Eversolo DMP-A6 / Α8 Streamer
knick
28 September 2010
992
Citizen of the world
NEO firmware (v1.1.70) μέσα σε 20 μέρες
Changelogs:
Control APP(Android version: v1.10.76 IOS version: v1.0.53)
1. Added playback details display theme settings
2. Added more sorting modes for the album
3. Added album year display for album details
4. The play queue adds the edit list function
5. The play queue adds the function of adding to the playlist (effective when the number of tracks is less than 200)
6. Optimized the album track collection function
7. Optimized the problem that the same screen cannot be connected occasionally
8. Optimized the reconnection function on the same screen
9. The track list increases the track duration display
10. Optimized the function of editing device name
11. Optimized the problem that the music service cannot obtain data occasionally
12. Optimized the problem of incomplete display of files in the music library list (Android only)
System
1. Optimized the problem that Apple Music occasionally stops playing
2. Optimized the problem that the VU meter does not move after some apps switch tracks
3. Optimized the playback of FLAC 32bit tracks
4. Optimized the problem that the volume cannot be adjusted when individual APPs output through the optical fiber
5. Added the function of editing tracks in the play queue
6. Added the function of sorting the tracks in the play queue according to the list
7. Optimized the problem that the album cover display in the playback details interface was wrong after exiting the mobile screen projection
8. Added the function of sliding left and right to switch themes in the playback details interface
9. Added playback details interface to display album information
9. Optimized the problem that the artist cannot be obtained from the CUE file
10. Added the function of playing CUE files in the file manager
11. Added the function of clearing the play queue
12. Added the year display on the album details interface
13. Added more sorting modes in the album list interface
14. Optimized the problem that the display of the interface for switching input sources in the playback details interface is incorrect
15. Optimized track information acquisition
16. Added the theme setting of the playback details interface in the settings
17. Optimized the playlist sorting function
18. Optimized the Airplay function
19. The play queue adds the function of adding to the playlist (effective when the number of tracks is less than 200)
20. The track list increases the track duration display
21. Optimized the problem that when CD Ripper converts to WAV format, no ID3 information is written
22. Add sorting function in music library device
23. Added some TCP control instructions (http://music.eversolo.com/.../Eversolo_DMP-A6_TCP_en_v1.0...)
24. Optimized the problem of incomplete data acquisition from the network disk
25. Added Dropbox network disk function (BETA)
27. Fixed some bugs.
Check the online update.
Online push will be carried out in stages but for someone want to try it first can download it below:
https://music.eversolo.com/.../DMP-A6_R_v1.1.70...
MD5: C2284B6263EAF506D2714D614A8E5FAD
knick
28 September 2010
992
Ένα ακόμη review που παρά τον κατ' αρχήν "επιφυλακτικό" τίτλο του δίνει περισσότερα πλεονεκτήματα από μειονεκτήματα. Από τα μειονεκτήματα του (4 στο σύνολο τους) μόνο η σύνδεση HDMI που έχει μόνο audio out εχει κάποια σημασία. Τα υπόλοιπα 3 ( 1. η εφαρμογή Amazon music (who cares όταν υπάρχει το Tidal) 2. το ότι δεν έχει φυσικό remote control και 3. ότι είναι ...δυσεύρετο !!) είναι πραγματικά ελάσσονος σημασίας.
Γιώργος ΚΟΨ
20 June 2006
2,896
GLYFADA
To remote control κατόπιν λαικής απαίτησης θα κυκλοφορήσει ΄συντομα ως option. (δεν έχει ουσιαστική χρήση βέβαια...αλλά...)
Όσο αφορά το ότι είναι δυσεύρετο, θα λυθεί έως 10/7 , για την χώρα μας!!!
Reactions: knick
Struggler
11 November 2007
543
Τελικά το αγόρασα κ εγώ, ΚΑΤΑΠΛΗΚΤΙΚΌ μηχανάκι. Η απόκριση του είναι αστραπιαία, tidal connect, Spotify connect, τα μενού είτε από το κινητό είτε από την touchscreen η οποία έχει απίστευτη αίσθηση. Είδε κατευθείαν μέσω smb το synology ds118 που το χω συνδεδεμένο στο router. Κ σκαναρε ολα τα αρχεία Για την ώρα το τρέχω ασύρματα. Κανένα πρόβλημα. Από ήχο καταπληκτικό. Τώρα βέβαια το συγκρινα με το shanling m6 pro 21 dap κ σε α/β για αρχή δεν μπορώ να πω ότι κατάλαβα τεράστια διαφορά. Έπαιζε ήδη καλά το dap, δεν ξέρω αν φταίνε τα αυτιά μου ή κάτι άλλο.... 🙄
Σημείωση έχω δανειστεί κ το lab12 dac1 reference για δοκιμή. Έχω σύνδεση usb στο lab 12 κ μετά Moonriver. Κ επίσης rca έξοδο στον Moonriver. Οπότε μπορώ α/β να βγάλω συμπέρασμα, θα το χω το lab12 2-3 μέρες οπότε θα επανέλθω με νέα. Ο Στράτος από την lab12 μου πε ότι δεν θα χει σχέση το εσωτερικό dac με του eversolo.
Είπα για το πόσο γρήγορο είναι, δεν έχω ξαναδεί τέτοια απόκριση σε συσκευή,.... 😱
Struggler
11 November 2007
543
Λοιπόν μέρα 2η. Δοκίμασα eversolo a6 και lab12, είχα παρόντες κόρη κ συζηγο με μετρημένα 😁 πολύ καλύτερα αυτιά από τα δικά μου. Δεν τους είπα τι ακούνε έβαζα μια το ένα μια το άλλο σε κάθε κομμάτι κ μετά μου έλεγαν. Γενική ομολογία το a6 είχε λίγο πιο λαμπρά πριμα, βέβαια είναι αρχή ακόμη βέβαια. Ο lab 12 πιο ισορροπημένα πρίμα, κ τα 2 γεμάτο ήχο σε χαμηλά, σε κάποια κομμάτια άρεσε ο lab12 σε κάποια ο a6 ασχέτως είδος μουσικής. Streaming από tidal. Κ οι 2 συμφώνησαν ότι υπάρχουν μικροδιαφορες κ δεν θα έδιναν 2400 για τον lab 12. Υπόψιν ο lab12 είναι demo κ έχει παίξει περισσότερο. Στο α6 είχα πάνω δοκιμή iFi supanova καλώδιο ρεύματος, στο lab12 της lab12 καλώδιο ρεύματος.
Οποτε ερωτώ, έχουμε κ οι 3 πρόβλημα? Φταίει ο χώρος που δεν μπορούν να ακουστούν οι οποιες διάφορες? Μήπως είναι αδύναμος κρίκος τα ηχεία? Διότι είχα διαβάσει πολύ καλό το dac του α6 αλλά όταν το συνεδεαν με εξωτερικά dac ήταν πολυυυ καλύτερο. Εμείς δεν το νιώσαμε..... 🙄🙄
μπορείς να μας πεις λίγες λεπτομέρειες για το σύστημα?
Struggler
11 November 2007
543
Ενισχυτής Moonriver 404 reference, ηχεία klipsch rf35, καλώδιο ηχείων qed xt40i κ interconnects wireworld oasis. Lab12 κ a6 στις εισόδους του Moonriver με α/β δοκιμή γρήγορη, (εννοώ δεν έβαζα έβγαζα καλώδιο) χώρος απεριποιητος, ασσυμετρος, σαλονοτραπεζαρια περίπου 40μ2. Rt60 τώρα χωρίς χαλιά περίπου 0.5 με 0.6,με χαλιά 0.4 με 0.5. Τα χαμηλά φτάνουν κ 0. 8 κάποιες συχνότητες.
Καλημερααα
Καλημερααα
Και τα δυο τα έπαιζες ως DAC? ή είχες το eversolo συνδεδεμένο με το lab και άκουγες τη μια το eversolo μόνο και την άλλη με το eversolo να δίνει ψηφιακή έξοδο στο lab12?
Δε κατάλαβα καλά τη διαδικασία.
Λογικά το Lab 12 το συνέδεσες μέσω s/pdif με το Eversolo. Μόνο και μόνο αυτή η διασύνδεση αρκεί για να χάσεις αρκετά σε σχέση με την εσωτερική διασύνδεση που έχει το Eversolo με τα δικά του DAC.
Για να εκτιμήσεις πραγματικά τις δυνατότητες του Lab 12 πρέπει να το τροφοδοτήσεις μέσω USB και μάλιστα από καλό audio grade streamer (όχι laptops και τέτοια).
