GearBest gadgets offers
Gearbest
7 February 2017
1,601
[URL="http://www.gearbest.com/lids-bottle-caps/pp_274603.html"]
Electric Automatic Juice Water Dispenser - WHITE
[/URL]
$0.99 with coupon:AutomaGB
Gearbest
7 February 2017
1,601
Creality 3D CR - 10 3D Printer - EU PLUG BLUE
$369.99 with coupon VCR10
● With LCD screen and keypad for easy offline use
● Supports SD card off-line printing, can also directly print with USB adapter
● 300 x 300 x 400mm build volume, just right for you
● Supports multiple 3D printing filaments: ABS / PLA / TPU and so on
● Further simplified structure means fast assembly and easy adjustment, which saves you both time and energy
● Enhanced stability and reliability: aluminium plate ensures more stable printing
● Assembly is simple and suitable for DIY customers
● It is unassembled DIY kit, which provides you an unforgettable step-by-step learning experience of 3D printer from scratch. As long as you have a passion for creativity, you can not afford to miss this product
● Nozzle temperature: below 250 Deg.C in normal state, max. 270 Deg.C
Gearbest
7 February 2017
1,601
Awei A920BL Sports Earbuds - GRAY
Bluetooth V4.1 / Multi-point Connection / Noise Cancellation / with Mic for iPhone Samsung
$8.99 with Coupon:GBGR920
- Support multi-point connection, connect with two different devices at the same time.
- Can call or answer the phone.
- Support voice report number automatically.
- Support voice reminding function.
- With power consumption display function for iPhone.
- With vioce controlling function.
- Support song switching.
- CVC 6.0 smart noise reduction.
Gearbest
7 February 2017
1,601
Bluedio T4 Portable Bluetooth Headphones - BLACK
Stylish Look / Noise Cancellation / Hands-free Call / Voice Prompt
$55.99 with coupon T4Porta
● ANC active noise reduction, clear sound effect
● Type-C charging interface, fast charging speed
● Charging 10 minutes for 3 hours music time
● Bluetooth V4.2, colorful design
● Voice prompt with multiple languages
Gearbest
7 February 2017
1,601
Syllable D300L Wireless Bluetooth Sports Earbuds - BLACK
On-cord Control / Sweat Resistance / Hands-free Call
$17.99 with coupon D300L
● Bluetooth V4.2 for best stereo sound and superb bass
● Sweat resistance protects the earbuds and prolongs the use time
● Press the controller to play / pause music as well as all get through calls
● Works perfectly with iPhone 7 / 6 / 6s Plus / 5s / SE / 5C / 4s, and other android devices
Gearbest
7 February 2017
1,601
DJI Spark Mini RC Selfie Drone - BNF WHITE
WiFi FPV 12MP Camera / 2-axis Mechanical Gimbal / Gesture Mode
$529.99 with coupon:GBSpark
● 1/2.3 inch CMOS sensor, f/2.6 wide-angle lens, 2-axis mechanical gimbal for stabilized 1080P videos and 12MP stills
● Powerful propulsion enables Spark to fly at up to 50 kph in Sport Mode
● Multiple Intelligent Flight Modes available - ActiveTrack, TapFly, QuickShot etc.
● Gesture Mode is only be used to take selfies but also control the drone within 3m range
● 1480mAh 11.4V LiPo provides 16min long flight time for more footage
Specifications:
Aircraft
Max. flight time: 16 minutes ( no wind at a consistent of 12.4 mph / 12 kph )
Max. hovering time: 15 minutes ( no wind )
Operating temperature range: 32 to 104 Deg.F ( 0 to 40 Deg.C )
Satellite positioning system: GPS / GLONASS
Transmitter power ( EIRP ): 2.4GHz FCC: 25dBm; CE: 18dBm; SRRC: 18dBm; 5.8GHz FCC: 27dBm; CE: 14dBm; SRRC: 27dBm
Operating frequency: 2.400 - 2.483GHz; 5.725 - 5.825GHz
Takeoff weight: 300g
Dimensions: 143 x 143 x 55mm
Diagonal distance ( propellers excluded ): 170mm
3D Sensing System
Obstacle sensing range: 1 - 16ft ( 0.2 - 5m )
Operating environment: surface should be larger than 20 x 20cm and enable diffuse reflection, with reflection rate more than 20 percent ( e.g. wall, tree, people )
Camera
Sensor: 1/2.3 inch CMOS, effective pixels: 12MP
Lens: 81.9-degree FOV, 25mm ( 35mm format equivalent ) f/2.6 ( shooting range: 2m to infinity )
ISO range: video: 100 - 3200; photo: 100 - 1600
Electronic shutter speed: 2 - 1/8000s
Image size: 3968 x 2976
Video resolution: FHD: 1920 x 1080 30fps
Max. video bitrate: 24Mbps
Supported file system: FAT32 ( 32GB or less )
Photo format: JPEG
Video format: MP4 ( H.264 / MPEG-4 AVC )
Intelligent Flight Battery
Capacity: 1480mAh
Voltage: 11.4V
Max. charging voltage: 13.05V
Battery type: 3S LiPo
Energy: 16.87Wh
Net weight: approx. 0.2 lbs ( 95g )
Charging temperature range: 41 to 104 Deg.F ( 5 to 40 Deg.C )
