Έρχεται Δεκέμβρη με τιμή κάτω από 250 ευρώ.
HDX-BD1: Network media player with Blu-ray support
The HDX-BD1 has a great deal in common with the Popcorn Hour C-200. It's one of a new generation of machines that are Blu-ray compatible. In the C-200, you can install a Blu-ray drive in the unit itself. With this HDX machine, you have to use an external drive instead, but even so, it gives a very desirable route to playing Blu-rays. The advantages are that not only can you play movies from disc, but you can also stream HD video over your home network to your TV in up to 1080p quality.
The BD1 uses a new interface from HDX known as Voir, which the company believes gives a very user-friendly experience. As with previous models, it's possible to fit a hard drive to the player via tool-free process. Adding a hard drive will allow you to take advantage of the built-in BitTorrent and usenet clients. It also makes it possible to send content to the machine using an FTP client, which can be very useful if you want to use it while your main PC is switched off.
The BD1 has gigabit Ethernet too, which should mean streaming 1080p video is a glitch-free and pleasant experience. If you're connecting external devices, you'll be pleased to know there are two USB 2.0 sockets at the rear, as well as an eSATA connector for either a high-speed hard drive, or Blu-ray drive. You'll also find HDMI 1.3, which is capable of sending 1080p video to a Full HD TV. The BD1 can also pass Dolby TrueHD and DTS HD audio to a compatible audio decoder too, so you'll get the full Blu-ray sound experience too.
HDX BD-1 HARDWARE SPECIFICATION
Chipset:
Sigma Designs SMP8642, 667MHz CPU with floating point coprocessor.
Memory:
1GB DDR2 DRAM
1GB NAND Flash
1GB internal flash drive (for BDLive or other content)
Audio/Video Outputs:
HDMI v1.3a supports deep color and true HD audio enjoyment
Component Video
Composite Video
Stereo Analog Audio
S/PDIF Optical and Coaxial Digital Audio
Interface:
Power button with standby and reset button
2x USB 2.0 host at the back
1x SATA (one occupied by HDD tray)
1x eSATA (for external HDD or BD Rom Connectivity)
3.5" HDD tray
Network:
Gigabit Ready LAN adapter
Power:
Input 100~240V AC, 50~60 Hz,
OutputC 12V max 3A
usual power consumption
10 W (no device connected)
maximum power consumption: 36 W
Footprint:
Width x Depth x Height : 170mm x160mm x 50mm (6.69" x 6.29" x 1.96")
Weight:
1kg (2lbs 2oz)
SOFTWARE SPECIFICATION
Connectivity:
Bonjour
UPnP SSDP
UPnP AV
Windows Media Connect
Windows Media Player NSS
Samba
NFS
UPNP Media Servers: TVersity, Twonkymedia
BitTorrent P2P
Usenet downloader
NAS Access : SMB, NFS, FTP(optional)
Supported Media File Formats
Video containers:
MPEG1/2/4 Elementary (M1V, M2V, M4V)
MPEG1/2 PS (M2P, MPG, DAT, VOB)
MPEG2 Transport Stream (TS, TP, TRP, M2T, M2TS, MTS)
AVI, ASF, WMV
Matroska (MKV)
MOV (H.264), MP4
Video Decoders:
XVID SD/HD
MPEG-1
MPEG-2 MP@HL
MPEG-4.2 ASP@L5, 720p, 1-point GMC
MPEG-4.10 (H.264) : BP@L3, [email protected], [email protected], [email protected]
WMV9 : MP@HL
SMPTE 421M (VC-1) : MP@HL, AP@L3
Audio Containers:
AAC, M4A
MPEG audio (MP1, MP2, MP3, MPA)
WAV
WMA
FLAC
APE
Audio Decoders:
Dolby Digital
DTS
WMA, WMA Pro
MPEG-1 Layer 1, 2, 3
MPEG-4 AAC-LC
MPEG-4 HE-AAC
MPEG-4 BSAC
LPCM
FLAC
Vorbis
Audio Pass-Through:
DTS, DTS-HD HR, DTS-HD MA
Dolby Digital, Dolby Digital Plus, Dolby True HD
Other Formats:
ISO, IFO navigation
AVCHD navigation
Blu-ray** ready (requires addition of compatible external BD-ROM)
Photo Formats:
JPEG, BMP, PNG, GIF, TIFF
Subtitle Formats:
SRT, MicroDVD SUB, SSA, SUB/IDX
Chipset:
Memory:
1GB DDR2 DRAM
1GB NAND Flash
Component Video
Composite Video
Stereo Analog Audio
Interface:
3.5" HDD tray
Network:
Power:
OutputC 12V max 3A
Footprint:
Weight:
1kg (2lbs 2oz)
Connectivity:
Bonjour
UPnP SSDP
UPnP AV
Samba
NFS
BitTorrent P2P
Usenet downloader
Video containers:
AVI, ASF, WMV
Matroska (MKV)
MOV (H.264), MP4
Video Decoders:
XVID SD/HD
MPEG-1
MPEG-2 MP@HL
WMV9 : MP@HL
Audio Containers:
AAC, M4A
WAV
WMA
FLAC
APE
Audio Decoders:
Dolby Digital
DTS
WMA, WMA Pro
MPEG-4 AAC-LC
MPEG-4 HE-AAC
MPEG-4 BSAC
LPCM
FLAC
Vorbis
Audio Pass-Through:
Other Formats:
ISO, IFO navigation
AVCHD navigation
Photo Formats:
Subtitle Formats:
