Eιναι προφανες οτι το high mode στα 550λ θα διαρκει για καποια συγκεκριμενη περιοδο (καποια λεπτα) και μετα θα πεφτει, οπως στους περισσοτερους φακους.
Turbo: 980 Lumens (To avoid overheating, the light will enter High mode automatically after 3mins continuous use)
High: 550 Lumens (1.7hrs)
Features
● CREE XM-L2 LED, with a lifetime of up to 50,000 hours;
● Brand-new Dual-button Side Switch System, slightly depress the side switch buttons for output ranging from 30 to 980 lumens, Police Strobe, Aviation Signal, SOS, Strobe and Moon Mode:
Mid: 220 Lumens (1.8hrs)
Low: 30 Lumens (31hrs)
● Constant current circuit, constant output;
● Effective range of 315 meters;
● Intensity: 24800cd;
● Uses 4*AA (Alkaline, Ni-MH, Nickel-cadmium) batteries;
● High quality reflector with soft beam pattern;
● Working voltage: 3~6V;
● Optimized Deep Reflector, great throw distance as well as perfect beam pattern;
● Dimension: 120.6mm (length) x 40mm (head diameter) x 42mm (body diameter)
● Weight: 165.4g (battery excluded);
● High quality aerospace-grade aluminum alloy, Stainless steel head retaining ring;
● Military specification Type III- hard anodized body;
● Waterproof, in accordance with IPX-8 standard;
● Ultra-clear tempered glass lens resists scratches and impacts;
● Tail stand capable- can be used as a candle
● Accessories: Lanyard, O-ring, Holster