Gimbal
Controllable range: pitch: -85 to 0 degree
Stabilization: 2-axis mechanical ( pitch, roll )
Vision System
Velocity range: 22.4 mph ( 36 kph ) at 6.6 feet ( 2m ) above ground
Altitude range: 0 - 26 feet ( 0 - 8m )
Operating range: 0 - 98 feet ( 0 - 30m )
Operating environment: surface with clear patterns enables diffuse reflection with more than 20 percent reflection rate; adequate lighting ( more than 15 lux )
WiFi
Operating frequency: 2.4GHz / 5.8GHz
Max. transmission distance: 100m ( distance ), 50m ( height ) ( unobstructed, free of interference )
Gearbest
7 February 2017
1,601
Alfawise S60 Window Cleaner Cleaning Robot - US PLUG WHITE
Flash Sale Price $126.99
AI Technology
Automatically detects window frames and obstacles, calculates and programs an optimal cleaning path for maximum efficiency
UPS System and Anti-dropping Algorithm
To stop this small smart appliance from falling if the battery cuts out or the power fails
Zigzag Automatic Cleaning Routes
Auto up then down, auto left then down, auto right then down
Powerful Motor-powered Suction
The vacuum motor will draw in air allowing the robot to hold onto the glass tightly as it traverses the surface
Remote Control
Simply switch the cleaning route or control the directions by the remote controller
APP Control
You can control the cleaner through the Bluetooth matching to your smart phone or tablet
Gearbest
7 February 2017
1,601
SOOCAS X3 Sonic Electric Toothbrush - MOTOR BLACK
Bluetooth Linkage Wireless Charging IPX7 Waterproof Rating Xiaomi Ecological Chain
Flash Sale Price $46.99
• 4 cleaning modes
Clean, sensitive, gumcare, whitening
• Smart wireless charging
The base can automatically identify the electric brush, very convenient for you to use
• Long service time
Built-in 1000mAh Li-ion battery, the charging time is about 16 hours, the usage time is about 25 days
• Customized setting
You can set or choose the mode, intensity and brushing time through your phone
• Bluetooth connectivity
You can connect the electric toothbrush with your phone via Bluetooth, the APP will show you some information, such as the cleaning degree, the residual electricity, the time for replacing brush head
• The whole body is washable
The whole body is IPX7 waterproof level
• Fine workmanship
Smooth and comfortable hand feeling, this electric toothbrush also gives you the sense of beauty
• APP supported languages
Ukrainian, Russian, Simplified Chinese, English, Korean
• Various product certification qualifications
FCC, CE, FDA, and IPX7 waterproof
Gearbest
7 February 2017
1,601
Original Xiaomi AMAZFIT A1603 Smartband Android iOS Compatible - INTERNATIONAL VERSION BLACK
IP67 Waterproof Bluetooth 4.0 Heart Rate Monitor
$34.49 with coupon coupon:AMA1603
Perfect Personal Health Tracker: heart rate monitor, pedometer, distance, calories and sleeping monitors.
Ultra-long Battery Life and USB Rechargeable: it consumes less power and can generally standby for 20 days. You can see the battery indicator on the screen.
Waterproof Design: IP67 waterproof standard, suitable to use at home, office and during outdoor activities.
Gearbest
7 February 2017
1,601
DC 12V 300 PSI Electric Pump Air Compressor Tyre Inflator for Car Motorcycle - Black - BLACK
Flash Sale Price $9.99 !!! 50 pieces
300 PSI range gas meter, let the tire pressure display more accurate
15 of LPM light gas flow, far the supermarket similar products
High strength pressure braided tube
8 minutes to play full your 15 inch tire
Easy to use-just plug into your car cigarette lighter for power,slip universal adapter over tire valve and your are ready to inflate
Equipped with pressure checking gauge
Suitable for: bicycle tires, car tires, motorcycle tires, tricycle tires, electric car tires, football, basketball, inflatable boat, air bed, balloon, etc
Gearbest
7 February 2017
1,601
Tronxy X1 Desktop 3D Printer - EU PLUG GUN METAL
Support SD Card Off-line Printing + LCD Display + High Precision 0.1 - 0.4mm
Flash Sale Price $132.99
● Supports SD card off-line print, especially convenient when without a computer
● 0.1 - 0.4mm layer resolution, high precision
● 150 x 150mm x 150mm build volume
● 0.1 - 0.5mm layer resolution accelerates the design process
● LCD screen shows your printing information directly and easy for you to manipulate
● Enhanced stability and reliability: acrylic plate ensures more stable printing
● Supports 3D printing filaments: PLA, ABS
● Operating system: Windows XP / 7 / Mac
