HDI Dune Prime 3.0 Review !
vadergr
17 August 2007
27,479
Μεταμορφωση
Αφηστε τους αλλους να ψαχνονται για το ποιο ειναι το καλυτερο media player :worshippy:
http://dune-hd.com/accessories/129-dvb-t_tv_stick.html
DVB-T USB dongle for Dune media players based on Sigma Designs 864x platform (currently Dune HD Base 3.0 and Dune BD Prime 3.0) with antenna and USB extension cable.
Specification:
Compatible with Dune media players based on Sigma Designs 864x platform
USB 2.0 Standard (USB Type B Female Connector)
DVB-T Compliant (SD and HD channels)
Input Terminal: 75 Ohm IEC (DIN) Connector
Receiving Frequency: 48.25..863.25 MHz
Bandwidth: 6/7/8 MHz Auto Select
Requirements:
Dune media player based on Sigma Designs 864x platform
UHF/VHF Antenna for DVB-T Terrestrial TV (included)
Contents:
USB dongle
Compact size antenna
USB extension cable (1.8m or 2.0m)
Notes:
Dual-dongle supported: compatible models of Dune players (see above) can work with two Dune DVB-T dongles at the same time. In such a case for example one of the dongles can be used for writing contents from some channel to HDD, another one at the same time is used for watching any other available channel.
This product doesn't contain any software.
All the needed software for operating the included USB dongle and working with DVB-T channels is a part of the firmware of the compatible Dune players (see above).
The first version of Dune firmware supporting DVB-T will include basic work with DVB-T channels (inc. TV programs recording to HDD), but supporting EPG will be included into the future versions of the firmware.
You can use this equipment with a PC on your own risk. No support for such use is provided.
MSRP:
EU, with VAT: 59 EUR
neof1z
14 January 2009
848
ΠΕΡΙΣΤΕΡΙ
Specification:
Requirements:
Contents:
USB dongle
Notes:
MSRP:
Σίγουρα θα αναφέρεσαι σε τίποτα άσχετους.Ένα Feature που προσωπικά δεν με ενδιαφέρει καθόλου άσε το ενδεχόμενο που μπορεί να παίξει και στο C-200.Είμαι περίεργος να δω και πως θα δουλεύει τη στιγμή που τα USB tuners ζητάνε Core2duo.Κάτσε να το δεις να δουλεύει και ύστερα πανηγύριζε.
Αν συστήνεις κάποιο Dune καλυτερα να τους λες το Base γιατί έχει βουίξει ο τόπος με το θορυβώδεις BD του Prime.
http://www.mpcclub.com/forum/showthread.php?t=22167
Αν αυτό (noisy BD drive in the Prime 3.0) αφορούσε το C-200 θα ήσουν ο πρώτος που θα το είχε ποστάρει.
vadergr
17 August 2007
27,479
Μεταμορφωση
Τα αρνητικα για το drive του prime τα εχω αναφερει στην παρουσιαση εδω και πολυυυυυυ καιρο.Σε εμενα παντως τοσο θορυβωδες ΔΕΝ ειναι και πιο πολυ με ενοχλουν καποιες ασυμβατοτητες του με αντιγραμμενα δισκακια dvd9 παρα ο θορυβος.
Σε οτι εχει να κανει με την ισχυ, μην ξεχνας οτι media players με ενσωματωμενο ψηφιακο δεκτη, χρησιμοποιουν ακομα και περσινα τσιπακια (8635).
Δεν τιθεται θεμα για την δυνατοτητα του prime/base σε αυτον τον τομεα.
Τωρα αν τα θαλασσωσουν αλλου, δεν ξερω.
ΥΓ.Ειμαι σιγουρος οτι δεν απευθυνομαι σε ασχετους και για αυτον τον λογο θελημενα προσπαθω να δωσω τις δικες μου αποψεις/γραμμες γιατι πολυ απλα σεβομαι το καθε ευρω που θα δωσει καποιος για την αγορα ενος media player.Ευχομαι να μην μου πειτε ποτε οτι τα παιρνω κιολας ...Εχω ξεκαθαρη θεση για το xtreamer στην value κατηγορια και στα base/prime 3.0 στην ακριβη.Ουτε το εκρυψα, ουτε το μετανοιωνω αλλα ουτε ποτε εχω βγαλει τα υπολοιπα σκαρτα.
neof1z
14 January 2009
848
ΠΕΡΙΣΤΕΡΙ
Όποτε άλλος ένας λόγος να μην πρωτεΐνης το prime.
Ξέρεις ότι δεν άφησα ούτε υπονόησα κάτι περει χρηματισμού.
Σκάρτο βγάζεις όποτε μπορείς το c-200.To customize που έχει το C-200 δεν υπάρχει σε κανενα player.Με το LiteOn BD που έχω επάνω επάνω παίζει τα πάντα.
vadergr
17 August 2007
27,479
Μεταμορφωση
Δεν ειπα ποτε οτι δεν παιζει και ακομα και προσφατα καπου παλι ανεφερα οτι στην υψηλη κατηγορια κυριαρχουν dune και c200 ...
Απλα εχω την δικη μου ξεκαθαρη αποψη.
