http://dune-hd.com/firmware/
Bγηκε νεο fw ! Δεν δειχνει να εχει ριζοσπαστικές αλλαγες.
120202_1544_beta
NOTE: Includes also all changes from 120127_2115 (see below).
* Added "Soft Reset" function:
- Now the "Reset Settings" function proposes two choices: full reset to
factory defaults (the same as took place in previous firmware
versions), and so called "soft reset".
- The soft reset clears the settings only partially and is more
convenient in cases when the user does not need full factory reset.
- The following things are cleared by the soft reset:
- All settings from Setup menu.
- All plugins settings.
- All cached data and data stored by the player for its own needs.
- All bookmarks (remembered playback positions).
- The following things (which may be hard to reconfigure from the
scratch) are kept by the soft reset:
- All configured network folders.
- All favorites configured in the main menu.
- All installed plugins.
* Improvements for the users of big remote controls:
- Added the setting allowing to choose the behavior POP UP MENU RC
button: toggle playlist/TV menu (as took place in previous firmware
versions), or toggle the new functions menu (introduced in the latest
firmware version) (this is the default behavior). The old behavior
(toggle playlist/TV menu) can be convenient for the users used to it.
Enabling the old behavior makes the functions menu unavailable (and
thus it may be reasonable only for users of big remote controls, which
have dedicated buttons allowing to trigger various playback functions
w/o the need to use the functions menu). The setting: 'Playback /
Preferences / POP UP MENU button'.
- On the models which are shipped by default with big remote control,
LEFT/RIGHT RC buttons during playback now trigger the time seek
function (as took place in previous firmware versions), rather then
the volume function (as was introduced in the latest firmware verion).
* Tvigle.ru application improvements:
- Added setting allowing to manually control if the application is shown
or not on the main screen: 'Setup / Applications / Tvigle / Shown on
the main screen'.
* Minor other improvements and fixes.
