φιλε μου η Audioevolution εχει σε πολυ καλη τιμη τα Castle Knight 2. Ειναι πολυ ενδιαφερουσα περιπτωση και μπορεις να τα ακουσεις εκει με ραντεβου.
· Type: bookshelf
· Cabinet: bass reflex
· Impedance: 8 ohms
· Sensitivity: 90dB 1 watt @ 1 meter
· Number of ways: 2
· Power handling: 125 watt RMS
· Recommended amp.: 6-125 watt RMS
· Frequency Response: 42Hz - 24 kHz
· Crossover freq: 3.0 kHz (second order)
· Tweeter: 25mm (1 inch) soft dome
· Mid/Woofer: 150mm (6.5 inch) mixed fibre cone
· Finish: Rosewood & Black
· Optional Finishes: Cherry, Maple, Oak & Walnut
· Hand Maded High Quality Real Wood Veneers
· Size (HxWxD) mm.: 380 x 200 x 335
· Weight /Pair: 18kg
Μετα υπαρχουν τα Focal JmLab 706V
Description 2-way bass reflex bookshelf loudspeaker
Power RMS 80 W
Sensitivity (2,83V/1 m) 90 dB
Frequency range 55Hz-28kHz
Crossover frequency 3000 Hz
Drivers 61/2’’ (165mm) Polyglass mid-bass
1’’ (25mm) TNV inverted dome tweeter
Nominale impedance (EN 600065) 8 Ω
Dimensions (HxWxD) 390x222x293mm
Weight 18lbs (8.2kg)
Color Ebony, Amati
Warranty 2 years
Αν θες κατι τονικα ουδετερο υπαρχει το Quad 11L2
Standmount Yes
Floorstander No
Sensitivity (db/w/m) 86
Impedance (ohms) 6
Max power handling (watts) 150
Biwirable Yes
Finishes 6
Dimensions (hwd, cm) 31x19x24
Aν θες μικρη κολωνα Wharfedale 10.3
# Ηχεία δαπέδου 2 δρόμων
# Bass/Mid Driver 125mm
# Tweeter 25mm
# Ισχύς 20-100 wrms
# Αντίσταση 6ohm
# Ευαισθησία 86dB
# Απόκριση Συχνότητας 40-24kΗz
# Crossover 1.8kHz
# Διαστάσεις 800 x 194 x 278 mm
Επισης τα Mordaunt Short 914i
Avant 914i
Sensitivity 90dB
Frequency response 39 - 22kHz
Nominal impedance 4 - 8 Ohms
Drive units 1 x 165mm (6.5") aluminium CPC mid/bass drivers
1 x 25mm (1") aluminium dome tweeter
Crossover Damped 2nd order HF with DVP
Recommended amplifier power 15 - 120 watts
Magnetically shielded Yes
Dimensions (h x w x d) 860 x 180 x 270 mm (38.8 x 7 x 10.6")
Weight 13.5Kg (29.7lbs)
Και μην ξεχασω το Kef iq30
Design: Two-way bass reflex
Frequency Response: 45Hz - 40KHz
Amplifier Requirements: 15-120W
Magnetic Shielding: Yes
Maximum Output: 110dB
Input Impedance: 8 Ohms
Weight: 6.7kg (14.8lbs)
Dimensions (H x W x D): 365 x 220 x 327 mm (14.4 x 8.7 x 12.9 in.)
Ολα ειναι στην κατηγορια τιμης που ορισες. Για τιμες
www.skroutz.gr
Ωρα να αρχιζεις ακροασεις!-bye-