Δεν το θαβω το c200 απλα πιστευω οτι θα επρεπε ΗΔΗ να κανει καποια βασικα (mkv/ts hd audio, ασυμβατοτητες με αρκετα απο οτι διαβαζω bd rips,bugs τυπου στο πχ νεο fw δεν παιζουν τα flac μετα απο αναπαραγωγη βιντεο ενω στο προηγουμενο επαιζαν σωστα, και δεν ξερω αν πλεον εχει δωσει λειτουργικο autoframe rate).
Να ειδες?Με τσιγκλησες παλι :Banane0: (πιστεψε με , μονο του βγαινει :grinning-smiley-043 )
neof1z
14 January 2009
848
ΠΕΡΙΣΤΕΡΙ
Συμφωνώ μαζί σου 100% κάποια πράματα για κάποιους βασικά για κάποιους όχι έχουν ΚΑΡΑ ΑΡΓΗΣΕΙ αλλά αυτό δεν σημαίνει ότι δεν θα γίνουν.Οι τύποι δεν είναι σαν το Xtreamer.
http://www.avclub.gr/forum/member.php?u=4011
καμμια επιθεση , ισα ισα νομιζω ξεκαθαρισα καποιες ,ισως διφορουμενες απο την μερια μου, αποψεις...
Το ίδιο και εγώ.
vadergr :grinning-smiley-043
nigio
22 December 2008
271
ειναι καποιος π εχει βαλει διπλα διπλα popcorn c200 και dune για συγκριση?με προβληματισε το ποστ,που βγαζει το ποπ κορν ανωτερρο σε εικονα...
jami
21 May 2009
23
Έχω το εξής πρόβλημα!!Βάζω ταινία με ματρόσκα με DTS και πεντακάναλο ήχο μου βγάζει μόνο μέσω οπτικής και ομοαξονικής.Μέσω HDMI που δίνω στην τηλεόραση και απο την τηλεόραση στον Ενισχυτή (digital out της τηλεόρασης), ο ενισχυτής το βλέπει σαν δικάναλο στέρεο!!Το αστείο είναι οτι ο ενισχυτής παρόλο που το βλέπει σαν στέρεο, στην πραγματικότητα παίζει τα 2 εμπρός κανάλια του DTS με αποτέλεσμα να ακούγονται μόνο τα εφέ και η μουσική, αλλα όχι οι ομιλίες απο την ταινία που αποδίδονται απο το κεντρικό!Δοκίμασα και άλλο ένα καλώδιο HDMI που είχα πρόχειρο αλλα δέν κατάφερα κάτι.O ήχος είναι στην επιλογή bitstream και το HDMI audio επίσης ενεργοποιημένο.Καμμια ιδέα;υποψιάζομαι οτι το καλώδιο HDMI είναι το πρόβλημα.Με τον ίδιο τρόπο έχω συνδέσει και έναν AZBOX premium και το 5 κάναλο παίζει μια χαρά στον ενισχυτή!Καμμιά ιδέα;
20 June 2006
9,533
Απάντηση: Re: HDI Dune Prime 3.0 Review !
Αυτό το βρήκα στο avsforum:
-The Spears & Munsil BluRay has a 1080p test pattern that is designed to show pixel accuracy. On the Dune, only 1919 horizontal pixels are visible on a 1920x1080 display. Hence the Dune is scaling when it should not be.
Τι γίνεται ρε παιδιά? Νόμιζα ότι το Dune είναι the best!
Οντως υπαρχει ένα θεμα αλλα όχι σαν αυτό που παρουσιαζεται στο avs.
Εχει παρατηρηθει και αναφερθει στο mpc πως γινεται overscan κατά ένα pixel , δεξια και κατω της οθονης…
Σαν να λεμε αντι του 1920Χ 1080 , 1921Χ1081…
Αυτό προφανως δε βοηθα στο τελειο νετάρισμα για αυτό και η παρατηρηση περι ευκρινειας στο παραπανω κειμενο…
Το ευχαριστο είναι πως εχουν ενημωρηθει οι υπευθηνοι της Dune και εχουν ανακοινωσει πως στο επομενο firmware το προβλημα θα λυθει..
sstav
23 August 2009
134
Να ρωτήσω δύο-τρία πραγματάκια
1. το prime με +70 ευρώ για BRDisc αξίζει λέτε σε σχέση με το basic;
2. Υπάρχει περίπτωση το blueray του prime να υποστηρίξει 3D Blueray με firmware upgrade;
3. Το Basic, όταν βγουν 3d blue ray players θα μπορέσω να αγοράσω ένα τέτοιο ξεχωριστά και να το κουμπώσω ώστε να παιζει κανονικά;
Συγνώμη αν έχουν ξανασυζητηθεί
sstav
23 August 2009
134
άρα είναι πολλά τα λεφτά 279 ακόμα και για τα βασικά που μπορείς να κάνεις και με ενα xtreamer pro
neof1z
14 January 2009
848
ΠΕΡΙΣΤΕΡΙ
Όχι φίλε μου δεν είναι πολλά τη στιγμή που ότι λέει το κάνει και θα κάνει ΠΡΑΜΑΤΑ που δεν ήταν να τα κάνει.
vadergr
17 August 2007
27,479
Μεταμορφωση
Tα βασικα τα κανουν και μηχανακια των 100-120 , δεν χρειαζεται να παει καποιος στα c200/prime 3.0 για να τα εχει.
LefterisV
9 June 2010
73
Θα περιμένω για το 4.0 και μέχρι τότε θα βλέπω από ένα HP laptop με υποστήριξη BD και bistream.
