Φακοί Cine PL - EF - E - RF -Z -L mount
Kosh
7 September 2006
91,380
Εκεί ψηλά.....
Η επισημη παρουσιαση του Tokina Cinema 11-20mm
Kosh
7 September 2006
91,380
Εκεί ψηλά.....
Musashi Takumi 2 Cine Zoom Announced – Full Frame 29-120mm T2.9 PL
Takumi 2 29-120mm T2.9 FF PL cine zoom lens
This new lens comes with some nice details on its spec sheet, no doubt about it. Hopefully, the company can deliver what is promised here. A field test will have to prove the claimed specs, but here it goes:
Focal Length: 29mm-120mm
Zoom Ratio: 4.1x
T Number: T2.9 constant
Iris Blades: 9 blades
Sensor Compatibility: Full Frame up to 40.96 x 21.60mm (diagonal: 46.3mm)
Mount: PL mount
Minimum Focus Distance: 4ft / 1.2m from image plane
Flange Focus (Flange Back Distance): 52mm
Angular Field of View (h x v): @29mm: 70.5° x 40.9° // @120mm: 19.4° x 10.3°
Focus Ring Rotation: 280°
Zoom Ring Rotation: 160°
Iris Ring Rotation: 70.7°
Front Diameter: 136mm
Length: 370mm
Weight: 7.5kg / 16.5 lbs
Country of Manufacture: Japan
The Takumi 2 29-120mm T2.9 will ship around the end of May, beginning of June this year. Stay tuned for more details as they become available to us.
The Takumi 1 40.6 – 332mm T4.8 is available now for around $38,000, and there’s also a s35 version of the Takumi 1 23.9 – 195mm T2.9 ($25,000).
Kosh
7 September 2006
91,380
Εκεί ψηλά.....
Nεος Μeike Cine FF 85mm f2.1 σε μοντουρες
  • PL version weighs 1019g (2.25lbs) and it is 102.4mm long
  • EF version weighs 1100g (2.43lbs) and it is 110.5mm long
  • RF version weighs 1171g (2.58lbs) and it is 134.4mm long
  • E version weighs 1164g (2.57lbs) and it is 136.4mm long
  • L version weighs 1159g (2.56lbs) and it is 134.4mm long
Kαι το timeline κυκλοφοριας τους
Kosh
7 September 2006
91,380
Εκεί ψηλά.....
Τιμή στα 5000 (λιγο πιο τσιμπημενη απο τους Sigma cinema zooms)
Καλυπτει S35 αισθητηρες και θα πλαισιωσει τοους αλλους 2 zoom φακους της Tokina
Kosh
7 September 2006
91,380
Εκεί ψηλά.....
evanfotis
26 March 2008
5,478
Ανέβασε μαζεμένα ένα σωρό βιντεάκια ένα για κάθε φακό Canon FD (ίσως να μπει και η μοντουρα fd στο τίτλο του νηματος; ) το Media division στο youtube.
Νομίζω είναι αποκόμματα από τις υπερπαραγωγές του, αλλά είναι πιο πρακτικά, για πληροφορίες συγκεκριμένων φακών.
