[Επίσημο] Xiaomi Mi Mix 2
airb
25 May 2008
15,151
Λιβαδειά
Display
- 5.99" (diagonal)
- 18:9 aspect ratio
- 2160 x 1080 FHD+
- 403 PPI, 1500:1 contrast ratio
- DCI-P3 color gamut, high color saturation
- Sunlight display
- Night display
- Reading mode
- Color temperature adjustment
- Supports standard display
CPU- Snapdragon 835, max 2.45GHz
GPU- Adreno 540
Battery
- 3400mAh (typ) / 3300mAh (min)
- Built-in rechargeable lithium-ion battery
- 9V/2A Quick Charge 3.0
- USB Type-C reversible connector
RAM- 6GB dual channel LPDDR4x
Storage- 64 | 128 | 256 GB
Rear
Camera
- 12 Megapixel
- 1.25μm, 4-axis OIS
- 5-piece lens, f/2.0 aperture
- Two-tone flash
- PDAF autofocus
- Low-light enhancement
- HDR adjustments
- Panorama
- Burst mode
- Face recognition
Front
Camera
- 5 Megapixel
- 1080p video call with real-time Beautify
- Beautify with 36 smart beauty profiles
- Selfie countdown
- Face recognition
- Mirror
Camera
Video
- 4K video, 30 fps
- 1080p video, 30 fps
- 720p video, 30 fps
- 720p slow-mo, 120 fps
Connectivity
- 802.11a/b/g/n/ac protocols
- 2.4/5G Wi-Fi | Wi-Fi Direct
- Wi-Fi Display
- Bluetooth 5.0
- 2x2 MIMO technology, supports MU-MIMO
Sensors
- Ultrasonic proximity sensor
- Gyroscope
- Accelerometer
- Electronic compass
- Ambient light sensor
- Vibration motor
- Barometer
- Hall sensor
Global Bands- 43 bands
- 6 network modes
GPS Navigation
- GPS | AGPS | GLONASS | BeiDou positioning
Dimensions- 151.8 x 75.5 x 7.7 mm
Weight- 185 gram.
Color- Ceramic Black
- Ceramic White
Design- Four-sided curved ceramic body
In the Box
- Mi Mix 2
- Protective cover
- Power adapter
- USB Type-C cable
- Type-C to audio converter
- SIM insertion tool
- Warranty card
- User guide
SAR- Head: 0.39 W/kg
- Body: 1.77 W/kg
Store
- Skroutz
- Gearbest
- Banggood
- Geekbuying
- FastTech
- MiniDeal
- Vickmall
Review
- GSM Arena
- Phone Arena
- Android Authority
- The Verge
Official Page- Xiaomi
ΣΩΚΡΑΤΗΣ Τ.
7,145
ΑΘΗΝΑ
Απάντηση: Re: [Επίσημο] Xiaomi Mi Mix 2
330 ευρώ γράφει και μαζί με την ασφάλεια τελωνείου,πάει στα 357 ευρώ όταν στο skroutz ξεκινάει από τα 388 ευρώ και στο bestprice στα 372.
Πλέον δεν συμφέρει να φέρεις τίποτα από τους Κινέζους.
Kosh
7 September 2006
91,593
Εκεί ψηλά.....
Το βασικο ειναι οτι βγαινει το καινουργιο που θα ειναι πραγματικα ξεχωριστη συσκευη.
ΣΩΚΡΑΤΗΣ Τ.
7,145
ΑΘΗΝΑ
Ποιό καινούριο εννοείς;To 2S?
Γιατί εγώ περιμένω το Xiaomi Mi 7 με αγωνία.
https://el.geekbuying.com/item/Xiaomi-Mi7-Plus-6-01-Inch-6GB-64GB-Smartphone-Black-391679.html
btw,βλέπω τώρα μία προσφορά του banggood που με κουπόνι και ασφάλεια τελωνείου βγαίνει στα 310 ευρω.
Λίγο θέλω να πατήσω το κουμπί αλλά με σταματάει αυτό το Global Bands που γράφει ενώ θα έπρεπε Global ή International Rom.
airb
25 May 2008
15,151
Λιβαδειά
Ίδιο με το παλιό είναι, μόνο επεξεργαστή έχει νεότερο
Kαι πολύυυ καλύτερη κάμερα (για μένα μόνο αυτό του έλειπε) :smile:
