Exogal Comet DAC
Gojakla
20 May 2009
5,856
Η Exogal είναι παιδί των κυρίων Jim Kinne, Larry Jacoby, Jeff Haagenstad και Jan Larsen.
Ο monsieur Kinne, είναι ο mastermind πίσω από πολλές δημιουργίες της Wadia, όπως τα Wadia 27 decoding computer & Wadia 270 CD transport.
Στη γκάμα της εταιρίας έχουμε 3 προϊόντα. Τα Comet DAC, Ion Digital Amplifier και Comet Upgraded Power Supply.
Παραθέτω ένα σημαντικό κομμάτι από το review του Audiostream:
I asked my contact at Exogal about the D to A process employed in the Comet. Part of the response I received from Jeff Haagenstad, Exogal's CEO, is worth repeating here:
The short answer to your question is "No, we won't provide answers to the questions about How We Do It. The longer version is that we don't do our D to A conversion in a conventional way. We have implemented a 6-core DSP in an FPGA (and we blew the "Read" bit, so we can write to it for upgrades but it can't be read or decompiled...) and we use some signal processing approaches that are unconventional in audio but not in wider signal processing work. We wanted to pursue patents but since it's all based on other algorithmic approaches there was too much prior art for us to do the patents. Hence the need to keep it Trade Secret.
If you look at our backgrounds, you'll see that in addition to audio experience, Jim worked on some broadband networking technologies, I've worked on GPS, Vehicle Guidance and Computer Imaging applications, and Jan has a bunch of different signal processing experience. We have all worked in applications with harsh and unforgiving computational environments so converting a relatively clean PCM signal to analog audio is actually a fairly simple thing for us to do. (Conceptually, if not mathematically)... The EXOGAL DSP platform (on which the Comet is the first of many products to exploit the technology) does have some conventional DAC chips but only the final output stages of the DAC chips are used for the final translation into analog. The main output uses PCM4104 DAC's and the headphones use PCM5122 DAC's. The outputs are buffered using TI/National LME49600 buffers. These are high-current, high-impedance, class AB buffers with no feedback. Beyond that, we ain't sayin'.
Official Site
Specs
Digital Inputs
AES/EBU on XLR, SPDIF on 75Ohm BNC, Toslink, USB-B, Analog on isolated RCA
Analog
Outputs
One Pair Balanced (XLR), One Pair Unbalanced (RCA)
Weight
9.2 lbs (4.2 kg)
Dimensions (HWD)
1.875 x 7.45 x 11.5 in., (4.76 x 19.0 x 29.2 cm)
Finish
Clear (Silver) or Black Anodized Aluminum
Features
- Asynchronous USB, AES/EBU, SPDIF, Toslink, and line level Analog input
- Direct connection analog outputs with 32-bit Digital Volume Control
- Analog Outputs: one pair balanced (XLR), one pair unbalanced (RCA), one stereo Headphone
- Single ended and balanced analog outputs can be used simultaneously.
Single ended outputs can be programmed as stereo, or center/subwoofer operation.
Single ended outputs have a programmable offset level from balanced outputs.
- Controlled by the Exogal Remote App for Android phone or tablet (running 4.3 or higher with BLE support) or an iPad, iPhone 4s or newer, or iPod Touch.
Reviews
TAS / Audiostream
Έρχεται με remote και θα σας αποσπάσει περί τα 2500 γιου ες ντολλαρς.
Δημοκηδής
23 June 2006
9,987
Αντουάν, τελικά δεν κατάλαβα τι ντακ έχεις πάρει εσύ ... έμεινες με το τζικ, ή προχώρησες στην πώληση του - όπως σχεδίαζες - και την αγορά κάποιου άλλου ;
Gojakla
20 May 2009
5,856
Σπύρο έχω άλλο στο σπίτι.
Θα τα συζητήσουμε εν καιρώ... :ernaehrung004:
