Μια εβδομάδα έμεινε για τον διάδοχο.
Σήμερα διέρρευσαν και τα χαρακτηριστικά.
Και έλεγα να μην πάρω μηχανή σύντομα.
http://www.fujirumors.com/fujifilm-x-t2-full-specs-images-leaked/Full Specs Χ-Τ2 Google translated
β 24.3MP CMOS sensor
β Image processing engine X Processor Pro
β Video 4K30fps. Full HD60fps
β Video of the bit rate is 100Mbps
β The maximum speed of the shutter is 1/8000 seconds. 1/32000 sec electronic shutter
β Synchro speed of the flash is 1/250 seconds
β AF 325 points can be selected intelligent hybrid phase difference AF
β The body is in a magnesium alloy, improve the durability of the dial. Dust and water specification
β EVF is 2.36 million dots. Refresh rate 100fps
β 3-way tilting 3 inches 1.62 million dot LCD monitor
β Dual SD card slot. UHS-II support
β AF-C custom settings
β ISO range is ISO200-12800 (RAW)
β Wi-Fi built-in. Remote shooting correspondence. Instax Share printer support
β 16 kinds of film simulation modes, including the ACROS
β That can customize the settings screen βMy Menuβ
β Normal / boost mode switching
β 14bit RAW lossless compression. Camera RAW development
β Exposure compensation +/- 5EV
β 256-segment metering (multi-spot average, spot, center-weighted)
β Interval Shooting
β 13 kinds of creative filter
β The battery is NP-W126S. The number of possible shots 350 sheets
β 3.5mm microphone jack. 2.5mm remote terminal. USB3.0 terminal. Micro HDMI terminal
β You can use all of Fujinon X mount lens group
When the vertical position power booster grip use of the option, can use a plurality of battery at the same time, continuous shooting is speeding up, the shooting interval, shutter time lag, the image disappearance time is shortened. In addition, 4K of recording time is extended up to 30 minutes.
