h264 Cutter v111 for DM800
Code:
New Features: -M2TS as input file supported (h264 codec only) -TRP/REC 2 TS converter (use 'Tools' -> 'Convert TRP/REC -> TS'). TRP files are for example used by Clarke-Tech HD 5000-C or Kathrein UFS910 and may be from other PVRs. REC file are used by Topfield Receiver This feature is not perfect yet because some media player (e.g. mplayer) detect the h264 stream as mpeg2 but for the most players it works fine (mpc, vlc, ...) -improved "drop usless freames" Fixed items: -more HD channels are supported (e.g. HD Suisse, SVTHD, Digit ALB HD) use 'Setting' -> 'Advanced' -> set In to 'I-Frame' or 'All-Frame' and Output frame type to 'All-Frame' -(Vista) 64 bit problem fixed: the cutter should work on 64 bits systems, too
Code:
