- 12.2 MegaPixel dual-pixel- 1.4 mm
- f/1.8 aperture
Front
- 8 MegaPixel Wide-Angle and Telephoto Cameras- Wide-angle: f/2.2
- Telephoto: f/1.8
Camera
Video
Back
- 4K: 30fps
- 1080p: 30fps, 60fps, 120fps
- 720p: 30fps, 60fps, 240fps
Front
- 1080p: 30fps- 720p: 30fps
- 480p: 30fps
Back
- 4K: 30fps- 1080p: 30fps, 60fps, 120fps
Front
- 480p: 30fps
Processors
- Qualcomm Snapdragon 845
- 2.5 Ghz + 1.6 Ghz, 64-Bit Octa-Core
- Adreno 630
- Pixel Visual Core
- Titan M security module
- Adreno 630
- Pixel Visual Core
Memory
Storage
- 4 GB LPDDR4x RAM
- 64 GB or 128 GB storage
- 4 GB LPDDR4x RAM
Battery
- 2915 mAH
- 18 W USB Type-C Charger
- 8 W Fast Charging
- Qi Wireless Charging
- 3430 mAh
- 8 W Fast Charging
Wireless
Location
Wireless
- Wi-Fi 2.4GHz + 5.0GHz 802.11a/b/g/n/ac
- Bluetooth 5.0 + LE
- NFC
- Google Cast
Location
GPS | GLONASS | BeiDou | Galileo
Wireless
- NFC
- Google Cast
Location
Ports- USB Type-C, 3.1, Gen 1- Single nano SIM- USB Type-C, 3.1, Gen 1- Single nano SIM
Sensors
- Active Edge
- Back-mounted Pixel Imprint fingerprint sensor for fast unlocking
- Proximity / Ambient Light sensor
- Accelerometer / Gyrometer
- Magnetometer / Barometer
- Android Sensor Hub
- Advanced x-axis haptics for sharper / defined response
- Active Edge
Media
Audio
- Dual Front-Firing Stereo Speakers
- 3 Mics
- Noise Suppression
- 3 Mics
- Noise Suppression
AR | VR- Built for VR to work with Google Daydream View headset- Built for VR to work with Google Daydream View headset
Colours
- Clearly White
- Just Black
- Not Pink
- Clearly White
- Just Black
- Not Pink
Dimensions
weight
- 145.6 x 68.2 x 7.9 mm
- 148 gr
- 158 x 76.7 x 7.9 mm
- 184 gr
Materials
- Aluminum Frame + Hybrid Coating
- Corning Gorilla Glass 5 on the front
- Soft Touch Glass (Corning Gorilla Glass 5) on the back
- IP68 dust and water protection
What's in
the box
- Pixel 3
- Quick Switch Adaptor
- USB-C to USB-C cable
- Pixel USB-C earbuds
- USB-C to 3.5 mm headphone adaptor
- SIM tool
- Quick Start Guide
- Pixel 3 XL
- SIM tool
- Quick Start Guide
SAR info- Head: 1.34 W/kg
- Body: 1.34 W/kg
- Head: 1.35 W/kg
- Body: 1.19 W/kg
Reviews
- GSM Arena
- Trusted Reviews
- Android Central
- Techradar
- Tomsguide
- Digital Trends
- Android Authority
Official page- Google
Yperion
21 June 2006
43,515
BVR (Beyond Visual Range)
DisplayMate: Το Pixel 3 XL έριξε κιόλας το iPhone XS Max από την κορυφή και είναι πλέον το smartphone με την καλύτερη οθόνη...https://www.techgear.gr/displaymate-pixel-3-xl-best-smartphone-display-award-145803/
Πλέον κορυφαία οθόνη έχει το Pixel με AMOLED της Samsung αφήνοντας δευτερο το iPhone με AMOLED Samsung ενώ τρίτο είναι το Note 9 που έχει....σωστά το μαντέψατε AMOLED Samsung.
Και όσο θυμάμαι πριν μερικά χρόνια πως κάποιοι προσπαθούσαν να μας πείσουν ότι δεν είναι καλές.:flipout::flipout:
sfortis
Administration Team
3 August 2006
11,396
t3.large
Κινητο με σεμενεδάκι δεν παιρνω και ας ειναι και pixel 3.
Χωρις πλάκα, ειναι αστεία μεγάλο το notch του. Μια κακή μοδα.
Ουτως η αλλως τα googleοφωνα πεθαναν για εμενα μετα τα nexus. Πραγματικά δεν εχω δει να το εχει άνθρωπος τοσα χρόνια.
