Ideon Audio: Ayazi Dac
artheo
7 October 2013
469
οκ. Πάντως το ότι το προσφέρει η αντιπροσωπεία για δοκιμαστική ακρόαση πριν το αγοράσει κάποιος είναι πολύ σημαντικό και εκτιμητέο!
Δεν παίρνεις γουρούνι στο σακί δηλαδή. Όποιος ενδιαφέρεται μπορεί να το ακούσει και να διαμορφώσει τη δική του γνώμη...
DomieMic65
10 July 2006
9,689
Όντως πολύ σπουδαίο κ μπράβο τους!!
nickvas19
11 August 2011
2,008
ισχυει....ειχα αναφερθει και εγω σε αυτο.και μαλιστα ο αντιπροσωπος βρηκε καποιον που τυχαινε να ερχεται εδω και μου το εστειλε με εκεινον
VaSiLiS-T
10 January 2007
8,209
παλλληηηηηνιηηηη
"Positioning of the speakers is the key, " Marantz brand ambassador Ken Ishiwata announced as he spoke of the new Fink Team loudspeaker . Designed by a team headed by consultant Karl-Heinz Fink, these will hopefully go into production. Paired with Marantz's new upsampling-to-DSD SA-10 CD/SACD player ( 7000), which contains Marantz's new SACD transport, and the new PM-10 integrated amplifier ( 8,000), the speakers delivered tremendous bass, supreme control, and somewhat dark colors that lacked ultimate transparency. Ishiwata played Peter Gabriel so loud in the big room that the sound waves were literally vibrating in my gut. Most exhibitors would have been terrified to do this, but the Fink team speakers sailed through without a hint of distortion. Very impressive indeed.
Colors were nicely saturated on a hi-res file of Joni Mitchell and Herbie Hancock's "Summertime," and images had weight. Which is how it should be. I shuddered when "Dance of the Tumblers" was put on, but I must admit that the tonal balance, while dark, was quite impressive. So was the SACD version of "O Holy Night," originally recorded for LP on another audiophile classic, Cantate Domine.
When I met up with Fink himself in the hallway, he explained that he used laser scanning and vibrometer measurement to determine where he needed to minimize resonances in his MDF-based cabinets. Those cabinets contain multiple sheets of MDF layered with polymer damping materials, as well as bracing and glue. "We try to fix distortions, but not with a sledgehammer," he said of his apparently bullet-proof design.
Read more at https://www.stereophile.com/content/rounding-bend-munich-high-end#i2mDSmGJAKy3msAX.99
Το ayazi DAC επιλέχθηκε μετα απο πολύμηνη δοκίμη ... για πηγή στην εμπορική πλέον παρουσίαση των FinkTeam WM-4. loudspeaker ( 65κ )
A huge amount of subjectivity is going to be apparent when talking about the best sounding speaker at the show but, for me and fair few other people I spoke to at the show- that title went to the FinkTeam WM-4. This is the productionised version of a speaker that has been in existence for some time, principally in use as a test bed. FinkTeam is not a household name but Karl Heinz Fink who heads it up can justifiably claim to be the most influential person in audio you probably haven’t heard of. The development of the WM-4 has in part taken place at the same time as the Q Acoustics Concept 500- something largely handled by Fink- and some of the ideas you can see in that speaker have been taken to their logical conclusion here. There’s no hiding from the facts that this is a 135kg speaker that costs 65,000 but the sound it makes is utterly and continuously fabulous and across a wide variety of material, it delivered an absolutely staggering performance.
spcav
18 August 2006
16,598
Όμορφα
Μπλέχτηκα όμως λίγο
Τα link / κείμενα αναφέρονται μόνο στα ηχεια, δεν βλέπω κατι σχετικό με την επιλογή του dac
VaSiLiS-T
10 January 2007
8,209
παλλληηηηηνιηηηη
Στο λέω εγώ ότι έτσι είναι ,, απλά
βλέπεις φωτό ...
ο ίδιος ο Karl Fink , μας κάλεσε εκεί ,, για υτό και μόνο τον λόγο ,,
τι δεν καταλαβαίνεις ?
economo
4 December 2007
586
ΑΘήνα, Ελλάδα
Εξαιρετικά Νέα Βασίλη!
Εύγε!
Νοιώθω ιδιαίτερα περήφανος για το "ταπεινό" Ayazi που συνεισφέρει ή αναδεικνύει τα μεγαθήρια της Fink, οπότε φαντάζομαι πως νοιώθεις εσύ!
Μερικά παραλειπομενα από το story της επιλογής του Ayazi για το συγκεκριμένο σύστημα, θα είχαν πολύ ενδιαφέρον...
Π.Χ. ξέρεις τι άλλο δοκιμάστηκε και απορρίφθηκε?
Τι σχόλια έκανε ο Kalr για την κατασκευή σας?
Καλή συνέχεια και παλι συγχαρητήρια!
Στάλθηκε από το GT-I9505 μου χρησιμοποιώντας Tapatalk
VaSiLiS-T
10 January 2007
8,209
παλλληηηηηνιηηηη
Mε τον Karl Heinz υπάρχει εδώ και καιρό καποιου είδους συνεργασία σto επίπεδο του digital domain , ανταλλαγή απόψεων συμβουλών οδηγιών . κτλ ... που δεν ειναι του παρόντος , το Ayazi το έχει στην κατοχή του περίπου ένα χρόνο
φαντάζομαι θα δοκίμασε αρκετά .. έχει αυτήν δυνατότητα , αυτό που ακνακοίνωσε ο ίδιος στην κλείστη συνέντευξη τύπου στην αίθουσα του ότι το τελευταίο που δοκίμασε ήταν το Marantz SA-10 το οποίο χαρακτήρησε very nice ! but toο nice for me ...
τα σχόλια και οι παρατηρήσεις απο πλευράς του όδηγησαν στο AYAZI MK2 ,
2 λόγια για τον ήχο του δωματίου ,,, μετά απο 4 μέρες και διάφορα προγράματα που ακούστηκαν ,,,, μου κατάστρεψε την ψυχολογία :bigcry: και η πλειοψηφία μετα μου ακουγεται πλέον τενεκες ,, αλλα θα μου περάσει ,,
αυτό που μου εντυπώθηκε σίγουρα ήταν εκείνο το καταραμένο χαμηλό ,, είναι αyτό που λέμε no way back ... και ευτυχώς η δυστυχώς δείχνει τον κανόνα ,,, το μεγάλο ηχείο ειναι απαραίτητη προυπόθεση για " μεγάλο ήχο "
αυτά ...
-bye-
economo
4 December 2007
586
ΑΘήνα, Ελλάδα
Βρίσκω πολύ κατατοπιστικο το τελευταίο ποστ σου.
Κάτι τέτοιο ήθελα για να αντιληφθώ τη σχέση σου με τον Karl και το πως έφτασε να βάλει στο rack το Ayazi.
Well done! Και παλι μπράβο!
Υ.Γ. Με αυτά τα ακριβά "στοιχειά" τι θα κάνουμε, δεν ξέρω... 😊
red7760
18 January 2014
237
Κηφισιά
Μπραβο Βασιλη! Και εις ανώτερα να ευχηθω!
Και ολα αυτα χωρις εξοδο και προενισχυση για ακουστικά, χωρις φωτεινες ενδείξεις δειγματοληψιας,χωρις xlr συνδεσεις....!
Well done!
Αντε να βρω λιγο χρονο να φερω το δικο μου για την αναβάθμιση!