Struggler
11 November 2007
543
Το eversolo συνδέθηκε στο lab12 μέσω usb με καλώδιο (δοκιμή) των 500 ευρώ της lab12, οπότε από τη μια το eversolo (κ το εσωτερικό του dac) με rca to rca στον ενισχυτή, κ παράλληλα eversolo>lab12 μέσω usb>rca στον ενισχυτή. Κ τεστ α/β,
Struggler
11 November 2007
543
Ναι optical, coaxial. Τα ηχεία τα χω χρόνια μέρους 5. 1 με marantz sr7013, κ ήθελα βελτίωση σε δικαναλο και να αλλάξω τα ηχεία. Αλλά άκουσα τον ενισχυτή, οπότε αγόρασα πρώτα ενισχυτή, τώρα πήρα πηγή κ το επόμενο βήμα ηχεία.
Δεν έχω ακούσει τίποτα από όσα έχεις οπότε αυτά που λέω είναι λίγο...θεωρητικά.
Το eversolo που έχεις είναι κατά γενική ομολογία και αποδοχή ένα πολύ καλό μηχάνημα ακόμα και στον τομέα του dac.
Ωστόσο προσωπικά δε θεωρώ ότι θα μπορούσε να είναι τόσο κοντά στο lab12.
Τα ηχεία είναι σίγουρα το bottleneck του συστήματος, οπότε μη βιάζεσαι να πάρεις αποφάσεις τώρα, θεωρώ ότι το eversolo με το lab12 θα είναι ένας πολύ καλός συνδυασμός.
Στη θέση σου θα δοκίμαζα και την coaxial σύνδεση, έχω ένα γνωστό με πολύ καλό dac με usb και επέλεξε streamer με coaxial σύνδεση.
Το γεγονός ότι πήρες πρώτα ενισχυτή και μετά θα αποφασίσεις για ηχείο είναι λίγο...ανάποδο.
You may struggle to find the right speaker.
Struggler
11 November 2007
543
Όταν τον άκουσα ήταν πολύ ανώτερο από ότι είχα ακούσει, κ τον βρήκα μεταχειρισμένο με εγγύηση οπότε ήταν ευκαιρία, είχα ακούσει gato, primare, Arcam, Cyrus, jbl, όσο για τα ηχεία θα την βρω την άκρη... 😋😊
Panoramix
31 January 2012
11,464
Το λογικό πάντως είναι να ψωνίσεις το eversolo τώρα και όταν με το καλό αλλάξεις ηχεία να κάνεις επανεκτιμηση της αναβάθμισης με το lab12 κρατώντας ίσως το eversolo σα streamer. Τα ηχεία που έχεις νομίζω είναι περισσότερο προσανατολισμενα στο home cinema.
steadyshot
16 July 2012
355
Θα εξοικονομήσεις 1600 ευρώ για τα ηχεία και νομίζω έως τα 2,5 χιλ θα βρεις ένα πολύ καλό ηχείο, το οποίο θα κάνει τη μεγαλύτερη διαφορά…
Reactions: Struggler
Δημοκηδής
23 June 2006
9,991
Αν το lab 12 δεν το πήρες, παρά μόνον για δοκιμή, σίγουρα τα χρήματα του πρέπει να πανε στα ηχεία ... και αν μελλοντικά χρειαστείς καλύτερο ντακ από αυτό του εβερσόλο, το ξανασκέφτεσαι ... οι διαφορές μεταξύ των ντακς εν γένει είναι σχετικά μικρές, μεταξύ ηχείων όμως πολύ- πολύ μεγαλύτερες ...
ika
20 September 2010
4,930
Τα ψηφιακά κάθε 6 μήνες αλλάζουν, σαν τα κινητά έχουν γίνει.
Αν δεν σου περισσεύουν, καλύτερα κάποια στιγμή να επενδύσεις τα πολλά € σε νέα ηχεία που λένε πιό πάνω οι συμφορουμίτες.
Πρέπει να ταιριάζουν και οικονομικά με τον ενισχυτή σου, τώρα είναι στο 1/3 νομίζω
tonal
29 September 2006
2,904
Σχετικό είναι αυτό.
Ένα καλό DAC παραμένει ένα καλό DAC και σε μερικά χρόνια από τώρα. Δεν είναι τόσο ραγδαίες οι αλλαγές.
Αυτό που αλλάζει συνεχώς είναι τα streamers. Εκεί αν το προϊόν δεν έχει συνεχή υποστήριξη με αναβαθμίσεις λογισμικού και δεν είναι εύχρηστο τότε υπάρχει πρόβλημα.
