[Επίσημο] iPhone 15 Pro | 15 Pro Max
Ήρθε η natural titanium παντόφλα. Μπήκε αμέσως το 17.0.3 καλού κακού, ενώ αμέσως έγινε και η ρύθμιση για max φόρτιση στο 80%. (aka οποίος έχει καεί στο χυλό, μετά φυσάει και το γιαούρτι).
Αισθητά πιο ελαφρύ από το παλιό, αντίστοιχα ογκώδες ωστόσο. Πάντως είχα ξεχάσει πόσο απόλαυση είναι το texting σε αυτό το μέγεθος, γράφεις και email χωρίς θέμα.
22 June 2006
34,864
NEO HRAKLEIO
The 15 Pro deserves a place next to the inimitable iPhone 4 which Steve Jobs himself described as related to a 'beautiful old Leica camera'. This iPhone feels like a camera.
As for the files as they are today, I noticed colors are ever so slightly more pleasant. Maybe it's software—we'll dig into that later—but it's always possible this is due to lens coating changes this year.
22 June 2006
34,864
NEO HRAKLEIO
On iPhone 15 Pro, ProRAW files contain a bit more noise. This is most pronounced on the telephoto lens, which tells you in no uncertain terms that it's punching above its weight when light levels dip too low.³
This is a welcome change, as previously iPhone generations tried to hide this behind heavy noise reduction, resulting in that smudged, 'watercolor' effect. It seems odd to cheer on noise, but this is genuinely a huge improvement as fewer details are lost, and it might even help people take better photos.
For the everyday user, iPhone 15 and 15 Pro offer one of the biggest camera upgrades in the history of the iPhone. Tech people tend to miss this because a new iPhone is about all the details that tie hardware and software improvements together. Most iPhone users took 12 megapixel photos, had a small-ish zoom range, and switch to a separate mode for portrait Photos. With iPhone 15 Pro Max's default 24 megapixel resolution, added 'lenses' under the main camera lens, automatic depth capture for portraits, and that 5× lens, this release is massive for casual photographers.
anderm
Γενικός Διαχειριστής
1 August 2009
10,368
Αθήνα...
Αυτή η φωτογραφία τώρα θεωρείται καλή και εντυπωσίασε τον reviewer;
Looter
20 July 2008
1,630
Κάθε χρόνο υπάρχουν αρκετοί reviewers που σκίζουν τα ρούχα τους για το πόσο εντυπωσιασμένοι έμειναν από το νέο iPhone.
Από κάθε review ζήτημα να μπορείς να κρατήσεις το 10% από αυτά που αναφέρουν.
Και μετά τους κάνει εντύπωση που πέφτουν οι πωλήσεις…
Βασικά αν δεις στο άρθρο, αυτή η συγκεκριμένη είναι με digital zoom, και τη συγκρίνει με αυτή του 5άρη από κάτω:
Μια χαρά είναι, βέβαια έχει αφαιρέσει τα flare κλπ., και ΚΥΡΙΩΣ ξέρει τι του γίνεται φωτογραφικά, δύσκολα θα έβγαζε κάποια από τις φωτό του άρθρου κάποιος τυχαίος.
chrisssb
26 August 2008
29,793
Kingdom of Rain
Μεγειά Ιάσωνα! Να το χαρείς!
22 June 2006
34,864
NEO HRAKLEIO
Υπαρχουν τόσες καλές φωτό στο άρθρο… εσυ κόλλησες σε μια που δεν σου αρέσει!
Οποίος ασχολείται σοβαρά με φωτογραφία καταλαβαίνει…
spcav
18 August 2006
16,666
Με yes.
Το texting γιατί σε προβληματίζει στα μικρά;
Εμενα το βασικό μου πρόβλημα είναι το τραγικό (και επιμόνο) auto correct τησ Apple και όχι το μέγεθος (ακόμη και χωρίς γυαλιά).
22 June 2006
34,864
NEO HRAKLEIO
και η google παρουσιασε το νεο pixel 8 pro με 5χ φακο, αλλα εκανε αυτο που ειπα παραπανω , εβαλε δηλ. παρομοιο αισθητηρα με το βασικο (48 Μp) κι ετσι εχει καλυτερο αποτελεσμα σε 5x και πολυ καλο υβριδικο μεχρι 10χ (ισως και παραπανω).
ελπιζω να το κανει του χρονου και η Apple , οπως το ιδιο και με τον υπερ ευρυγωνιο.
Το pixel θα ηταν το μονο Android αυτη τη στιγμη που θα κοιταγα σαν δευτερο κινητο, αν ερχοταν κανονικα στην Ελλαδα.
22 June 2006
34,864
NEO HRAKLEIO
για τον Τασο! :p
που ζηταει ομαλο ζοομ σε ολο το ευρος... δεν το ειχα προσεξει οτι υπαρχει τετοια δυνατοτητα.
Τη περιγραφει μεταξυ αλλων στο παραπανω βιντεο που εβαλα (#435 ποστ)
Οσο ζεις μαθαινεις...
Απο 0.5χ μεχρι 5χ .
Reactions: takisot
